11
Oh yeah, you can go front leaf springs relatively easily. You'll have to build a new front x-member to hold shackles. But it's easier than making the 5-link garbage work. (Sorry if I seem screwed, I'm still drunk from last night)
It all depends on your idea of easy too... Can you weld? Anyways, you can dump money into the D30, but if you're going to go larger than 33's, it does NOT make sense. I learned an interesting thing yesterday, 297X (half-ton Ujoint) shafts share the same ears as 260X (1/4 ton Ujoints), so while the 297X is stronger, it's not by much as you break the ears instead of the ujoint. When I say share the same ears, they are the same other than the 297X style has a larger hole (making it even weaker). I think I'm going to just carry a bazillion 260X shafts and start saving my pennies.
How much spare time do you have, and how deep are your pockets? Just Empty Every Pocket Eh? Otherwise, if you want a 'manche, go for it. Never hurts to look, haggle, and then walk away if nothing else. Make sure you get a good look under it, check all the fluids, and give it a test spin if possible.
Looks good. You might want to hack some sheetmetal now, too. And what the heck sort of truck is in the background?
I'm at 6.5", sits closer to 8" I think. Clears alright. I did quite a bit of hacking. Just make sure you get rims with little enough BS. Oh, please tell me you've contemplaited the consequences of such a tire on stock axles.
I lost my charger for my camera, but... There's a ground inside the driver's side tailight. And that's the only one I know of. I'll flip through the FSM.
new to manual trannys question
DirtyComanche replied to Oizarod115's topic in MJ Tech: Modification and Repairs
My BA10/5 was replaced in '96, so maybe it'll last a little while longer... But whenever I'm at pick'n'pull, I look. -
Don't worry about it. I taught a girl how to drive standard on my BA10/5, and I actually wheeled it for quite a while. It's noisy, but hasn't exploded yet. (I'm gonna go knock on some wood) -
ITS FINALLY DONE!!
DirtyComanche replied to 88swampedmj's topic in MJ Tech: Modification and Repairs
The only bent arm radius setup out there is the TNT one, I think. And it ain't gonna fit. Realistically I've jsut got too much BS because I bought the AR-767s instead of finding something else. Anyways, I'll admit that the rusty's crap was a mistake. However, I think I can farther modify it to suit my needs. 4 bends and a new X-memeber (which I was going to do anyways, as the rusty's one is retarded) and it would be golden. Although, that might get tricky with where the UCA mounts are on the LCAs. Hmm. Okay, I should just get fullwidths. -
ITS FINALLY DONE!!
That makes sense... I think I might get some half inch spacers and longer studs for my front. 4.5" BS with a 8" rim and 12.5 wide tire just doesn't work. Well, it works in a straight line. Wait, how about I say "@#$% rusty's" because all it rubs is the control arms, which could have just as easily been bent. Oh hell how I hate that kit. Of course, I'm not a fan of those spacers. -
How many 15+ year old vehicles have the stock exhaust? Mine is 2.25 I think. But I don't remember. It was pretty weird.
If nobody here can help you, post on www.jeepforum.com in the comanche section. 'Ed in North Ga' will respond, and he knows EVERYTHING about renix 4.0s, it seems. Otherwise, I can't do anything for you.
That came out clean. Always good to see somebody building their own stuff.
Yeah, pretty sure that's BrettM. Somebody should b*@$£ at him so he posts on this board.
Welcome I wish my engine ran smooth...
Nah, Cnd is .89 to 1.00 US. So that's still $400~ US.
Give me a couple days and we'll see how far I get on mine.
Well, when the water gets deep anything that keeps the engine running longer can make the difference between being flat out @#$%ed or just pulling out on the other side, or having time to back out and rethink things. Anyways, my stock placed S-pipe has held up pretty well, save a few dents, it was pretty much from the tranny back that the exhaust kept getting trashed. I'm going to make a full belly skid and that should end that. I'm still not sure what type of mount I can use that will provide some isolation/dampening but keep the stack rigid. Save slipping a rubber bushing over the pipe, and then slipping a larger dia. pipe over that and welding brackets to it. Think I could get a closeup pic of the actual mount on the semi? TIA, mjeff87
Yeah, but it's not like Pat's (pingpong) rig, which is what I'd classify as 'not stock appearing'.
Since I'm somewhat redneck, I think I'll be getting a cherry bomb. Or maybe it's because I'm really cheap. Anyways, since I don't have a bed and all, I figured I'd run the tail pipe straight up the back of the cab. I'd paint it black of course. Now, I'm wondering if it'll be alright to bolt that pipe to the back of the cab, without any sort of dampeners or such, as long as I have one of those flex fitting things at the bottom? Or is $#!& gonna rattle? (It's a Jeep, who cares, but still I'd rather it not sound like an big angry bee like the ricers.) Now, if I need some sort of dampener/isolator, how the heck do I build one?
how to bootyfab a rear bumper
DirtyComanche replied to mjeff87's topic in MJ Tech: Modification and Repairs
Take it wheeling on its last day, just to show it what could have been... -
So i made some TJ windshield mount light brackets
DirtyComanche replied to Stumpy's topic in The Pub
Yeah, Torx, my enemy... But what was worse was I snapped off one of those brake speed bleeders. Man, that took a long time to extract. But I frigured out how to weld stainless pretty good by the end. -
Header For 89 Comanche?
DirtyComanche replied to Antarctico's topic in MJ Tech: Modification and Repairs
Are these guys talking shorty headers, not longtubes? Then I agree with Pat. Spend your money elsewhere. I'm so tempted to try making my own longtube header with a pipe bender. (That harbor freight special one that costs $99) Like everything else, I'd save money but it'll take me 3 weeks...
