random informative picture thread
  • 1 month later...
  • Replies 100
If it's a TBI 2.5 instead of MPFI, the pump will only put out 14-15psi btw.
Correct... 91+ 2.5 and 4.0 pumps are the same.
I live in a Renix era world. :D
Off topic, your new avatar cracks me up. Looks like the kid from the online stock trading commercials. :yes:
:cheers:
:cheers:
Yep, just figured I'd save some poor sap from the annoyance and headscratching that results from swapping a new engine in and having it run like crap because the fuel pump isn't feeding it enough, right off the bat :hmm: :thumbsup:
:cheers:
Yeah, I slapped the hat on her, and she liked it so much I had to take a picture.
I'd love to comment on your avatar... but.. :shake:
Just found this thread and it is great!
Can some of you post the stock position for the bottle jack, lug nut wrench and spare tire winch tool?
My 91 base model had only bare sheet metal at the back of the cab. Found a good rear cab cover at a salvage yard. BUT not sure how to mate it to the back of the cab and keep the bottle jack in place. Help Please!
  • 5 weeks later...
I just learned that actually... opened up the d35 someone gave me for spare parts and went "huh... that isn't a normal carrier!"
Now I'm tempted to keep my d35 and stick the trak-loc in it instead of upgrading to the 8.25 that I have waiting :(
  • 3 months later...
connector No. locations
Connector C100: Left Of Master Cylinder On Dash
Connector C101: Above Master Cylinder
Connector C102: Behind LH Headlamp
Connector C103: Next To RH Shock Tower
Connector C104: Next To RH Shock Tower
Connector C105: Behind Battery
Connector C106: Next To RH Shock Tower
Connector C107: Next To RH Shock Tower
Connector C108: In Front Of Washer Bottle
Connector C109: Next To RH Shock Tower
Connector C110: RH Rear Of Rocker Cover
Connector C111: RH Rear Of Rocker Cover
Connector C112: RH Rear Of Rocker Cover
Connector C113: RH Rear Of Rocker Cover
Connector C114: RH Rear Of Rocker Cover
Connector C115: Under Dash To Right Of Steering
Column
Connector C116: Above Master Cylinder
Connector C117: In Front Of Washer Bottle
Connector C118: Under LH Side Of I/P Behind Kick
Panel
Connector C119: Under LH Side Of I/P Behind
Kick Panel
Connector C120: Behind A/C Mode Select Switch
Connector C121: Under LH Side Of I/P Behind
Kick Panel
Connector C122: Under RH Side Of I/P Behind
Kick Panel
Connector C123: Under RH Side Of I/P Behind
Kick Panel
Connector C124: Under LH Side Of I/P Behind
Kick Panel
Connector C125: Under LH Side Of I/P At Kick
Panel
Connector C126: Behind LH Rear Inner Fender
Panel
Connector C127: Behind LH Rear Inner Fender
Panel
Connector C128: Under RH Side Of I/P At Kick
Panel
Connector C129: Behind RH Kick Panel
Connector C130: Under LH Side Of I/P At Kick
Panel
Connector C131: Under LH Side Of I/P At Kick
Panel
Connector C132: Under LH Side Of I/P At Kick
Panel
Connector C133: Under LH Side Of I/P At Kick
Panel
Connector C134: Under RH Side Of I/P At Kick
Panel
Connector C135: Under RH Side Of I/P At Kick
Panel
Connector C136: Under RH Side Of I/P At Kick
Panel
Connector C137: Under RH Side Of I/P At Kick
Panel
Connector C138: Under Front Seat
Connector C139: LH Rear Inner Fender Panel
Connector C140: Behind LH Rear Inner Fender
Panel
Connector C141: Behind LH Rear Inner Fender
Panel
Connector C142: Behind LH Rear Inner Fender
Panel
Connector C143: Behind LH Rear Inner Fender
Panel
Connector C144: Behind LH Rear Inner Fender
Panel
Connector C145: Behind LH Rear Inner Fender
Panel
Connector C146: Behind LH Rear Inner Fender
Panel
Connector C147: Behind RH Rear Inner Fender
Panel
Connector C148: In Console
Connector C149: In LH Side Of Liftgate
Connector C150: In LH Side Of Liftgate
Connector C151: In LH Side Of Liftgate
Connector C152: Behind A/C Mode Switch
