eaglescout526
Administrators
    13
  1. Just went through this with the blue cluster. It’s a finicky thing to get adjusted just right. I’ve had mine for almost a year now and I finally got the tach in the sweet spot for the 2.5L. The REM helped me a lot both times I adjusted it. Course, i don't know how it was off the first time I adjusted it as I used the REM. You'll get it adjusted where it needs to be.
  2. Progress. Your TPS works as designed.
  3. If it was, revving it while at idle would starve for fuel in the same manner you would putting it in gear and driving.
  4. Guess it’s time to pillage dealers for JK shocks.
  5. Hmm. You’ve checked just about every box for this problem. Course I’m curious about your sending unit, not that that is the issue. Check your TPS and make sure it’s voltage output is around 4.5-4.8(or 85% something like that) volts if I remember correctly from my TBI service manual(there’s a whole adjustment procedure, it is in Cruisers tips). Make sure the TPS is receiving 5 volts as well. You can also play with the TPS as the engine is running and see what it does. It should bog down as you push on the sensor’s lever as the engine is idle.
  6. Hmm. Odd. But it doesn’t surprise me that I had issues.
  7. No problem. It took me a while to hunt those codes down. The AMC one was found using the link that is posted and going under the AMC cars and not the Jeeps. I found the Chrysler code in an old book but can’t remember which book for the life of me at the moment.
  8. Awesome. I really appreciate it!
  9. Damn. The VIN is coming back as invalid.
  10. Thank ya! I think that 2.5L has the AMC logo valve cover. Can’t confirm but the gold for that and the air cleaner is a different touch. I believe Minuit was looking for a 2.5L coolant bottle with cap. He still might be interested in that, but I know the cap and baffle are really rare
  11. Color code for Colorado red: AMC is BE Chrysler is HE4 for the later years.
  12. 2.5L stuff needs to be saved. Can that license plate bracket on the front be grabbed for me? I’ll decode this one soon.
  13. Oh god. I’ve only had the crate for a week now and these parts are just soaked and caked in gunk. I don't know what the owner had happen to everything but dang. I spent thirty minutes pressure washing the crap of the trans. I think it is an AX4. Won’t shift into fifth so it could not have a fifth. Every other gear is fine. AC bracketry and all the bolts and stuff took me a few days to soak and clean. Got fed up and pressure washed all those parts and hoses from the thirty years of crap. I swear my engine was not as gross as all these parts when I got Little Red. Now I just gotta look at the parts diagrams and figure out which bolt goes where. Scored a Renix CPS out of this. Cleaned it up and let it soaked in the mix I made with the other parts and installed it on a gamble and sure enough she fired right up. Awesome. Another original sensor. I still have to buy a good chunk of new stuff for the system. Probably will gamble on the original hoses. Here's what to expect to see; clean parts to be restored. New parts to be acquired. And within a month or so should come the install of everything under the hood. Ill post a bunch of before and after pics of everything that I have chosen to be cleaned and restored.
  14. Not many people can say they own a first year run XJ. Get me the VIN and I’ll decode what it has.
  15. Who would want to be affiliated with the people who bashed on Steve Irwin.
  16. Um, Well, its tough to say. There's a sales code option for perforated leather, what ever that is. There is a leather and plastic option for steering wheels as well. As to whether Chrysler is using real leather or not, I can not say for certain. Probably pleather? A lot of the newer leather interiors don't really feel like cow leather if they have the leather option. My two cents.
  17. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY Build date: 1/27/86 Body code: JL62
  18. No worries. I’ll get it decoded tonight. Thanks for getting back to it
  19. Baffle is long gone but you don’t need it. I used a big 5 quart valvoline oil cap and it works great. I found a NOS one on eBay and bought it. There should be seven dealers left with them. Would you like me to PM you some numbers?
  20. That full instrument cluster needs to be saved! That’s the blue faces!
  21. Yea that is true. But this salvage yard has nothing but Jeeps as new as 2001. But not a lot but they have plenty of resourceful Renix era parts for me. Most still have the AC/heater box plenums. Sadly some moron that worked for them many years back tossed all the Renix engine harnesses. I think anyone would be happy to get rid of any part associated with the 2.8L
  22. As soon as I saw this post I went to the salvage yard I frequent and snagged what I needed.
  23. *X1 -SA Charcoal 3LX ADA LIGHT PACKAGE AGJ Driver Assistance Group AHY Hybrid Electric Vehicle 15 KW Group APA MONOTONE PAINT PACKAGE BCQ Battery - 750 Amp Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGW Transmission - 4-Spd. Automatic,44RE DTA ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHB HVY.DTY/AUX TRANS OIL COOLER NHQ Transmission Heater NMB ENGINE COOLING - STANDARD DUTY PQ9 QQ9 RAB Radio - AM/FM SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE TBB CONVENTIONAL SPARE TIRE WJN 15" Aluminum Wheels YJP NEW VEHICLE SERVICE - WINDSOR Build date: 12/16/87 Body code: JM62
  24. This style? Freshly restored.
