eaglescout526
Administrators
    13
  1. *ZZ -ZZ ADA LIGHT PACKAGE AGY Seating Group AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWB SPORT BAR NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAB Radio - AM/FM SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 9/18/85 Body code JM62
  2. Those look familiar. I think they will be going on a certain XJ soon hahah.
  3. Don’t forget to check your fuses.
  4. I’d hold out on the conversion. It sounds like an upsale and to get more money from you.
  5. You’d have to get the HO cluster, sending unit and speed sensor. It’s straight forward when you have he donor Jeep.
  6. I may be wrong, but that lip should be more straight.
  7. I saw that on a later XJ last night. Looks like a good upgrade for Renix 2.5Ls. Huh. Interesting. I mean I had one crack from service and looks like someone had tightened it down too hard at one point. But that’s about it. I’ve had good luck with mine.
  8. It would be on the passenger side of the engine bay.
  9. No problem. They also are used for cruise control, which isnt installed.
  10. Theyre GM vacuum reservoir cans. AMC used them from 84-86 and GM used them until they were obsolete. So all theyre doing is providing vacuum to the fuel vapor system and your HVAC duct controls.
  11. Yes it is a 3 speed. Chryslers code ironically for their own transmission probably wasnt the same code on AMCs side orrrrr Chrysler wiped the code out for use with 4spds going forward after the torqueflights discontinuation.
  12. Really? Those are the good plastic ones. The ones crown make are perfect to hold hardware in and thats about it. Well don't throw it away, if you do, ill give it a good home. Also 94-00 for the Aluminum cover. Good year range. I think I am on the trail of a mechanical cooling fan upgrade for the 2.5L
  13. Did your plastic cover have the AMC logo or did it feel like a cheap flexible plastic? metal valve cover 53010428->53010428AB=>05093783AA->
  14. I guess we are at a servo problem. Not much else to test. I have a few if you want to shoot me a PM.
  15. Caution with jeep air. If you buy their R134a fittings, they might come ovaled and prevent proper tightening.
  16. Probably a factory test for precision and accurately working.
  17. No there really isn’t. I think one side of the bumper itself has a longer tab to compensate for the curve of the bumper and look flush but that’s it.
  18. Crown makes them if you arent looking for OEM specifically.
  19. When Fran had this MJ, I did not see a sport ever nor did he have one. But the buildsheet would show the sport bar code too. So you’ll have to drill the holes and install it.
  20. They’re called weather pack connectors. GM loved using them in the 90’s.
  21. That’s good. No cracks in your line anywhere.
