13
Actually I am almost certain the battery codes are right. Chrysler doesn't use that battery type anymore and usually Chryslers new battery codes mention the Amps the battery puts out.
It has been posted under your VIN post
Done
*X1 TRIM STYLE X1 - CLOTH BENCH -H9 143 Zone 43-Pittsburgh 1AA U.S. Dealer Retail 5KK First American Title Insurance CO. ALA SE Decor Group ALK Italia Package APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DCK 4SPD MANUAL TRANS - AISIN SEIKI DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EPD ENGINE - 2.5L I4 TBI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA HW1 JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDD LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z56 Left Front Spring Group Vi Z75 Right Front Spring Group V Build date 3/21/90 Body code TL61. Looks like it left the factory with a 4 speed manual
Yes, that's exactly how you post up your VIN.
If you can, post more info about your truck. Year and engine would be sufficient. Also post your VIN in the registry and I can get you a build sheet and we can see what was originally in your truck.
Manual. Except Honda manuals. Those are sensitive engagement.
Comanche Dawn
eaglescout526 replied to Limeyjeeper's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Yeah...aint that the truth. Some parts still hide at dealers and at vintage. When that one member got a NOS rear bumper for his truck a while back just from having no bumper on his truck gives me hope theres still NOS parts laying around in peoples possessions. -
Can this mechanical fan be salvaged?
eaglescout526 replied to Drahcir495's topic in MJ Tech: Modification and Repairs
You could always get a new one in place or rebend the blades back and throw it on and see how out of place it spins. -
Comanche Dawn
How? Like JMO and I say "Its the thrill of the hunt". Been hunting down NOS parts for 3 years now and its been fun. -
Comanche Dawn
Rochester and GM made these. GM is all over the AMC/Jeep charcoal canisters. -
Damn I said too much. Yes I can get it less. I would have to call one of the dealers who has it.
First post, new to the club
eaglescout526 replied to OtterMobile's topic in Member Projects: Your Comanches
Ok I wasn’t the only one who saw corn. -
List is $161. I can snag em for a bit cheaper.
Found it! Good news. The intermittent wiper switch is still available at some dealers. 16 left. I had no idea that was the switch.
89 4x4 Conversion And AX15 Swap HELP
eaglescout526 replied to Killernoise's topic in MJ Tech: Modification and Repairs
No. Neither AC of AD is. -
Wow. Had no idea. That fits 00-01. AB shows 87-99. Hmm. I wonder just how different they are as the two do not supersede into each other. -
This. Right here. You need the AX15 cross member. That cross member is good for only the BA10/5 and the AX4 and 5. Thus meaning the holes and mounting will be different than that of the original cross member. Two different part numbers are listed here. Any AX15 cross member will do. Yes it says 89-90 but its for just that number. It supersedes to an AB for later years but remains the same. -
I have roof rails for newer Mopar Jeeps I'm selling and will be willing to let them go for cheap if you want to go that route.
When you say the switch are you talking about the whole turn signal switch? That's the only switch in the column itself. Theres the high beam switch that's down the outside of the column and the module goes directly under the column. ACDelco makes the chrome stalks still but have an alignment issue. Chrysler still has the stalks but are black unless you want to go that route.
All that the catalogue shows me. And this is a non tilt diagram. This is a tilt column diagram. Part numbers appear the same up till 90 when Chrysler superseded them.
Let me go take a look at the stalk real quick and get back with ya. Should be able to order a GM replacement. I take that back, I have a GM replacement stalk that I used to replace my worn our letter one which is made for intermittent wipers.
The intermittent wiper isn't specific to tilt or not. If someone else doesn't have one readily to sell to ya, I can get one but it will take me a bit as I am limited to when I can go to the salvage yard. Which is during my lunch.
