13
no parking lights or gauge lights
eaglescout526 replied to cpacker208's topic in MJ Tech: Modification and Repairs
Running Renix still or Chryslers HO system? -
Need Source For Jeep Liberty Advice
eaglescout526 replied to AZJeff's topic in MJ Tech: Modification and Repairs
Lol what did I say. Well glad it’s a 404 and not a log in screen -
I’d keep an eye and ear on it for a bit. But it sounds like you’re fine.
Redlined the 2.5L huh? Well at that speed the valves wouldve been floating and not opening and closing given how fast the RPM was. Now if you were running it at that speed for longer than what you did, youre probably fine and I would do an inspection just to make sure. Does the engine sound fine? I would be only worried about the valve train and timing chain in this instance. Maybe the distributor too.
I am not seeing anything in terms of maintenance to the timing. I did find this: MEASURING TIMING CHAIN WEAR 1 - SECONDARY TENSIONER ARM 2 - SECONDARY CHAIN TENSIONER PISTON NOTE: This procedure must be performed with the timing chain cover removed. Remove the timing chain cover (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT/CHAIN AND SPROCKETS - REMOVAL). To determine if the secondary timing chains are worn, rotate the engine clockwise until maximum tensioner piston (2) extension is obtained. Measure the distance between the secondary timing chain tensioner housing (Measuring Secondary Timing Chains For Wear) and the step ledge on the piston. The measurement at point (A) must be less than 15mm (.5906 inches). If the measurement exceeds the specification the secondary timing chains are worn and require replacement (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT/CHAIN AND SPROCKETS - REMOVAL). DO NOT CLICK THE LINKS, THEY WILL TAKE YOU TO THE SERVICE LIBRARY IN WHICH NO ONE WITHOUT DEALER CLEARANCE CAN ACCESS. -
You’ll probably get a lot of flak for modifying an original roll bar that no one makes. Have you tried seeing if there’s anyone out there who has a short bed that needs a long bed one?
I can check the service library if you’d like. -
91 Pioneer Stripe Decal
eaglescout526 replied to Gary from Texas's topic in MJ Tech: Modification and Repairs
Ok. The HO pioneer decal has been secured. As soon as I get it I will call Phoenix graphics and get it sent so they can duplicate it and hopefully the HO guys can have the proper decal to put on their MJs. -
That’s not a D44a is it?
None of the evap system would stop the tank from filling to capacity unless it’s really that pressurized but even when filling all the pressure is released to accept more gas into the tank. Now there is another issue I thought of, there was a member on here a while back who had an issue like this and they found the float on the sending unit lost is buoyancy and stopped floating above 3/4 of a tank. This is a possible problem you could be having.
Selling your Comanche. Do you regret it?
eaglescout526 replied to Classy Comanche's topic in The Pub
That’s every story with every car. You’ll even get it with new fresh off the lot cars. It’s discouraging but the reward of powering through the fixes is worth it along with the challenge and testing of your mettle. I had a kid younger than I who owned a newer XJ this past Saturday totally fall in love with the MJ and got really shocked to see a 4cyl under the hood vs the 4.0. That actually made my day to see someone younger than I appreciate the classic obscure Jeeps. -
Chunk, A 1984 XJ
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
Front bumper is off, tow hooks installed, just waiting on the front support brackets to show up so I can get this buttoned up and have the bumper installed. While I was in here I tore down the original bumper to paint it up and drill a couple holes for the front bumperettes...wellIll I somehow screwed up when drilling the second hole and drilled it farther from my original marking, not sure how I did that. Luckily when I got MJCARENAS parts stash, he had a front bumper predrilled, yes I should have just swapped bumpers but the problem was is that the bumper was a badly spray painted blue. So more work wouldve been involved at first vs drilling a couple holes. See my logic...so now the newer bumper is set up and ready to be installed. I am pretty satisfied with how it turned out though. Some rustoleum rust reformer as a primer/way to cover the blue paint and finish off the landau black to have the finished product on the hood. Even sprayed the back side of the marchals to make them look nice. Also got the aftermarket hitch assembly off. Got a NOS AMC one to toss on along with the appropriate wiring harness selection for it. That hitch was a blast to take off. Nothin like destroying rusted hardware to get the damn thing off. Almost dropped the gas tank to use a cut off wheel only to remember that I have nut splitters that can do the job more effectively. Also I hate the idea AMC came up with to mount the rear bumper, sure its highly effective but you gotta get a small wrench or ratchet up in between the mount itself to remove the top bumper bolts. Fun times, hopefully I can get it off, put on the NOS mounts and get the tire carrier on. -
Yeah I can't imagine it being a newer Chrysler code. Its got to be an AMC/Chrysler code for when the customer wanted an MJ without the decals.
