eaglescout526
Administrators
    13
  1. Build date: 8/24/87
  2. Build date: 6/30/88
  3. Build date: 10/15/87
  4. Build date: 9/13/87
  5. Build date: 4/11/88
  6. Build date: 12/14/87
  7. Build date: 5/30/88
  8. Build date: 4/7/88
  9. Build date: 9/30/87. I don't know if the VIN is off by a digit but the last "9" might be an "8" instead.
  10. Build date: 4/28/88
  11. Build date: VIN is incorrect in some form. Comes up as an XJ.
  12. Build date: 11/24/87
  13. Need VIN for build date
  14. Build date: VIN giving issues
  15. Build date: VIN giving issues
  16. Build date: Correct
  17. Build date: 4/28/86
  18. Build date: 3/9/86
  19. That makes sense. I’ve never owned a 4WD Jeep but I can see it. Scratch what I said. JMO is right. With or without cruise is your choices.
  20. I can’t imagine AMC using eight different cables for two half different vehicles. I can look tonight for the parts and differences in cable lengths between the XJ and MJ but I want to say length of the drive train to the speedo should be the same regardless of the body style. The only differences should be 2WD and 4WD with cruise or without cruise.
  21. I smell the 80’s
  22. Actually one of them is giving me issues in the program, it acts like the VIN exists but doesn’t and I believe what’s left has correct build dates. I can go back and double check them
  23. Lol, nice!
  24. *X1 -Y1 APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual,T3340 EPD ENGINE - 2.5L I4 TBI GAS HCC HEATER W/UPR LEVEL VENTIL - TYPE II LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Punk'n Metallic Clear Coat QE4 Punk'n Metallic Clear Coat TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Bare Minimum.
  25. *W7 Cloth Lo-Back Bckt/Red Accent Seats -YY 3LZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AGL PLYMOUTH SPRING SPECIAL PACKAGE APA MONOTONE PAINT PACKAGE AWE UP COUNTRY SUSPENSION GROUP AWH POWER EQUIPMENT GROUP BCQ Battery - 750 Amp Maintenance Free CAC BUCKET SEAT - LO BK CGW Air Bags - Front, Next Generation** CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual DMR 3.42 Axle Ratio ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ Fog Lamps LPE EXTERIOR CARGO LIGHT MBF REAR BUMPER - STEP TYPE (BRIGHT) MCA FRONT BUMPER GUARDS MCB REAR BUMPER GUARDS MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY PXH QXH RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJN 15" Aluminum Wheels Build date: 5/19/87 Body JP62
