The86manche
Everything posted by The86manche
Intermittent wiper module repaired
The86manche replied to The86manche's topic in MJ Tech: Modification and Repairs
A perfect example. But in my case, the wiper motor shakes and moves just enough to jostle the wires around which causes bad readings. I had a good module working on the lowest delay setting but the linkage would cause the wires to shake and caused a contact issue which made it run constant instead. The wiring on these are super simple but the grounds need to be checked. The the contacts for the connectors that plug into the module from the harness I have found wiggle around a lot and may cause instances of poor connections too. Lots of simple variables that may be overlooked. And is why I would love a love test sorce from a truck instead of a test stand to se, hopefully, the same results, not different. But if I get different results I can find out why. Is it the connectors on the harness? Does the wiper motor need a much stronger ground? Pinched wire? Failing wiper switch? -
Yes please, id like to fix up a few more so we can do a big batch test. But so far i have about 5 that I have tested good. I have found that these modules are suuupperr sensitive to their wiring connections. -
July 2026 - The Clean Machine in Progress
The86manche replied to 89 MJ's topic in Comanche of the Month (MJOTM)
Thank you everyone! She's on her way back to New, but also different lol -
Well i took a video of the jig in action but the video is too big to post. I need to find someone even semi local because some of the modules that Pete tested for me tested good for me when they didnt for him. -
Slow going on this project but finally got the modules back and went through wiring diagrams to build a test jig for the modules so I can check them live. Surprisingly simple design. -
That power regulator can be used for parts to fix the manual regulator
Did you get a photo of the other xj?
I can't seem to find where i placed the extra set i have.. I know I have them. Ut I don't remember where. So feel free to reach out to fiat, I don't want to hold you up
I will have to check when I'm home but I believe i have those mounts and bolts
Front brake maintenance - caliper guide pins
The86manche replied to blanzawa's topic in MJ Tech: Modification and Repairs
That doesn't look factory honestly. I don't think ive seen that. Maybe someone put them there. My 86 does not have those. -
Project clean machine?
The86manche replied to The86manche's topic in Member Projects: Your Comanches
- 136 replies
- candace the comanche
- candace revival
(and 1 more)
Tagged with:
My 1990 Wiper Repair
The86manche replied to AnotherOldJeepGuy's topic in MJ Tech: Modification and Repairs
Visually it looks a-pkay, but the biggest capacitor on the board looks potentially compromised. Hard to tell from top down view, but the top looks potentially swelled. I would test them. If they pass it could be one of mamu diodes on the board or the voltage chip. -
Found my motor mounts! Installed with new hardware. Now time to fit some headers. Ive got two sets. And after tonight I either have to use one from each set and modify or get custom.. Motor in! And test fitting headers.. That's a no go on the right.. Left side is much more agreeable. This one is actually for the camaro/firebird platform. It bends towards the front of the oil pan. The other header dumps right at the axles pinion. Not super ideal. It is snug in there though. But clearing is clearing! Flipped itself.. but this pipe goes from the left header to the right and is too wide.. I think ill try taking it to a muffler shop and seeing if they can make an identical piece but 5 inches narrower. The other header for the right side almost works.. but still not quite.. Header flange hits upper control arm mount. Hmm....- 136 replies
- candace revival
(and 1 more)
Tagged with:
Sorry to hear about your health but glad you are still standing! I may have to roadtrip out. Ive been looking for another 84-86 hood so I don't have to cut mine up for the blower
I also have not given up on this. I had passed them off to a buddy who wanted to look into them and he got to busy to get anywhere so the project stalled. I'm getting them back so I can continue my work. -
I actually recently picked up one out of a yj, I need to go through it to make sure its good. Once ive confirmed that it will be up for grabs if you want it. And if you don't mind id like to take your old one off your hands as a "core" to refurb. Otherwise I could go through yours for you. -
Theres a junkyard page i follow on Facebook and someone posted about a pt cruiser with a factory Whipple supercharger on it. Might need to source one for yours Pete
The ups lady showed up today while I was at work! Left floor brace, so now Ive got all i need to finish up this left side. Brace needs some minor mods. 86 doesn't have studs that go through the floor so will have to notch them out. Getting excited to finally see this thing put back together again. Also pulled out the headers and went searching for my engine mounting plates.. no idea where I put them..- 136 replies
- candace revival
(and 1 more)
Tagged with:
What should I do while the carpet is pulled up?
The86manche replied to jodawill's topic in MJ Tech: Modification and Repairs
Yeah, those are just drain holes with plugs in them and seam sealer. Looks like they may have used two different plugs from the factory? But still, oem. -
If you still need the tail light harness I found it, turns out I have two. Lol
You could use a clear enamel if you wanted. And if you didn't want to brush it on and have that brushed look you could grab a cheap harbor freight spray gun and reduce the enamel and spray it on for a smooth look. -
Scuff it and seal it with some enamel or other tough and comparable product. Spray some rust preventative, like cavity wax in those floor braces too and then you'd be find to put some sound deadening in if you wanted. -
It was bring your floor pan to work day today! I ran out of hardener for my epoxy and it was too big to prime at home so I brought it in to shoot. Two coats each side.- 136 replies
- candace revival
(and 1 more)
Tagged with:
Are you sure that has a 2.8? That engine wasn't an option in 88
No, I stand corrected. They sell header flanges so you can make your own headers for these engines- 136 replies
- candace revival
(and 1 more)
Tagged with:
