fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. Decided to finally go the antenna delete route with the NOS antenna hole cover PN 56001184.
  2. fiatslug87
    Fly bys?
    Sitting in the backyard enjoying a beer and this Kalitta Air 747 from Travis AFB to Honolulu flew over us at 6200 ft.
  3. My 90 that I purchased new has flanged nuts exactly like the picture above, as do the 88 and 89.
  4. Added a set of aftermarket louvers that I’ve had for over 10 years to the power slider. I didn’t like how they fit so I added additional mounting points at the corners. Before: After: Mmmm ‘80’s goodness:
  5. Private group, you have to be a member
  6. I have some of the Crown ones and they are not as rigid as the original and bend easily. Hopefully their new supplier makes a better product.
  7. Someone said these worked for them: EBay Link Summit sells ones mad by Crown but are currently unavailable, they go in and out of stock. https://www.summitracing.com/parts/cwa-34201545
  8. Looks good! I think you have your shifter boot rotated 180°, the high part at the bottom should be towards the dash.
  9. Grab its VIN and post it in the registry even if you don’t buy it.
  10. My old crappy eyes!!!
  11. You got it in the right place, it’s a ‘91.
  12. July 2026 update, see first post. 9 new additions this month for a total of 2533.
  13. I LOVE that wall!!! GLWS
  14. Had to replace the water pressure regulator valve for the house, also replaced the old main gate valve with a ball valve while I was there. 31 years took a toll on the old pressure valve.
  15. As ratrapp said use a local guy. I luckily have a neighbor that’s an owner/operator, saw his truck as we were walking the dogs. I had him remove my rear slider and clean up all the urethane.
  16. There are at least three types of gauge surrounds with matching lenses and a lens without the trip reset hole. The top one has a small cut out in the speedometer the bottom is HO.
  17. 89 MJ is correct (PB3), please post it in the registry and a build sheet will be provided. https://comancheclub.com/forum/32-1989/
  18. POR-15 is a urethane coating that is Painted Over Rust. There’s a cleaner that should be used before application.
  19. Oh man that brings back memories, I had the Hot Wheels Red Baron back in the early ‘70s. That looks like a great place to spend several days!
