The86manche
Everything posted by The86manche
Project clean machine?
The86manche replied to The86manche's topic in Member Projects: Your Comanches
Broke out the hand held sandblaster and worked away. Blasted the piece i removed and cleaned up scale on the crossmember where it bolts to the unibody. Will need that installed when I need to weld in my patches and don't want rust touching my work lol And everything ive been cleaning up ive been coating in rust converter primer.- 142 replies
- candace the comanche
- candace revival
(and 1 more)
Tagged with:
Happy 4th everyone! I had nothing going on today so I decided to put my nose to the mj grind stone! Ive been peeling back the unibody rail to clean up the rust and I had one last spot to remove for total clean up and clean out. This little guy. It wasn't too far gone thankfully so I didn't need to make any more patches and the ugliness behind it.- 142 replies
- candace revival
(and 1 more)
Tagged with:
Really? That's unfortunate, Whats the difference?
Looks like a solid one to save
I'm on a roll with this metal shaping! This is the outer lower section of the unibody rail. Lined right up damn near perfectly. This is the inner section that the cross member would bolt into. Needs a little finishing up. All in all the metal shaped really nicely. Now I need to clean them up, weld some flange nuts to the inner section and epoxy them before install.- 142 replies
- candace revival
(and 1 more)
Tagged with:
Taking baby steps but progress is progress. Took the stencils I made with sharpie and cut them out into shapes! Took them over to the metal break and bent them to shape. I'm very happy with how that turned out.- 142 replies
- candace revival
(and 1 more)
Tagged with:
I might have the tail light harness. It may take me a bit to try and find it though.
It would either be a switch plate for fog lights/transmission switch(if auto) or a blank plate.
After a hiatus, I need an opinion...
The86manche replied to Spinnakerblue89's topic in MJ Tech: Modification and Repairs
I started at the rocker. My thoughts were to have the inner rocker replaced firsts there would be no working around the floor. And I can put the floor in and work it to the rocker instead. I'm leaving the outer off until the floor is burned in so I can clean up the burn marks from the welder on the inner rocker. Then put the outer panel on -
84-86 XJ/MJ oddities to be mindful of.
The86manche replied to eaglescout526's topic in MJ Tech: DIY Projects and Write-Ups
Hey very sharp of you! These are indeed ones that came off a sport bar! I even have the switch plate for them too! But I just used it as an example. -
Other nuances! The hockey puck arm rest chrome trim, including the little diamonds for the ends! Go figure mine ran off somewhere.. Those marchelle fog lights! And mud flaps! -
So before I pull it off just wanted to show you its condition. It had been a while since i looked at this closer. The cable does move, no binding but the retaining end for the carb doesn't have the tabs anymore. And the sheathing is a little worn. I don't know if you will find one thats really in any better shape but I just wanted to point that out in case you were looking for something better.
I can pull it off for you. Been trying to sell the Trans and tcase to no luck. Will likely end up tossing it, but if there's anything else you want off it let me know.
Well back to Candace again, working on that efforts of curing her of her cancer. Removing plates and cutting out the unibody rust. The cancer. Plate removed! And out unibody section removed. From there the last inner section was cut. I still have a spot to cut out. But for the most part its all been removed and I can start making my patch panels to put back in.- 142 replies
- candace revival
(and 1 more)
Tagged with:
I'm not sure if it helps you at all but the front bumper is the same as the cherokees if that helps your search at all
None taken lol I never expected the first print to be perfect anyway haha
It has once again been a little while since ive done any progress to the truck. A lot of life has happened in a short amount of time that pulled me away from this truck. House renovations, family, travel, I lost my brother last year. Its been a lot. But I can finally say I'm back on it. Taking it slow and assessing the rust on the driver rail under the floor. Ive got my work cut out for me yet. But I have a game plan. Inside of the rail was full of old mud that had hardened to almost cement. A wonder why its so rusted inside. Peeling it back one layer at a time. Will shape some patches and put it all back soon. Still have cutting and cleaning to do.- 142 replies
- candace revival
(and 1 more)
Tagged with:
Okay! Give me some time while I make it then!
So i looked at my 86 column and I understand what you are looking for now. Are you looking for original? I could probably 3D print the little piece
Or a yj
I feel like one from an s10 could work too. Late 80s early 90s. I could be wrong but it is the same column.
Vacuum, or pressure? The old pump may have just been very weak. But as far as I understand, if your truck is a 2.5, it didn't get a ballast resistor. If its a 4.0 maybe someone removed it and just connected the spade connectors together. Either way, it would quiet the pump down. Did you drop the tank to change the pump?
