skidoo_j Posted September 25, 2010 Posted September 25, 2010 I have an 89 Comanche Sport truck that had a D35. I recently swapped in a D44 performing a SOA conversion. By cutting the spring perches and using XJ shackles i've got the rear lift about 4"... I'm currently experiencing death wobble. And going though Idea as to the fix. Transfercase drop or yj Yoke? Or both??? anyone know typical at rest measurement for the slip yoke out of the cone? Need to see if driveline is too short w/ 4" lift. I know the D44 Snout is 1" longer than D35 but yoke currently looks to be pulled an extra 1/2" assuming the shiny part was inside. In the front i'm swapping in LCA that are adjustable, and the HD trac bar. but does anyone have an opinion if the knuckle to knuckle steering is better than the stock y? also have a 3/4" pitman arm drop should or should not use??
skidoo_j Posted September 25, 2010 Author Posted September 25, 2010 Oh truck specs that maybe needed to respond to my ???? 4.0 manual trans 5 speed. 231 transfer... changed diff gears to 3.54 in front to match d44.
carnuck Posted September 25, 2010 Posted September 25, 2010 Death wobble is in the steering and not the driveshaft. IIRC YJ has a longer yoke. Count the splines and check the diameter though
Motion Offroad Posted September 25, 2010 Posted September 25, 2010 IIRC YJ has a longer yoke. Count the splines and check the diameter though The YJ yoke is longer, but is not fully splined the extra length like the XJ/MJ yokes are. So what you gain in length you loose in spline engagement.
skidoo_j Posted September 25, 2010 Author Posted September 25, 2010 so the spline count is the same, just the spline is not cut as deep into the yoke shaft? so in theory the driveline lenght is shortened, but the amount of movement is less?
Pete M Posted September 25, 2010 Posted September 25, 2010 with a 4" lift (driveshaft is now short an inch) and a Dana 44 (snout is 1" longer than a Dana 35) added to the mix, your rear shaft should be about the right length. don't forget to install new U-joints. old joints don't like changes in their operating angle and that can cause vibrations. death wobble is a horrifyingly violent shaking of the front end that makes you slam the brakes and pray to god that you don't hit something. Is that what you're experiencing?
skidoo_j Posted September 25, 2010 Author Posted September 25, 2010 correct, but it feels like it starts in the rear end.. as i see the bed shake before i feel it.
Pete M Posted September 26, 2010 Posted September 26, 2010 are you sure everything is tight? U-bolts? lug nuts? maybe bad bushings? bad U-joints? is the driveshaft straight? rotted frame?
freakjeep93 Posted September 26, 2010 Posted September 26, 2010 possibly VERY out of balance rear wheels or really bad wheel bearings? mabye bad shocks? idk I'm just throwing ideas out
64 Cheyenne Posted September 26, 2010 Posted September 26, 2010 You didn't say anything about the front axle. My guess is that you did the SOA on the rears.....did you lift the front also? If not then you have a castor issue causing your problem. (Front wheels tilted too far forward) The fix, lift the front or put more shims in the LCAs to get your 7* neg castor. (knuckles tilted back 7*)
mvusse Posted September 26, 2010 Posted September 26, 2010 If you did lift the front that may be the cause of it. Front lift pulles the inverted Y steering up, causing toe in. 4.5" front lift gave me 2" tow in, causing DW at speeds as low as 25mph, violently enough to fry my alternator bearings (as well as pop the front panel off the radio, , pop the sun visors out of the clips, throw the change out of the center console cubbies, pencils out of the cubby below the glove box, and fillings out of my teeth.) Reset the toe at 0 and all was well.
skidoo_j Posted September 26, 2010 Author Posted September 26, 2010 everything is tight new u-bolts, new shocks all arround. Just got new u-joints for the driveline, found out that only 1 bolt remained on the transfercase mount. frame appears to be rust free and solid. a bit of rust on driverside floor board that i need to address soon. I did put what should be a 4" lift on the front but it only went up 2.5. Waiting for manufacture to warranty the springs that have less than 300 miles on them. plan to replace lca with adjustable ones. I have a pitman arm drop that's about .66" drop should i put that on? would changing from the Y design to the Knuckle to Knuckle be beneficial? Or would just changing control arms and getting an alignment possibly solve it?
mvusse Posted September 26, 2010 Posted September 26, 2010 Getting an alignment (or at least toe in adjusted) will most likely solve it. Throw the drop pitman arm in the trash.
