8
Everything posted by fiatslug87
4.0L HO Airbox/CCV Hose Reference Photos
fiatslug87 replied to Moosieus's topic in MJ Tech: Modification and Repairs
Look through this post. -
1989 Jeep Comanche - Crank but won't turn over.
fiatslug87 replied to dotnetrob's topic in MJ Tech: Modification and Repairs
By turning over you mean it started and ran for a second, right? Jump the fuel pump ballast resistor on the driver side fender and try starting. You can also check fuel pressure at the rail, Cruiser’s tips has the procedure. -
Will it start if you put starter fluid down the TB? -
VIN Registry List: July 2026 Update
fiatslug87 replied to fiatslug87's topic in Comanche Registry (VIN decoding)
July 2025 update, see first post. 13 new additions this month for a total of 2413. -
You have a Pioneer Metric Ton there.
@JMO413 can you get the selling location? Thanks
@JMO413 can you get the selling location? Thanks.
Montana Manche Restoration
fiatslug87 replied to Montana Offroad's topic in Member Projects: Your Comanches
Look great! How is the road noise on pavement?- 57 replies
- comanche
- comanche restoration
- (and 14 more)
If you want to see some spectacular engine bays check out Gjeep’s and HOrnbrod’s.
According to Cruiser’s tips 0.3v is too low. https://comancheclub.com/topic/73466-7-–-cps-testing-and-adjusting/ -
Then check the CPS as stated above. Sometimes if you disconnect and reconnect the CPS it fires up. -
Do you hear the fuel pump prime when you turn the key before cranking? -
The one that’s just above the oil pan (driver side) is the knock sensor, the one farther up and back is the coolant temp sensor.
Running hot fan question
fiatslug87 replied to Colt6920's topic in MJ Tech: Modification and Repairs
When you get a chance add the truck to the Registry. -
Added Laredo molding modified for my SWB ‘88 Pioneer. Had the molding Line-Xed when they did the bed, also a little inlay with repainted full size Cherokee emblems.
Adding AC, need details for Dealer AC harness
fiatslug87 replied to Kedosp's topic in MJ Tech: Modification and Repairs
Try these https://comancheclub.com/topic/12083-electrical-manual/#comment-117394 https://comancheclub.com/topic/11875-renix-factory-service-manual/#comment-115082 -
Post a couple pics of your Eliminator.
comanche project gone bad.
fiatslug87 replied to dirtyoldjeeper's topic in MJ Tech: Modification and Repairs
It looks real clean and modern without the emblems.
Great work, looks fantastic! Has it passed CA emissions in its final configuration? Have you been MJOTM yet?
Two bags of tater tots in the turkey fryer filled with actual lard!
