Harley
Everything posted by Harley
  1. Make sure to lay on the horn and wave as ya pass through town!
  2. I use to install siding for quite a few years and heat is the only thing that will do that. It almost looks like it was done intentionally due to the triangular shape of it. Do you have kids or kids in the neighborhood that could have possibly somehow caused it? Never seen it just happen without some sort of heat source help
  3. Need 2dr seats anyway. Oh well, thanks for the info anyway.
  4. Where ya located at? How much would he want for the booster and master?
  5. No problem. Good luck with it.
  6. If its not normal maybe I should fix mine too. Waiting for results............ :popcorn:
  7. mine does the same thing. Always thought it was normal as in setting the throttle for cold starts.
  8. Any chrysler dealership or jy for sure will have those plastic clips. Once you see one intact and in your hand you'll understand how to replace em. I always keep a few spares on hand cause they always break. especially when it gets cold.
  9. Those seats out of a 2dr by chance? what color and how much?
  10. Hmm, nobody knows? I know ya change it wire by wire if need be but I'm more interested in a plug and play setup
  11. My seats are torn up and was wondering if seats from a Cherokee would bolt up to my existing brackets? If not, does anybody know what options are out there for replacements or would it be best to just have them rebuilt?
  12. Need to replace my fuse box. Are they all interchangeable or does it have to be model/engine specific? Or any ideas on where to find a new one?
  13. No but it looks like any other visor out there. They're all the same. ya seen one ya seem em all.
  14. I would guess you have the 4.0. Not sure if its the same but on my 2.5 I had to remove the exhaust and the starter. It was a 4 piece gasket. Was easy to do though.
  15. When was the last time ya fed the gerbil? Mine gets tired when I don't feed him regularly
  16. oil pan gaskets
  17. With a test light you can have it wired in 10 mins. Faster than anybody can dig up a schematic. Its real easy and basic. Or ya can go to the parts store and get a book for $20 and that'll have it.
  18. FYI A heater core isnt as bad as they seem or people say. I did mine about a month ago and it took a couple hrs. Didnt even have to pull the dash.
  19. Just use a test light. probe the wires til ya find the one that controls the parking lights
  20. Just remove the small bolt on the harness and unplug the box. Then remove the 4 screws holding the box to the firewall.
  21. That line was fine.
  22. to be honest not really sure what the exact cause was because I swapped parts out so much before I got results but I'm thinkin it was just faulty masters that I kept getting. The one that's in it still might be bad because I don't think its releasing the clutch fully as its somewhat harder to shift through the gears but it does seem to be holding pressure now and no leaks that I've noticed. Gonna try bleeding it some more to see if I can get it to shift smoother like it use to.
  23. Got it figured out. Its one of those $800 when new decks that has an alarm, starter disable, built in crossover. it wires into an existing alarm, door switches, etc. Basically there's alot of wires out the back of it. lol
  24. Anybody by chance know of a source for pioneer wiring schematics? Theres a couple wires, not sure what they are for
  25. Duct tape and Gorilla Glue........Speaking of which, I'm gonna put some gorilla glue on a non stick pan and prove someone wrong tonight! :cheers:
