eaglescout526
Administrators
    13
  1. Found it! Good news. The intermittent wiper switch is still available at some dealers. 16 left. I had no idea that was the switch.
  2. Wow. Had no idea. That fits 00-01. AB shows 87-99. Hmm. I wonder just how different they are as the two do not supersede into each other.
  3. This. Right here. You need the AX15 cross member. That cross member is good for only the BA10/5 and the AX4 and 5. Thus meaning the holes and mounting will be different than that of the original cross member. Two different part numbers are listed here. Any AX15 cross member will do. Yes it says 89-90 but its for just that number. It supersedes to an AB for later years but remains the same.
  4. I have roof rails for newer Mopar Jeeps I'm selling and will be willing to let them go for cheap if you want to go that route.
  5. When you say the switch are you talking about the whole turn signal switch? That's the only switch in the column itself. Theres the high beam switch that's down the outside of the column and the module goes directly under the column. ACDelco makes the chrome stalks still but have an alignment issue. Chrysler still has the stalks but are black unless you want to go that route.
  6. All that the catalogue shows me. And this is a non tilt diagram. This is a tilt column diagram. Part numbers appear the same up till 90 when Chrysler superseded them.
  7. Let me go take a look at the stalk real quick and get back with ya. Should be able to order a GM replacement. I take that back, I have a GM replacement stalk that I used to replace my worn our letter one which is made for intermittent wipers.
  8. The intermittent wiper isn't specific to tilt or not. If someone else doesn't have one readily to sell to ya, I can get one but it will take me a bit as I am limited to when I can go to the salvage yard. Which is during my lunch.
  9. Nice. Yeah theres a blue wire from the 141 that controls that but I'm pretty sure our trucks don't help control that. I tested it and it seemed to dim the VFD when the lights are on but its too dim.
  10. I can get one from AMC salvage as they have a bunch of those damn things laying around.
  11. Nice! How does it perform for you? And how did you go about the wiring harness situation?
  12. That's fair, its like the cut in the air dam for the tow hooks. Puts my detailed mind at ease.
  13. No problem!
  14. *X8 Cloth Low-Back Bucket Seats -SA Charcoal 125 Zone 25-Canada-Alberta 1AB Canada Dealer Retail 5AM Largo Tracking ACC Southwest Edition ADH Heavy Duty Electrical Group ADL Skid Plate Group APA Monotone Paint BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHS Floor Mount Automatic Shift Lever DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JDB 180 KPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3X STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon NHK Engine Block Heater PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAC Build To Canada Mkt. Specifications YGA Without Billable Fuel YGB 1 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 1/25/89 Body code JM62
  15. *X1 TRIM STYLE X1 - CLOTH BENCH -SA Charcoal 126 Zone 26-Canada-Pacific 1AB Canada Dealer Retail 5AM Largo Tracking ACC Southwest Edition ADL Skid Plate Group APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAA Instrument Panel JAY DO NOT USE - See JP, KA classes JBD BEZEL-I/PANEL CLUSTER - BRIGHT JDB 180 KPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter JKB MOPAR Hood Lock K2X STRIPE/BADGE/MOLDING/COLOR K3E STRIPE/BADGE/MOLDING/COLOR KKE LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon NHK Engine Block Heater PE8 DARK VIVID RED PRIMARY PAINT - HE8 QE8 DARK VIVID RED SECONDARY PAINT - HE8 RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAD HIGHWAY TREAD TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAC Build To Canada Mkt. Specifications YBA 30.2 Liters Of Diesel YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 5/30/89 Body code JM62
  16. Those are TJ/KJ rims(someone might correct me). MJ factory rims look like these: These are what was available to us from 86-92. Not the wire ones, those were for the Limited XJ's with the gold trim.
  17. Well I don’t like how to go about such but honestly finding a fog light/cargo light combo faceplate is like finding the rebels on hoth. But I sliced them in half and “spliced” them together. Its not that obvious but head on it is. Oh well.
  18. Hey hey you added them! Damn she looks good! Hope you have nothing goin on The 21st of feb to join pirate and I. I'm gonna take a moment and read through this build. Wow, there's a lot of similarities in the mods we have done for our trucks goin on. I love it! Absolutely gorgeous. Gotta love AZ trucks.
  19. All axles has a limited slip option. Wasn't limited to which one you bought.
  20. Mines not Limited Slip.
  21. 86 is an odd duck.
  22. It should be the Chrysler A999 three speed. So it should have 4.56:1
  23. Replaced the wheel cylinders for the drums. Braking out back is much better now. And on top of that I cleaned the back side of my rims. Yes the part no one sees but they look good Couple hours of soaking in engine degrease and scrubbing with a broken metal brush does a pretty good job.
  24. Big difference. The 4.0L goes from the box and bends straight down to the TB. The 2.5L has the hose go from the box to the TB and has a special bonnet. I have a whole box I would be willing to part with. I'm gonna do a detail to it to make it look damn good, if you want the box too.