Connector C153: Near Cargo Lamp
Connector C154: Above Transfer Case
Connector C155: Behind RH Kick Panel
Connector C156: Under I/P On Steering Column
Connector C157: Below LH Side Of I/P Above
Parking Brake
Connector C158: Rear Center Of Cab Under
Carpet
Connector C159: Behind LH Rear Tail Lamp
Assembly
Connector C160: Behind LH Rear Inner Fender
Panel
Connector C161: At Rear Bumper
Connector C162: At Rear Bumper
Connector C168: Top Of Washer Bottle
Connector C169: Below Washer Bottle
Connector C170: LH Side Of Cowl Panel Grille
Connector C171: To Left Of Steering Column
Connector C172: In Driver's Seatbelt Buckle
Connector C173: Under RH Front Seat
Connector C174: Under LH Front Seat
Connector C175: Behind RH Headlamp
Connector C176: On Left Of Steering Column
Connector C177: LH Side Of I/P Next To Light
Switch
Connector C178: LH Side Of I/P Next To Light
Switch
Connector C179: Behind RH Side Of I/P
Connector C180: At Speaker
Connector C181: At Speaker
Connector C182: At Speaker
Connector C183: At Speaker
Connector C184: At Speaker
Connector C185: At Speaker
Connector C186: In Center Of I/P
Connector C187: In Center Of I/P
Connector C188: Below I/P Behind Defogger
Relay
Connector C189: In LH Side Of Console
Connector C190: Under LH Side Of I/P At Kick
Panel
Connector C191: Under RH Side Of I/P At Kick
Panel
Connector C192: Taped To Harness Above Fuse
Block
Connector C193: Behind Center Of I/P Below
Lighter
Connector C194: On I/P To Right Of Steering
Column
Connector C195: Below Washer Bottle
Connector C196: Center Of Liftgate
Connector C197: Center Of Liftgate
Connector C198: On I/P To Right Of Steering
Column
Connector C199: In Driver's Seatbelt Buckle
Connector C200: Under I/P To Right Of Steering
Column
COMANCHE
Connector C100: In LH Dash Panel Forward Of
Fuse Panel
Connector C101: Behind LH Headlamps
Connector C103: RH Side Rear Of Engine
Connector C108: Near A/C Compressor
Connector C109 (Diesel Engine): Near Lower
Center RH Inner Fender Panel
Connector C109 (Gasoline Engine): Near A/C
Compressor
Connector C112: Behind Battery Near Starter
Relay
Connector C115: Taped To Engine Harness
Behind Cruise Servo
Connector C119: LH Side Of Engine Near Glow
Plugs
Connector C120: LH Side Of Engine Near Glow
Plugs
Connector C200: Under LH Side Of I/P Behind LH
Kick Panel
Connector C202: Under LH Side Of I/P Behind LH
Kick Panel
Connector C203: Under LH Side Of I/P Near
Ignition Switch
Connector C204: Behind Mode Select Switch
Connector C205: Under RH Side Of I/P Behind
Kick Panel
Connector C207: Under I/P Above Brake Pedal On
Steering Column
Connector C209: Under RH Side Of I/P At Kick
Panel
Connector C210: Near RH Door Jamb Switch
Connector C211: To Left Of Steering Column
Connector C314: In RH Side Of Liftgate
Connector C315: In LH Side Of Liftgate
Connector C402: Under LH Side Of I/P At Kick
Panel
Connector C404: Under RH Side Of I/P At Kick
Panel
  • 4 months later...
  • 3 weeks later...
I for one can't thank each of you who have contributed all these great schemes and photos.
I am not new to wrench turning, but I am to Comanches and all these vacuum lines.
Mine ran fine, till a few weeks ago.
I started it and it was chugging and fuming...couldn't even get it out the driveway.
I shut it off and let it sit as I had to the airport to attend a family member's funeral.
Once I returned, about two weeks later I tried it again and it turned over but would not start.
I've been taking with some other great folks here and trying there suggestions, but still a no-go.
I could really use some pics of things like the cps. It's supposed to be on the driver's side of the bell housing,
but for the life of me I cannot find anything there.
Also which is best manual for these buggies...?
Looks like I'm running out of room on this...so thanks again...Ron
  • Pete M pinned this topic
