Automan2164 Posted July 1, 2010 Share Posted July 1, 2010 This month we are in project country, and since we have been watching this one progress... We decided it should be on the pedestal, for a project well done. :cheers: ------ JULY 2010 - Comanche09's 1988 Pioneer ------- MODEL AND YEAR Comanche Pioneer Shortbed 2wd 1988 ENGINE & PERFORMANCE: 4.0L Renix 1997 XJ Valve Cover 1997 XJ Oil Pan Mechanical Oil Pressure Gauge with shutoff valve Shell Rotella T 5w-40 Synthetic Oil DRIVETRAIN: 1997 XJ HP D30 Front Axle 3.55 Gears 1990 XJ AX-15 1995 XJ AX-15 External Slave Bellhousing 1998 XJ NP242 Selec-Trac 1998 XJ 8.25 29 Spline Rear Axle with Trac-Loc LSD 3.55 Gears Amsoil 75w-90 Oil in Diffs Redline MT-90 in Trans Mobil 1 ATF in Tcase COOLING: Open Cooling Conversion w/Single Core Radiator 1995 Suzuki Sidekick Coolant Bottle 1996 XJ Electric Fan Selectable (On/Off) Electric Fan Switch Mod 1995 Ford Explorer Power Steering Cooler ELECTRICAL & IGNITION: 5-90 Power/Ground/Alt/Starter Cable Kit GM Interior Rear View Mirror w/Maplights 1987 XJ Limited Old School Font Full Gauge Cluster Floor Lights, Ashtray Light STEERING: V8 ZJ Tie Rod SUSPENSION: Rough Country Adjustable Track Bar 2" Front Spring Spacers 1998 XJ Upcountry Front Springs Adjustable Lower Control Arms w/Rubber Bushings 1999 WJ Upper Control Arms Motion Offroad 3" Lift Leaf Springs Modified 2000 Dodge Dakota Spring Plates and U-bolts 1995 YJ Monroe Front Shocks 1993 Toyota T100 4x4 Monroe Rear Shocks INTERIOR: 1987 MJ All Black Interior 1997 XJ Black Door Panels 2007 Mitsubishi Raider Split Bench Seat BRAKES: 1995 XJ Dual Diapham Brake Booster Upgrade 1995 YJ Front Brake Hoses 1995 Dodge Dakota Rear Brake Hose Load Sensing Valve Eliminated LIGHTING: Stock 1997 XJ up Front Stock 1988 MJ in Rear LED Brake/Turn Signal Strip WHEELS/TIRES: 1999 XJ 5-spoke Charcoal Wheels 31/10.5/15 BF Goodrich All-Terrain T/A MISCELLANEOUS: 1997 XJ Front Clip and Door Swap Herculiner Bedliner Hi-Country Offroad Extreme front D-Ring kit U-Haul Class III Hitch 1995 XJ One-Piece Rubber Windshield Surround Best MJ story Being selected Comanche of the Month! And it being July 2010 would be on my one year anniversary (bought her July 4, 2009) :USAflag: What owner loves best about CC It is a great source of information for Comanche enthusiasts and the people in the club are very friendly, helpful and knowledgable. :cheers: That's one nice looking put together truck. :D Its been a great time being able to watch the small touches, and the way things have come together. I must say, as well as the other mods, love the tasteful things you've done to make this truck updated, but not overdone. So, I'll be the first to say congratulations, and welcome into the Comanche of the Month spotlight. Well done. :cheers: Rob L. :D Link to comment Share on other sites More sharing options...
freakjeep93 Posted July 1, 2010 Share Posted July 1, 2010 congrats nice truck Link to comment Share on other sites More sharing options...
ben3G Posted July 1, 2010 Share Posted July 1, 2010 nice truck it has a very clean look to it :cheers: Link to comment Share on other sites More sharing options...
comanche13 Posted July 2, 2010 Share Posted July 2, 2010 comanche09 that means I'm 4th in line :brows: but seriously nice truck always have liked the newer clips on the comanche great work BTW did you run into problems with the passenger door hitting your glove box? I thought I read that it hits somewhere? Link to comment Share on other sites More sharing options...
jpnjim Posted July 2, 2010 Share Posted July 2, 2010 :cheers: :thumbsup: :thumbsup: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted July 2, 2010 Share Posted July 2, 2010 Congratulations!! Yours is a nice clean build, I very much like the 'modern' look and the subtle little upgrades! GOOD JOB!! CW Link to comment Share on other sites More sharing options...
Wildman Posted July 3, 2010 Share Posted July 3, 2010 Congrats 09 on your COTM :clapping: Nice looking "Newer" Stock Comanche :yes: It's great that you got that all put together in a year time :thumbsup: I really like that Silver color too :banana: Link to comment Share on other sites More sharing options...
Darren Posted July 3, 2010 Share Posted July 3, 2010 Congratulations man. Real nice truck, clean and simple. I'd love to have an MJ just like that one for a daily driver, and for picking up chicks. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 3, 2010 Share Posted July 3, 2010 Congrats Matt. Lots of quality work in a short timeframe shows you are a dedicated MJ lover and a valued CC Forum member. I like the way you have shared your experiences both good and bad with the forum and created a very clean looking and unique rig. And I'm sure there is much more to come. These things are never done. :cheers: Link to comment Share on other sites More sharing options...
DJM/78 Posted July 3, 2010 Share Posted July 3, 2010 Its looking real good , congrats !! Link to comment Share on other sites More sharing options...
87Warrior Posted July 3, 2010 Share Posted July 3, 2010 Your truck is a beautiful machine. You should be very proud of that truck. :cheers: Link to comment Share on other sites More sharing options...
centralnc Posted July 4, 2010 Share Posted July 4, 2010 Fantastic Build. I really like the color. This obviously took a lot of time and patience. Congratulations on MJOTM!! Link to comment Share on other sites More sharing options...
whowey Posted July 5, 2010 Share Posted July 5, 2010 Very nice. I really like the use of all of the stock parts from various sources rather than an overload of aftermarket stuff. Link to comment Share on other sites More sharing options...
WBKrazy Posted July 5, 2010 Share Posted July 5, 2010 congrats! very clean mj Link to comment Share on other sites More sharing options...
comanche09 Posted July 5, 2010 Share Posted July 5, 2010 Hey All, Thank you for kind words! :cheers: I've really enjoyed reading and looking and looking and reading again :dunce: about all the other builds/experiences on here. It has made my buildup/resto relatively painless; alot of work, but worth it. :USAflag: BTW did you run into problems with the passenger door hitting your glove box? I thought I read that it hits somewhere? If you use the door panel with power windows, the switch part will interfere with the glove box door. I used manual window panels and have no clearance issues. :thumbsup: Link to comment Share on other sites More sharing options...
Rymanrph Posted July 7, 2010 Share Posted July 7, 2010 If you use the door panel with power windows, the switch part will interfere with the glove box door. I used manual window panels and have no clearance issues. :thumbsup: I wonder how you get around that. I've seen the write ups on the door striker swap; how difficult was it to do? By the way, nice truck. Link to comment Share on other sites More sharing options...
buxmj Posted July 8, 2010 Share Posted July 8, 2010 Congratulations, nice truck. Unbelievable work in just one year. Inspiration for me, thanks! Link to comment Share on other sites More sharing options...
Bandit240 Posted July 8, 2010 Share Posted July 8, 2010 This is just what i want to do with my truck as far as the body goes. I'm keeping an eye out for a rear ended 97+ XJ. They look so modern with the updated front end. Link to comment Share on other sites More sharing options...
