fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. I like the color, is it just me?
  2. That’s a lot of work!
  3. Nope, homemade. Using a Grand Wagoneer switch: momentary, off, momentary.
  4. Decided to put the rear sliding window switch in the cup holder so I made a switch panel for it.
  5. On eBay in Tacoma, WA.
  6. Great hearing from you again. Looks like the little ones can drive it in ten or so years. 😉
  7. Before I pour anything into my engine I would make sure I knew why I needed it. Have you done a compression test (dry and wet) and a leak down test?
  8. You can send your oil to Blackstone Labs for analysis. They will give you the amounts of different metals, fuel, coolant, etc. in the oil along with a brief analysis of the results.
  9. There are at least three versions of the 4.0L MPI manual. The pdf that's been circulating for years with the missing page 59 is identical to the 1989 version except for the cover and the numbering of the Notes pages (up to 94 in the '89 version).
  10. That’s not an overflow tank, it’s the pressure bottle. It should be filled to the top of the inner post when cold.
  11. Have you removed the handle and cleaned/lubricated the button mechanism? I’m assuming the clips/rods/springs are all intact since you can futz and get it to work. p.s. The obligatory “your grill is upside down” comment.
  12. Are all three individuals coming from the same warehouse? With RockAuto sometimes the shipping gets you.
  13. On eBay asking $8K OBO in El Paso, TX.
  14. Back on eBay asking $35K BIN in Woodburn, OR. Now looks like this.
  15. How do you get pinstripes in that desolate area?
  16. Swapped out my original slider for a CR Laurence power slider. I’m using a Grand Wagoneer rear window switch but not sure if I’m putting it in the center console or the overhead console.
  17. This belongs in the “It’s a Comanche but not a Comanche” thread.
