J B Cuz
Everything posted by J B Cuz
brake lights and dash light fuse
J B Cuz replied to artimus's topic in MJ Tech: Modification and Repairs
I would bet it is Dielectric (spelling ?) grease. It does 2 things, one it keeps water out of the socket, and two it reduces the vibration of the bulb allowing it to live longer. This stuff has been used in semi trucks for years. You can wipe it out with a cotton tipped swab dipped in alcohol or brake cleaner. The stuff can get pretty solid after a few years. J B Cuz -
A short video from March 5. My Comanche is the tan one and the white one is my nephew Scott. Link: J B Cuz
has anyone used Bushwacker fender flares
J B Cuz posted a topic in MJ Tech: Modification and Repairs
I am thinking of putting Bushwacker fender flairs #10912-07 on my 91 short box. I am looking for comments about fit and install. Thanks J B Cuz -
I just sent this to MUDTRUCK87 and then saw the link a thought I should post it for everyone. J B Cuz thanks for resending the e mail. I think I am using what you would call a parallel style. i used the stock front spring mounts and made my own arms from RE builder parts. The mount for the axle with the stinger is made of 1/4 steel and boxed around the nose and pulled back tight using axle bolts. It can be made mostly from 1/4 x 6" flat stock. Other then a band saw you would need a welder and a hole saw. The stinger and mount are made from 1 1/4 dom and scrap I had laying around. By using a long stinger you can control the wheel hope and torque with less strength than a short one. I use about a 6" ride height for every day running, so 8" is not out of the question. view from rear, shows track bar view looking to t case shows end of stinger and mount. Yes that is me view looking to rear side view looking toward pass side The only change I would make is to make the area where the stinger mounts to the body wider so it would spread the load better. Now when changing from forward to reverse I sometimes get a thump noise, due to load change. Any more questions feel free to ask. J B Cuz
1991 MJ short box "Ditto" 160k A work in progress Daily driver in St Paul MN 4.0l, AW4,NP231/with slip yoke eliminator, Front axle: Dana 30 ARB with 4.88 soon to be changed to 4.10 I want better mileage Sway bar: Sway Loc remote air disconect Rear axle: Dana 44 Power trax locker 4.88/4.10 disc brakes Engine: stock with york style on board air Suspension: AiRock 6" kit on front TNT long arms and Rear a custom 4 link with stinger Front bumper: Iron Scorpion welded by me with Warn 8000 winch and X line rope rear bumper: Custom made by me with wrap around protection Nerf bars: custom made by me Tires and rims: BFG mud terrains 255/85R16 on Alcoa rims (33" x 9.5") Bed cover: by Truxedo, Mac,s tie downs inside, Lite Spots and 12v plug in for Engel cooler
Yes you can. At one time I had my MJ, TJ, and Dodge w250 all using the same key. J B Cuz
I tow my TJ behind the MJ quite often. I know I am over the weight in the owners manual. I have a home made trailer made for either the TJ or MJ that weighs 1800#,s. The TJ is 4200# so I am around 1000# over. My MJ is set up with a Dana 44, disc brakes, large transmission cooler, and the hitch is made to use all the factory bolt hole which have been drilled through and have spacers on the inside. The truck is set up with an electric brake controller and when I built the trailer I used extra large brakes for the size. With the brake gain turned up it works fine just stay out of over drive. J B Cuz
Here are some pictures from my club Minnesota TrailRiders event last weekend. We had 2 Comanches show mine and one other. I hope you enjoy them. J B Cuz
forgot the link, J B Cuz
A few pictures and some video of the weekend. We ended up with 34 rigs and 2 comanches J B Cuz
I plan on it this spring. Just have to make time. J B Cuz
It is all a custom build. I used RE builder parts for the arms and bought 2.5" wall DOM. For the stinger I used 1.25x.125 Dom and .250 flat stock. The part around the carrier is .250x6" flat stock cut and welded into shape. I used a whole saw to get the axle tube radius. Does this help you out. Let me know if you need more pics. J B Cuz
A couple of pictures of my air suspension. by using air I can change to pressure to compensate for any load I can get in the bed, or on the trailer. The heaviest was aroud 2800# of oak for the fire place at the farm. J B Cuz
I put my 91 SWB on air bags using home made arms mounted to the spring perch in front and used a stinger from the rear axle to a mount on the body near the transfer case. it is not a bolt in you do have to fab up the arms,mounts, stinger and axle mounts. It rides great and has nice manners on and off road. I see if I can get some pictures up. J B Cuz
My club (Minnesota TrailRiders) and I have been hosting a winter run near River Falls Wisconsin for around 20 years This year I would like to invite the Comanche Club also. I know I will be a ways for most of you, but we have 2 Comanche's in the club now and seeing more at the event would be a hoot. Details The event will be held February 5th from 9:00 tell we get out of the woods. With a group of us going out for pizza and beer afterwards. :cheers: PM me for more details and directions. J B Cuz
I am using TNT's long arm set up. Been running it for over a year now, both on and off road with no problems at all. It handles will on road (my daily driver) and has nice flex off road. J B Cuz
On my 4cyl it mounted to the driver side of the radiator core support with 2 nuts (10mm). J B Cuz
if the motor runs fine at low rpm but dies on the high end it sounds to me like a lack of fuel. The other reason to not look at the plugs is it is running well at low rpm so why would the ignition system only fail at high rpm. Change the fuel filter see if that fixes it. J B Cuz
The biggest cause of death wobble is the track bar being loose at one end or the other. the second is that the track bar and tie rods are no longer aligned due to lifting the truck, but this normally just results in bump steer. J B Cuz
I had a similar problem it turned out to be a corroded main power wire. I cleaned it up and it works like a champ. What you are seeing is the trans default settings for no electric power. J B Cuz
I pulled up the wiring diagram for a 1991 and the aux fan is controlled by the ECU pin #31 DK BLU/PK it goes in the the power distribution center cooling fan relay and controls the ground to turn the fan on and off. After looking at the wiring I think it would be th sensor on the t stat housing that the ECU is using to determine the temp for turning the fan on and off. J B Cuz
I put a hot dog style tank above the passenger side frame rail just under the bed. There is an empty spot there and it is quite protected. J B Cuz
Nut size for transfer case to transmission studs
J B Cuz replied to Rymanrph's topic in MJ Tech: Modification and Repairs
3/8-24 the nut will use a 9/16 wrench J B Cuz -
I have a nice tail gate and all the hardware, I will sell it for $150.00. Send me your e mail and I will forward photos. J B Cuz out of Minnesota
I have a used one from a short bed you can have for 100.00 J B Cuz 763-242-1545
