Everything posted by deziped
Instrment cluster swap with a twist.
deziped replied to johnj92131's topic in MJ Tech: Modification and Repairs
No - Just aligned it in same position it was sitting in prior to removal and pressed it on firmly -
I used needle nose pliers, but, lots of things will work. Just get something behind the needle that will apply even pressure all around on the back side of the needle as close to the post as you can get and pull straight out. It should pop off. Be careful as the needle bends as easy as snot. Any ways thats how mine came off. -
Some of those spoilers would give you a wind resistance wheelie at idle, and some probally brake as effectively as brake flaps on a 747. But de be cooooool. :popcorn:
Changed the track bar bushing. Steering improved much. Removed old one by quartering it. Image Not Found Tools needed for this work bench job. Image Not Found Pounded it out with 1 1/8 socket Image Not Found New bushing ready to go. Image Not Found
I won 750,000 GBP!!!! (British Pounds) What should I do????
deziped replied to dfreeman616's topic in The Pub
Hey I got one of those a week ago and didn't reply. You must have been reselected to replace me. :doh: -
The ol Hwy 242, what a blast. It was hard to wait for that to open in Summer. Loved to run it in my RX7's (fat tires, stiff susp) & pegged RPM's or the Z (7's handled better but Z had the power edge), talk about drifting. Make yuh sh--- your pants with the ocassional boulder in the road and no guard rails & 2 way trfc on a skinny road. Actually enjoyed goin up it more than down. Got to where if I mentioned taking a drive on 242 the wife wouldn't even get in the car. Well those days are gone now. But, if you ever try it stop on top for the view of the mountains. On a clear day you can see Mt Shasta (14162) in CA all the way to Mt Rainier (14, 810) in WA & all Mt's in between.
Air-less works about as crappy as oil-less. I'll just blame that comment on yesterdays radiation treatment. Their getting pretty close to the jewels now, makes me nervous. :nuts:
I have a 5hp 60 gal presser. I have it bolted to a small pallet as I found it quiter than when sitting on/bolted to concrete floor and it still remains semi portable if needed outside the shop. But with a 50' hose I haven't had to move it yet. No more waiting for air to build up when using grinders or painting. Man was that frustrating with those airleess pieces of crap. And yes, airless ones are loud, inefficient, and wearout quickly.
Vac leak maybe. Check the vac line off the back side of the throttle body that runs up to the MAP/MAF on the firewall. Mine didn't fit tight at either end and caused the same symptons you describe. Possibility :dunno:
It's programmed that way, shifts to 2nd at 4300 - 4800 RPM. when in 1-2 position. Put a switch in it & then you decide when it goes into 2nd. When in town I put it in 1-2 position & leave it there. Have much better control of gear selection with flip of the switch.
Wahoo, while your on this subj. do you happen to know what the diameter is of the trac bar axle bracket OEM bolt? The hole on mine is now oval shaped. I measured the OEM bolt at .383" (9.728mm). Possibly when new it was a 10mm or 3/8"? :dunno:
S---- it up to 2.81 tonight. Sure gonna be over 3 by July 4th. :fs1:
Warning for all Montanan's, Clear the Streets tonight. :yes: :yes:
I'v got the sensors on my door, but, they ain't worth a darn unless your in the garage & near the door when someone else hits the button. Although I have on ocassion thrown a tool along the floor & out the door in attempts to reverse the door. :dunce:
I learned years ago never to park partially under an open garage door. Did it once and the wife comes home drives in beside my truck and paying no attention hits the button. It neatly put a crack in the center of my canopy. Was it her fault, oh hell no, I was stupid for parking there. GRrrrrrr. Oh well I got even just a couple months ago when I backed out an nailed her caddy. Tee-hee.
Friend offered to build (free) a down-sized version of this bumper for my mj using 4x2 tube covered in D Plate. The inner base for this one is 6 x 6 x 1/4 tube covered by 1/8 diamond plate. Nice cornering lights that can also be lit up full time on the back roads when your out looking for that deer. Says it only dropped his MPG by 1. I think maybe it might be a bit of over-kill for the MJ. Oh well, I'll go play in his shop & see what happens. Image Not Found
The humor on here is just another incentive in favor of this forum. There's a witty group on here for sure and you never no what to expect. :brows:
Well in an hour I'm off to have the ol prostate gland radiated :banana:. Hope their aim is good so the nuts don't get fried :hmm: , I think their already dead. Out of 12 biopsies 6 came back pos (+) cancer with a rating of 7 on severity scale of 1 to 10. Five days a week for the next 5 weeks ( there goes the Summer) and hope that takes care of it. They say its a painless treatment, if they don't screw up. Oh well, I needed to replace a front axle seal on the MJ, appears I'm going to have a lot of time to get it done now between ZZZzzzzzzzzzz's.
I'm going to be in Baker City area in a couple days (21st to 25th). Get time I'll check it out. Gotta remember to take my camera. I'm primarily headed to the Blue Mt's area for vaction with family & friends. Some of the best elk country around, if I see any I'll snap a pic or 2.
Looks similiar to some British military haulers I've seen.
Naches, well thats a good 800 mile round trip from here. Pretty long drive for a Sat- Sun & be back to work Mon AM. Guy would need to go on a vacation for that one. But, you all have fun, thats a beautiful area this time of year.
No chicken pics on the wall. Dogs in the house, no chickenss. Looks like a lil discrimination goin on here. :no:
How about somewhere around Eugene?