Pete M Posted September 26, 2010 Posted September 26, 2010 sounds like you have 4" TJ coils up front. :dunno:
skidoo_j Posted September 26, 2010 Author Posted September 26, 2010 rusty's 300 series with 1" spacer... to get 4"
skidoo_j Posted September 26, 2010 Author Posted September 26, 2010 rusty's 300 series with 1" spacer... to get 4" was advised that this combo would be the most like stock in ride
skidoo_j Posted September 29, 2010 Author Posted September 29, 2010 still need an answer for the length of exposed metal on the slip yoke on a stock setup. i'm going to post a pic from tom woods for measuring I'd like this measurement from a stock setup using d35 and 231 w/ swb. I'm thinking my driveline may actually be too long after the d44 conversion doing soa at same time. I calculate that had i done soa on the 35 my driveline would have needed to be 1/4" longer. but the d44 is 1" longer so excluding angles i'm .75 too long correct???
mvusse Posted September 29, 2010 Posted September 29, 2010 All depends on pinion angle. I run a SOA 8.25", which is 1" longer than the stock D35 was, with re-arched springs (1" higher than stock), lift shackles (another ~.75" lift), and a YJ yoke for another 0.5" length. Total lift over stock is ~7". Between the slip yoke and nose of the pumpkin I have an extra 1.5" length. Perfect length drive shaft is ANOTHER 1" longer yet. I highly doubt 4" lift only requires a 0.25" longer drive shaft if ~7" can use 2.5". I think you will be fine.
jimmy21669 Posted September 29, 2010 Posted September 29, 2010 still need an answer for the length of exposed metal on the slip yoke on a stock setup. i'm going to post a pic from tom woods for measuring I'd like this measurement from a stock setup using d35 and 231 w/ swb. I'm thinking my driveline may actually be too long after the d44 conversion doing soa at same time. I calculate that had i done soa on the 35 my driveline would have needed to be 1/4" longer. but the d44 is 1" longer so excluding angles i'm .75 too long correct??? SOA will drop your yoke 4 or more inches from stock and be 1 inch in...if you do the geometry, I believe it will be a wash.
skidoo_j Posted October 6, 2010 Author Posted October 6, 2010 Got my stuff in to fix the front end issues hopefully. Lets see... They put all this and more on in an hour on the TV show trucks, so i figure taking away all the time they spend talking about themselves... I'll have it done in 2 weeks. and yes that is a bottle of crown. I like good stuff while working on the car. Good by death shake in the truck...
skidoo_j Posted October 21, 2010 Author Posted October 21, 2010 HELP!!!!! Death wobble didn't go away need ideas!!!! New control arms, Trac Bar, 4" lift (spring and spacer), new stabilizer, sway bar disconnects. I've done everything i can think of. Got an alignment. but... at 55-65 i start to shake, not as violently as before the control arms and alignment, but still of concern. I'm going to check my wheel balance tomorrow. Any idea???
HellCreek Posted October 21, 2010 Posted October 21, 2010 Have your wheels "Road Force" balanced. It will make a world of difference. If you have replaced all of the front end components, and your alignment is on spec, that should fix your problem. :thumbsup: -Tom
J B Cuz Posted October 21, 2010 Posted October 21, 2010 The biggest cause of death wobble is the track bar being loose at one end or the other. the second is that the track bar and tie rods are no longer aligned due to lifting the truck, but this normally just results in bump steer. J B Cuz
HellCreek Posted October 21, 2010 Posted October 21, 2010 The biggest cause of death wobble is the track bar being loose at one end or the other. the second is that the track bar and tie rods are no longer aligned due to lifting the truck, but this normally just results in bump steer. J B Cuz Yes, JB, but he already replaced his track bar (see picture above), so he eliminated that cause. The only thing left to do is balancing, as far as I can see. :cheers: -Tom
shelbyluvv Posted October 21, 2010 Posted October 21, 2010 I am not seeing new UCAs in that pic. Are you still running stockers? I also see a CRusty's track bar. Take that POS and throw it as far as you can. I fought DW on my WJ for over a month after I put a new CRusty's lift on it. It turned out to be the bushings were too soft in the TB. I put a Rock Krawler TB in it and it cured the DW.
