fiatslug87
Moderators
    8
Everything posted by fiatslug87
  1. fiatslug87
    can't decide
    Four letters HEMI and supercharge it while you're at it.
  2. I sent one to a CC member in Belgium!! :yes: haven't heard if he's received it yet.
  3. If you need one see this viewtopic.php?f=4&t=12465&hilit=chime
  4. I'm more concerned about your MJ.
  5. use a Mothers Mini Powerball, really cuts down on the elbow work
  6. Check out this site http://www.wheelcollision.com/jeep.htm
  7. I had that as a sound on my Mac Plus!!! I like this one http://www.youtube.com/watch?v=HKGiOY72 ... re=related
  8. An alkaloid drug, C11H17NO3 (mescaline), obtained from mescal buttons (either of two species of spineless, dome-shaped cactus, Lophophora williamsii or L. diffusa, of Texas and northern Mexico), which produces hallucinations.
  9. Check with the guy selling on e-Bay, autographixdesign, he seemed very willing to work with people.
  10. This might help viewtopic.php?f=2&t=1988&hilit=+bed+bolts+picture Try PMing jeepthing07 for the pic of the other 4 bolts.
  11. Hi Joe, There are two MJs at the pick-n-pull in Fairfield (near the Air Force base) one is an '86 the other an '89 (?) both were 2.5L, I think the fuel pumps are still in them. I'm not sure if they're the same as the '91s but if they are that's an option. Mike
  12. If you're pulling from the donor XJ, just take note of the wiring, it will be the same for your MJ.
  13. BUMP I've always wondered about this, people say there's a drain and if it clogs the water ends up on your floor.
  14. When I changed the clutch master cylinder in my '90 I didn't remove the slave, but mine is an internal slave (AX-15) and there is a bleeder screw at the transmission. Come to think of it my '88 Peugeot trans also has the same bleeder set up. What transmission do you have? EDIT: I just saw you have the 2.5L, I don't know anything about that set up. So here's a BUMP for you.
  15. The light from the '88 will have one power wire to the harness, the other (ground) is attached to the light bracket, however your '92 will have a two wire connector at the harness (as in the picture below) so you will have to rewire the light. Hornbrod please confirm since you have a '91, my '90 has the two wire configuration while my '88 and '89 are single wire.
  16. But now you can make your own!!! :brows: He posted the whole article.
  17. Check this out, 315 HP @ 5250 RPM, 365 lbs-ft @ 3000 RPM. http://cgi.ebay.com/ebaymotors/1987-JEE ... ccessories
  18. The light pulls out about 10 feet (?) and has a magnetic side to it so it can be attached to any metal part, kind off cool.Hey, I have one of those! :D Hey Joe, did I sell one to you? Have you installed it? Is it working OK?
  19. I bought he SporTruck stripes from him early last year, offered $50.00 and he accepted. Still haven't put them on :ack:
  20. You got it!!! :clapping: :clapping: :clapping:
  21. I think ComancheKid45 looks more like this guy... Image Not FoundImage Not Found ...what say y'all? :jump:
  22. The light pulls out about 10 feet (?) and has a magnetic side to it so it can be attached to any metal part, kind off cool.
  23. The plan is to first have my wife replicate the cloth portions and sew them into the existing vinyl parts that are in very good condition (she's pretty good at sewing). If that doesn't work out I'll find a shop that can make them.
  24. OK in order to remove the whole post, you have to reach up under the seat cover and depress two tabs at the base of each post and then pull them out. It's been a while, just after you got your gray buckets. I'm the ultimate procrastinator. :yes:
  25. I'm trying to remove the covers from a pair of bucket seats so I can replace them. How do I remove the headrest "bungs"? -the black pieces in the picture. BLHTAZ, do these look familiar :thumbsup: ?
