13
*D1 TRIM STYLE D1 - CLOTH BENCH -SA Charcoal 163 Zone 63-Dallas 1AA U.S. Dealer Retail 5AL ADH Heavy Duty Electrical Group APA Monotone Paint BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpet CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHT Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDA STRIPE/BADGE/MOLDING/COLOR LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PE4 COLORADO RED PRIMARY PAINT - HE4 QE4 COLORADO RED SECONDARY PAINT - HE4 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAD HIGHWAY TREAD TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGE 5 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 5/30/89 Body code TL61 Sold by EL DORADO JEEP-EAGLE, MCKINNEY TX
*X1 -YY 3LW ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group AGP APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PE4 Colorado Red QE4 Colorado Red RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJN 15" Aluminum Wheels Build date 6/13/88 Body code JM61 Sold by MARIETTA JEEP INC, MARIETTA GA
*A6 Seats - Vinyl High Back Bucket -Q8 3LU AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBF REAR BUMPER - STEP TYPE (BRIGHT) MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) PXF QXF RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT TBL TIRE CARRIER - INSIDE WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 10/19/86 Body code JM61 Sold by LEE JEEP EAGLE, MABLETON GA
What’s wrong with the one you have? Is it reading low, reading inaccurately or not at all?
Yes you can swap the speedo with no issues as long as the housing is the same.
AC Expansion Valve Retrofit Question
eaglescout526 replied to ktmall07's topic in MJ Tech: Modification and Repairs
I mean it’s sounds tedious but you should be able to just swap parts around. I can’t imagine Chrysler having a kit that is completely different than what the factory got. I know the major difference between factory and dealer is the liquid hose has a muffler on it. -
I’m very curious about such a kit if Chrysler even offered one. Anywho, I’ll do a bit of digging in the parts catalog and throw a part number your way for the expansion valve. Should give you a good lead. -
It looks very similar to other dealer installed set ups I’ve seen. But curious since it is an HO. Didn’t think Chrysler offered a kit for the HO….it is the 92 one in your signature correct? Yes, any valve ought to work, I just hope there’s one out there that will line up with the lines as the modern ones are the aluminum block. -
That kinda looks like it would’ve been a dealer installed set up. The dealer kits used that expansion valve. You should be able to use a standard valve vs that one as it is for R12 probably unless it was converted at some point. -
Dash differences I've noticed
eaglescout526 replied to Classy Comanche's topic in MJ Tech: Modification and Repairs
Just needs a little love but that’s cordovan. To find the brighter garnet red, it’s gotta be an 86 or early 87 MJ. Gotta love he fun color options we got robbed of for more sophisticated 90’s options. -
Yeah grey, cordovan and tan were the colors of interior. Chrysler really sucked in the 90’s. -
On the XJs, it is the other way around. Members on here have found more tan interior XJ's than grey. We think Grey was a common MJ interior while tan wa s acommon XJ interior. If youre seeing lots of black interior(course you could be referring to other MJs), you should be snagging those parts. Everyone wants to convert to factory black without painting their parts. Black was only available for 86-87 MJs and XJs so its a harder color to find aside from the early 84-85 XJ interiors. -
Cranks but won't stay running.
eaglescout526 replied to TheSiLvAPython's topic in MJ Tech: Modification and Repairs
It is?! Well shoot. I am a fortunate soul to have an 88 produced without it. Either way I feel we have helped the PO get closer to his issue. -
Yeah it could be. Know any history on the truck? Like has the fuel system ever been serviced? -
Absolutely. Or delete the ballast all together honestly. It’s a “fix” that Chrysler did to “quiet” down the fuel pump. It was more applicable to the XJ than the MJ but they are prone to breaking and overheating which leads to failure. Bypass it and drive it around all day. -
So what’s happening is when the key is switched to the on but not start position, the fuel pump ballast is bypassed to prime the fuel rail. If this is correct, your engine should be cranking, fire a couple pistons and stop because now the fuel pump ballast is no longer being bypassed during crank. If the ballast hasn’t been bypassed or replaced, your truck won’t run longer than a second. -
Woot!
What in the world did I just find???
I’d frame and hang the Jeep decal. -
Awesome! Hopefully we didn’t hijack the thread too much. -
He is alive!!! Hahahahaha I actually wasn’t expecting you to respond right away. But hey I’m glad you still have them. I don’t mind doing that, that being said, the cluster he said he found will have to be the one that will take those tachs. When you get them done, you’ll have to school me on those so that way I can collect and fix them. -
The ones that are plug n play with 87-90 are very very rare as they were in 87 only Jeeps. 84-86 got them but they have the different speedo but they are getting increasingly rare too. Just the tachs die from the old components on the board. I wish I knew how to fix them. I sent a couple off to a member on here but that was almost a year ago. I think @scaleless got them. -
Now if you really really want to be classy, gotta find a full gauge cluster like the 5/6 cluster in the middle. Course you have to be mindful of the speedometer connection. -
Best way to tell which 5 speed is to crawl under and take a look. If the case is mated together like a clam shell, it is the BA10/5. If it looks more like a traditional trans case, it is the AX15.
