DirtyComanche
    11
  1. Coils are exactly the same... But hey, a couple cutting board from welk-mart and way the heck too much time can make some nice spacers. Or there's always the junkyard.
  2. Yeah. But it came out of a god-knows-what. Doubt it's the linkage, it's in gear, just slipping like a mother. It was still creeping foreward barely when I gave up on it. Oh, reverse seemed to be going too, like it felt weak. So, clutch packs or valve body, either way I think it's time I pushed this thing off a cliff. Or get another pink'n'pull special.
  3. Not the one in my MJ; I already know it is a peice of $#!&. But, the th-200 in my cutlass seems to have died. It was slipping a bit, I checked the fluid, seemed low, topped it up. Then it was slipping bad... Now I have no foreward gears, but I have reverse. It went from being fine when I parked it last week to dying in a matter of miles on monday when I needed to drive it. Ideas? So, the DD is dead again. Ohwell. I can walk.
  4. Lifts never really give advertised height. Brand new coils/leafs tend to have a couple more inches in them than advertised. Sometimes they'll settle down, sometimes they won't. The only thing that will actually give you exactly advertised lift is spacers/blocks. That and if you lighten up your rig, or weigh it down, things will change. And you have to factor in that your stock springs might have already been sagged, or in the case of the 2wd vehicles, not as tall.
  5. I have a 4.0 and my exhaust ends just by the tranny mount... I like the sound. Annoying as hell on the highway.
  6. I thoguth about it. Then I remembered how it was -40 here last winter. Now, let's add a wind chill to that... No thanks.
  7. How about the bedliner all over the whole thing look?
  8. Just because we're talking about caps, I'll throw out there that I've got a light blue one for a shortbox, and it's free if you pick it up. I don't have a bed anymore, so yeah... Not that anybody will.
  9. No sense getting an 86-89 5spd donor (w/4.0) as you're going to wind up having to get a new tranny later... Best to do it right the first time. Psst - You don't need a lift to run 31s
  10. Holy moly! You used RED Loc-Tite? What'cha gonna do when you need to change a hub/bearing unit, or replace the rear brake shoes? I think I would have started with purple, and maybe progressed up to blue if the purple didn't work. I don't use red on anything. Heat. That stuff breaks down at a fairly low temperature. Even a propane torch will do it.
  11. I've got a set of doors that I'm going to do that too... Someday.
  12. Which ZJ coils? There's 3~ different types. I think that the I6 versions will actually drop you an inch, if anything. The V8 versions are supposed to be 1" lift. I think they also have an 'up-country' option for ZJs, which would give you 2". I don't remember for sure. Did you take the stock coil isolators as well? You can stack them with the ones you've got and get a bit more lift. XJ 'up-country' coils are only an inch. I think.
  13. Springs are quality. As I said, only their in-house stuff is crap. The springs are made by somebody else. Their OLD rear leaf packs liked to sag, but that was a couple years ago so unless you're buying used it'll never be a problem (those were for XJs/YJs anyways, not like you'd be using them). But anything made in-house is buyer beware.
  14. You have 4.10s alright. Most 2.5s got them... Anywho, can I ask what those coils are out of? Variable rate coils are NOT a Jeep thing. If you ask me they look suspiciously like the coils ouit of a Ford thunderbird, mustang, or such... Look at the top coil and see if it is the exact same diameter as the Jeep ones. Anyways, if they are what I think they are they'll give you 3" or so of lift. Depending on exactly what car they came out of, and what options (engine) it had. But only one way to know. (They'll ride kinda odd too, but apparently not bad, the whole variable rate thing) Now that I look at them again I swear that they're Ford car coils. They don't look as long as the V8 (really stiff) versions, so you might be lucky... You'll have to modify the top bucket/bumpstop area when you use them, or they'll make a clunking noise as they move around. As I said, throw 'em in and see. Coil swap only takes a few minutes.
  15. Pat prefers to find out about the rocks by driving into them... Best place would be inside the wheel wells, near the back/top if you can find the space. The lower you mount them the more likely it is that they'll get f'd. There's not really much else in the way of options, unless you like cutting metal...
  16. Yeah, Rusty's offroad. Just generally really crappy product. Design, quality, etc. Left me feeling empty inside, and spending a lot of money to do it a different way... That's for their long arms. I feel the same towards anything else they make in house. I'd elaborate, but only if you really need convincing that they suck.
  17. Oh, that's your solution to everything! :D Nah, my solution to everything involves a sledgehammer.
  18. I think if your leafs flex past the point where the overload would be hampering them, they're being overflexed anyways.
  19. Oh, definatly going to agree there. And while you're at it take the bed off.
  20. Personally I'd not tow with a MJ/XJ. They just don't weigh enough. Sure, you could get away with one of those little trailers, or relativly light things. But anything heavy and the tail will wag the dog. Especially if you've got a shortbox. That and MJ/XJ brakes aren't exactly great...
  21. Pete, you could always get some ZJ control arms, at least I think it's the ZJ ones. They are the same length, but have a bend in them to prevent tire rub. Pick'n'pull - $5.
  22. Stock skids are just too thin. I had one of those steering skid thingos on there, and jeeze, one little rock and it's bent way the hell weird.
  23. Ditto on the aftermarket ones. Summit universal seat brackets, and some comfy mastercraft seats and life is dandy. But I never follow my own advice. I've got a 2dr seat on the drivers side, it's offset towards the center for some reason (it's on the MJ bench brackets) and I think I'm going to build all new brackets for it as it's all f'd and really not comfortable. I mean, I found it uncomfortable sitting in it putting the dash back together, I haven't even driven it. I put it in to replace a 4dr cherokee seat (passanger seat is still that) that somebody had busted and welded back together at a funny angle. Maybe I'll jsut go to pick'n'pull and get another seat. But I like the folkd foreward thing. It was inconvenient unbolting the seats to put things behind them.
  24. Rear axle matters too, the pinon length on the D44 is somewhat more than the D35, and I have no idea about the AMC 20. At least, I THINK it matters. They might have used the same shafts.
  25. Shortbed with BA-10/5 and NP231 is 43.5" Ujoint center to center. I THINK. I measured it a bloody long time ago. It's still outside if you want me to throw the tape on it... Now, if you want a 45~" driveshaft, look a 2nd gen camaro (let's say 72-81, I think) and you'll probably have a 45~" driveshaft. Not sure on what engine/trans/rear it had, but I have a feeling it was just a V6 auto. Pretty certain it had 1310 Joints too. Certain shortbed fords would also be close, based on my junkyard measurements.
