CEThomas
Everything posted by CEThomas
  1. You will need to boost fuel delivery, at the end of the day your ECM / Renix fuel delivery will be the same :cry: You will be feeding more engine on the same amount of fuel ;) Play around with some larger injectors to try to boost fuel delivery and you will start making that 2.5 work :cheers: Charles
  2. Trying to get the drive train in by this weekend so we can get ready to paint while we save up $$$ for the next items :D 1. Need to know what size bolts holds the bellhousing to the 4.0 HO? I have the 2 large (long) bolts but need the size of the small ones. 2. Need the size of the tork converter to flywheel bolts. 3. What size bolts hold the AW-4 to the mount. Thanks Charles
  3. What rims are you going to put on the 33x12.50? Charles
  4. My son and I will make it :D Not sure about the MJ yet, lot to do yet :cry: but we will bring my Ranger if it's not ready and be ready to wheel :cheers:
  5. They are not like power steering lines and the high pressure line can kill you if not done right.
  6. Shop around and find items that will plug in play. I would stay with Jeep items to make it easy. Try to find a/c lines that you can make work as custom will cost a lot to have made custom. Charles
  7. Say OVER FLOW :cheers: Charles
  8. You will need a vacum pump that can pull down to 29.8 bars. Best would find a ele. pump and build your own ;) You can gat an air operated one from Harbor Freight for around $15 but it's and air hog. My 60 gal Kobalt compressor will over heat trying to keep up with it :eek: If you do you water tank test you should pull the vacum for about 8-10 hrs to make sure you have ALL the most air out of the system so it will not ice up. Charles
  9. At some point I will have to change my Ranger and Capri from R-12 to 134 :cry: Thursday I have to look at my daughters car. The PO done a R-12 to R-134 and now it's not working :mad: And the ZJ which has been a pain in my @$$ for the bast 2 years. Charles
  10. Just a FYI the Chrysler evaporator is / has been the weak link in the system. If you try your water test might as well try it on the evaporator and see if you have any luck, it will let you know if you have any large holes. Charles
  11. What do you need to test?? You can not test any one item, well you could x-ray it, but you will need to put the system in the truck and vac the system and do a vac test around 29 bars for 24hrs. If you drop and vac at all you will need to pressure the system and dye it to find the leak. Charles
  12. CEThomas
    Gas Prices?
    How much will it help on a MJ? Out of all the trucks I have had only had 2 that a bedcover or no tailgate ever helped. Did nothing for my Dakota but was good for about 3mpg on the Ram :nuts: Charles
  13. Thanks, I thought the price was right on the compressor :D Charles
  14. I have a choice to make and not sure which way to go :nuts: I need to get a A/C buypass pulley or an A/C compressor. I see a buypass pully over on NAXJA for 25 shipped or I can go to the local Pick - N - Pull and get a compressor off a XJ for $25 :roll: What would I need to set the compressor up for onboard air, is it worth it, and any compressor work?
  15. Thanks, Will give it a try w/o first :D
  16. With a SOA how many use a T-case drop bracket? Just wondering if I should get one prior to sticking everything back in. Charles
  17. Thanks, Was starting to worry :D Charles
  18. I need all 6 /8 nuts that holds it onto the trany. They are a M10 x 1.25 :eek: Most M-10 nuts / bolts have a different thread count. I have been to 2 fastener supply locations, and have been told try the dealer or maybe another fastener supply house in Columbus that has a large metric supply of nuts/ bolts :bowdown: Charles
  19. Where do you get your t-case Nuts to mount the T-case to the traney. I jsut checked a couple locations and they do not carry anything :cry: Charles
  20. Got some on the way. Thanks Mudrunt :D Charles
  21. What size are the torque converter bolts on a 4.0?? Charles Yes, I know was getting a ax-15 but ended up going auto :roll:
  22. Black it is :D Charles