I have never seen that description before. This wouldn’t surprise me if this was a custom order thing.
*X4 -Q8 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DCK 4SPD MANUAL TRANS EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PB3 QB3 RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 2/21/88 Body code JM61 Sold by WILLIAM CLARKE JEEP-EAGLE, FREDERICKSBURG VA
*X1 -SA Charcoal 3LY ADL PACKAGE - 4X4 PROTECTION AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PS4 QS4 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE WJN 15" ALUMINUM WHEELS Build date 3/21/88 Body code JM61 Sold by ZIMMERMAN JEEP-EAGLE, FREEPORT IL
*X1 -H9 3LX AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black NAA ESA W/CATALYST (EXC CALIF SYSTEM) PS4 QS4 RAB Radio - AM/FM SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE TBB CONVENTIONAL SPARE TIRE WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 6/22/88 Body code JM61 Sold by HILLVIEW MOTORS INC, GREENSBURG PA
*B1 TRIM STYLE B1 - CLOTH & VNL BENCH SEAT -YY AGC APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL KD8 DELETE TAPE STRIPE COLOR SEPARATION LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PYB QYB RAC RADIO - AM/MTR SBA POWER STEERING TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 5/6/88 Body code TL61 Sold by RICHARD KELLEY BUICK INC, GAINESVILLE FL
*X1 -Q8 3LV ADB PROTECTION GROUP PACKAGE ADL SKID PLATE GROUP AGJ Driver Assistance Group AHL HEAVY DUTY INSUL PACKAGE APB TWO TONE PAINT PACKAGE - I APC TWO TONE PAINT PACKAGE - II BCQ Battery - Maintenance Free CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual DMR 3.07 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS LNJ Fog Lamps MBF REAR BUMPER - STEP TYPE (BRIGHT) MCA FRONT BUMPER GUARDS MCB MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAF HIGH ALTITUDE EMISS CONTROL PKG NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL PXB QXG RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBB CONVENTIONAL SPARE TIRE TBL TIRE CARRIER - INSIDE WJM Wheels - 15 x 7.0 Chrome XJH LOCKING FUEL FILLER CAP Build date 2/3/87 Body code JM62 Sold by KRAYNC MOTOR COMPANY, PRICE UT
*ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADE COLD WEATHER PACKAGE ADL SKID PLATE GROUP AHL HEAVY DUTY INSUL PACKAGE BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR DGF H D A904 AUTO TRANS DMN 4.78 Axle Ratio EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 20 GAL FUEL NHK ENGINE BLOCK HEATER NMB ENGINE COOLING - STANDARD DUTY RAC RADIO - AM/MTR SBA POWER STEERING SUA TILT STEERING COLUMN WJD WHEELS - 15 X 7.0 STYLED STEEL XEA TOW BELTS Build date 11/5/85 Body code JL62
*ZZ -ZZ ADA LIGHT PACKAGE ADB PROTECTION GROUP PACKAGE AGY AHL HEAVY DUTY INSUL PACKAGE AJZ AWH POWER EQUIPMENT GROUP AWJ Visibility Group BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CUF FULL LENGTH FRONT CONSOLE DGK Transmission - 3-Spd. Automatic EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LDA UNDERHOOD COMPT LAMP LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWF BOX SIDE RAILS NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHB AUX./H.DTY TRANS OIL COOLER NHM AUTO SPEED CONTROL NMC MAX ENGINE COOLING RAF RADIO - AM/FM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJM Wheels - 15 x 7.0 Chrome Build date 7/10/86 Body code TP62
