13
Air conditioner help
eaglescout526 replied to Chris-tofer's topic in MJ Tech: Modification and Repairs
Yeah this could be an issue. You can always swap to the Renix compressor but you might run into the issue of hose fitment like stroker said. Chrysler was pretty non standard with AC parts in HO years. Like 94 could have one hose set and then 95 can have completely different hoses. -
AC Expansion Valve Retrofit Question
eaglescout526 replied to ktmall07's topic in MJ Tech: Modification and Repairs
It’s possible that Chrysler made only a YJ AC kit for the YJ and was made to work on the XJ and MJ as well. The early HO years we’re pretty uniform across the board. -
No problem. Hopefully this guy isn’t too much of a moron for you to work with.
If you get the 84-96 glass, yes it’s the same and you’ll be able to use the trim.
Yeah, XJ and MJ cab forward interchange. 97-01 XJ has a rubber gasket as the trim. 84-96 is just the glass.
Tightening tow mirror
eaglescout526 replied to Whitaker717's topic in MJ Tech: Modification and Repairs
I’ll have to check the service library and see. And I’ll check my service bulletin books too. Didn’t think to try any of those. Whitaker and I spoke behind the scenes about this and I told him to see if anyone out there as run into this issue. Seems like not a lot of us have. But then again, how many MJs are on here with tow mirrors? -
No problem. That’s why we’re here for. Hopefully the mech gauge will reveal a healthy engine.
- 25 replies
- guage
- troubleshooting
(and 1 more)
Tagged with:
Fair enough. But yes there are two different parts available. The switch, which you currently have and the sensor. The switch is for the idiot light cluster and the sensor is for the gauge. It probably didn’t help that the PO didn’t get the right part in the first place which sent you on this mad tangent. Here is what the correct sensor should look like: I kinda forgot we had one on hand here at work.
- 25 replies
- guage
- troubleshooting
(and 1 more)
Tagged with:
56026782AC is the oil sensor part number. Still available from Chrysler. It sounds like the PO probably thought it would swap over and all would work. Course that asks a new question. Does the water temp reflect any data or does it just stay at the first bar?
- 25 replies
- guage
- troubleshooting
(and 1 more)
Tagged with:
What he hasn’t mentioned about this kit yet is it’s one of those dealers choice kits from the parts and service division of American Motors. In the middle of the package is that logo. It’s a really neat kit. I don’t think they’re Marchals though.
Yup!!! That’s the switch. As stated you need the sensor which can be had from Chrysler or aftermarket I’ll get a part number here in a minute for you.
- 25 replies
- guage
- troubleshooting
(and 1 more)
Tagged with:
Have you done any of cruisers tips? Have you cleaned the contacts on the starter relay? Yeah these gauges aren’t the best in the world but I got mine to read damn near accurately by just cleaning every contact. And I do have the same cluster as you.
The switch is switched on when there’s a certain amount of pressure and it keeps the light off. When there’s low pressure the switch turns off and the light circuit grounds out and turns the light on. The sensor will read accurately. Do you have a short little stubby thing or a big fat sensor?(or tall and skinny, depending on the sensor you bought)
- 25 replies
- guage
- troubleshooting
(and 1 more)
Tagged with:
Well there isnt a power steering gauge. How it works is a sensor screws into one of the lines and sends info to the ECU based on the pressure from the power steering system. As the pressure decreases, the idle increases to accommodate steering assistance to the driver. As pressure increases, the idle calms down from the lack of demand for steering assistance(I might have this backwards. I am going to go double check). I am sure you probably can get some plugs, I have never looked into it so I can't point you in the right direction with those. Ok I am right on the operation and its a switch, not a sensor. From the 2.5L operations and diagnosis manual: "The power steering switch is an input to the ECU via the air conditioning select and request input lines(My MJ did not have AC from the factory but had power steering so it still operated in the same manner just no AC which I now have haha)When the power steering pressure exceeds 275 psi ± 25 psi(19.6 bars ± 1.7bars), such as at idle during parking, the power steering switch closes to inform the ECU to raise the idle speed."
Ahh. The second one that is two flat blade connector is for the low washer fluid sensor. Unless you have an XJ or know your way around wiring the circuit together, our MJs don’t have the option.
Power steering pressure sensor Auto trans TPS plug Ground plug for cruise control.
Well it’s more of a hose that the intake uses to take in the fuel fumes from the tank that go into the canister. It doesn’t entirely affect anything but it does help get some extra fuel fumes.
So the one tube you’re holding by the firewall goes to the charcoal canister for the gas tank. The other one went to the air box lid. I can post a pic of my engine bay as it is stock as a stock Renix 2.5L can be if you need a reference.
*C1 -Y6 DARK SAND 115 Zone 15-Chrysler Corporation-Misc 1AS U.S. Miscellaneous Special 3AG Price Protection - Code G 3V2 Customer Preferred Discount 4BA Company Car Tracking 4E1 Assembly Plant Tracking 4HA Special Scheduling Condition I ALM APA Monotone Paint ARL BAF 130 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ Dana 35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3R STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED CC PRI PNT - HE4 QE4 COLORADO RED CC SEC PNT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires TZH Michelin Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YAL Executive Lease Program YAN Active Lease Vehicle YBB Tag Instructions YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z82 Right Front Spring Group XI Build date 10/10/90 Body code JL61 Sold by FCA US LLC, ORION TWP. MI This MJ has a recall open for the front disks.
*C1 -SA CHARCOAL 121 Zone 21-Canada-Ontario 1AB Canada Dealer Retail 3N8 ACC ADL Skid Plate Group APA Monotone Paint ARL BAP 75 Amp Alternator BCC Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpet DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ Dana 35 Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JDB 180 KPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K27 Do Not Use K2B STRIPE/BADGE/MOLDING/COLOR K3G STRIPE/BADGE/MOLDING/COLOR KKS STRIPE/BADGE/MOLDING/COLOR KWS STRIPE/BADGE/MOLDING/COLOR LBC Glove Box Lamp LMA Halogen Headlamps LMK Daytime Running Headlamps, High Beam MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon NHK Engine Block Heater PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBB Full Size Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires TZH Michelin Brand Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAC Build To Canada Mkt. Specifications YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 2/17/91 Body code JL62 Sold by HOWES REEVES LIMITED, FERGUS ON
