3
Everything posted by 88whitemanche
88Whitemanche's 98 Cherokee Build
88whitemanche replied to 88whitemanche's topic in Member Projects: Other Cool Stuff
Been a busy week with the cherokee...did the valve cover gasket, got some manual door regulators, installed one side because my passenger side panel broke while removal...smh...and also picked up those vent windows for the rear.... Direct swap...loving it for that reason... Valve cover gasket... Got lucky these didn't break flush...had 3 of them break like this some even closer... Quarter vent windows...will get installed pics later... Mock up.... -
Seattle all day!!! Those cheating phonies!!!! Plus I hate them because their in the same division of the dolphins...yes yes they suck but I hate the pats....
It happens so fast I don't realize the radio is on...but when it does come back on the radio is on/everything works as usual...
I assume just everything when it shuts off for a split second.... But you mean after it backfires? No...everything runs like butter after...it's hard to repeat the same symptoms back to back...luckily I've been able to go home and switch trucks after a week of dd driving.... I leave it parked because I'm afraid for an accident when it's shuts off while I'm in the middle of the hwy doing 70
It's only happened doing 70mph on the hwy and the shutoff is a true split second and it'll start back up by itself and run flawlessly after... You don't even have time to realize to Pop the clutch/pull over to the side or anything....just you feel a sudden loss/ loan down at gauges/ backfire and rpm back to normal in speed at 70mph.... No it doesn't do it at idle In the driveway...sometimes out on the street....cps is clear from the exhaust manifold...
Well fellas it's not the catalytic converter... I went to remove it and it's been hollowed out... So it must be something else.... Anyone has a clue what it could be?
89 Southern Mj: First Jeep
88whitemanche replied to xjustinx's topic in Member Projects: Your Comanches
Sweet CLEAN rig man...loving the build -
Sneaky sneaky! Loving that color though....
Next time you don't even need to needle nose pliers just simply peel the bottom part of the panel enough so you can push the window up.... I got the same issue I know it to the point that just a few full turns and it's at the point I can still roll the window back up...
Hard to start when at operating temperature
88whitemanche replied to Rohls's topic in MJ Tech: Modification and Repairs
What is your cps output?- 19 replies
- hard start
- hot
(and 1 more)
Tagged with:
Trucks with no carpet or vinyl floor look here
88whitemanche replied to xjrev10's topic in MJ Tech: Modification and Repairs
I'm liking the idea...this wouldve worked when I didn't have vinyl...it would move with every shift... -
Finally got my hands on one!
88whitemanche replied to Comangi's topic in Member Projects: Your Comanches
Congrats...the motor looks to be the same year 4cyl... And the console is from an xj... -
'86 Commuter/Weekend Warrior
88whitemanche replied to JeepsOLot's topic in Member Projects: Your Comanches
So.... You didn't pick up that ax15 yet?.... -
My idea on homemade pre96 np231 SYE
88whitemanche replied to Herada12's topic in MJ Tech: Modification and Repairs
IIRC You don't need a sye for an SOA...unless your at 7+ Inches of lift -
Future beast mode? ...dana 30 lokka came in...I picked this one for the front because it's not going to be used often...so less wear and tear....
By itself...
No...it only happens on the hwy at70mph....more concern about not crashing/ someone crashing into me/ get out safely....
Anyone?
Build is looking great willy... So....I know many of us are wondering...are you going to build this one similar to your wife's mj or a mild wheeler/ daily driver?
Tylers Daily 4X4 Build
88whitemanche replied to Comanchel0ver's topic in Member Projects: Your Comanches
Looks great I've been wanting to do this mod for a while now..... What fans did you use? Also what switch or fan controller are you using for this swap?- 99 replies
- camanche
- daily driver
(and 3 more)
Tagged with:
Yeah it looks like it... I'm going to go look at it today but I think that was just a shadow of a few dents that are on the bed...
Also buddy of mine plasti-dipped his comanche looks like mine it's scary lol....
Well since I've been trying to fix certain things like the obvious electric window regulators...which sucks because I went to 5 yards and all had about 9-11 96- 2 doors what a tease!!!!! But I happen to pull a few stocks skids...engine and transfer case and will look for the zj skid for the gas tank... So far it's been running flawlessly except it's due for a new clutch and got a low oil pressure issue which I think it's just the sending unit.... -
Well I've been hounding down ocs for my two door...I happen to find a cherokee with an ax15... But I caught it late and I drove 2 hours up to look for pcs and only found it with only 30mins left before the yard closes...but I did get some stuff for the cherokee and an ax15 crossmember for my swap...
