The86manche
Everything posted by The86manche
guess which pile is the good wiper 'puters...
The86manche replied to Pete M's topic in MJ Tech: Modification and Repairs
Moisture doesn't exactly help them but I'd argue not the big issue with them. The boards are loaded with resistors and capacitors and unfortunately over time they wear out/ dry up and will no longer hold/ control voltage. Which causes them to lose their function. So no, there's really no way to make them last forever. You can replace the capacitors though. Which is what I've been trying to do but I have to get more in depth with my testing to find where each weak link is in each board. I want to design a new board that either doesn't need capacitors anymore or is just.. New. instead of refurbished. -
Yeah but I have not given up on this! I've got a bunch of ideas and things I want to try or look into. But right now kind of on the back burner -
Wiper Delay Module Compatibility
The86manche replied to TeKdo's topic in MJ Tech: Modification and Repairs
That's me but things have put it on the back burner for the time being. I need to rig up a live test harness so I can probe and see what's getting power or not through them. -
Idiot lights gauges 1986 COMANCHE 2.5L
The86manche replied to SLOTMAN's topic in MJ Tech: Modification and Repairs
Paint thinner, acetone. Not airplane stripper. That will take everything off. It looks like a rattlecan paint which is not resistant to rough chemicals.
I happen to have a 3/4 cluster from an 85 cherokee that should work. It's in decent shape I'd sell. -
RADIATOR 1986 COMANCHE 2.5L MANUAL 5 SPEED
I was told oriellies has a full aluminum radiator -
I'm not 100% on the year honestly. I know it had a 4.0 so I don't think it was an 86. The vin tag was even kind of hard to read. Owned by dead jeep in Rhode island. Soon to be crushed. I grabbed parts off it for free before it gets squished! She was rough. Fire at one point. Rusty in places. But the metal that i needed was perfect! AND also had a d44 axle under it i scored for FREE. I think it's even a posi.
Engine swap in California
The86manche replied to Ryans88's topic in MJ Tech: Modification and Repairs
I have not as i do not live out in California but I just wanted to give you a heads up about the 2000-01 xj 4.0s. The heads have weak castings and tend to crack between cylinders 3 and 4 right below the oil cap. -
I was going to ask about header panel parts until I read it was already going to be used. Also I agree sad to see it pulled apart
1986 2.5L to 3.4L: Amateur Hour
The86manche replied to FigurativeGarbage's topic in Member Projects: Your Comanches
Those are aftermarket? They look like fiero valve covers to me. I have a set of real fiero valve covers I'd sell if you'd like. They do require specific bolts and unfortunately I lost them though. They have a collard washer on them. -
If you cracked the valve cover you may have over torqued or they were the wrong bolts. That is quite unfortunate hopefully you still can use it -
Key parts sells the full length floor pans for our trucks. Not firewall metal though. But easy enough to recreate. Or get from a cherokee because it's the same up until 96 I believe
Weber carb K490 in a 2.8L
The86manche replied to Faceted's topic in MJ Tech: Modification and Repairs
I think the orange piece is a sort of vaccum switch. I may have one in can send you if you really want to replace it -
I see 4 good relatively clean trucks that could be saved and though they are missing quite a bit what they share with the cherokees would make it easy to get back on the road
Project clean machine?
The86manche replied to The86manche's topic in Member Projects: Your Comanches
As I pinch pennies for some more sheet metal I figured I'd do some more work elsewhere. I went back to the d44 to do more work! Center chunk removed! It's an absolute mess! Spider gears are chewed, the pin is held in by hopes and dreams, the amount of glitter and chunks is astounding. Seals are shot too. It was just a list of discoveries that I didn't love. I also found out one side of the axle had new bearings installed.. and I could pull the race out by hand.. so someone may have spun a bearing? And I have to deal with that. But I'm going to make it work! In the meantime I scuffed and coated the whole axle in flat black rustoleum. That turned out nice at least! Next step is to take the pinion gear out, remove the rest of the races and pressure wash the chunks and glitter out of it so I can put it back together and put it under the truck.- 142 replies
- candace the comanche
- candace revival
(and 1 more)
Tagged with:
It was tough, still a lot of texture on that wheel so scrubbing the grime out of it was painstaking, but the end result sure was satisfying
I should have one. But also key parts makes new housings and lenses too
There should be two almost L shaped brackets one on each side of the axle by the coil springs with a stud going through the side. The link should secure to that and then to the sway bar
1992 Jeep Comanche "Maria"
The86manche replied to MariaManche's topic in Member Projects: Your Comanches
When I removed mine I did almost exactly what you did but I also applied a little heat on the top side. I used two nuts and was able to remove all of mine
