eaglescout526
Administrators
    13
  1. Hahaha it sure looks that way!
  2. Look at all the fun I am having!! This has been a challenge, the pass side of the bay is cleaned up and rid of the ECU wiring. Currently what you see is the FI starter relay in place to test what remains of the main harness and it along with power still works and gets to the cab and front lights. Now the drivers side is the fun. I worked on de-pinning the diag port which FYI are Molex connectors and the same connectors for the Renix diag ports. Both ports are de-pinned and fished through the main harness and separated. The only things I have had to cut are ECU related wires out of splices, no terminals have been cut to make things easy for this, I am being thorough and clean so if I want to put it all back with minimal work. Next I have to unplug the C100 and remove any ECU pins there which I believe is just power related wiring and get it prepped for Renix. I also snagged a distributor from my spare 2.5L as I forgot this one has the vac advanced one for this set up and I can't use that with the FI. Fun fact, Renix era distributors look to be sourced from Ford as the one I have says Motocraft and has the original AMC part number and serial number tag on it. Also learned I will need to get a new starter. Had to do some digging on why that is and it seems to be based solely on the type of fuel system. I didnt think this would be a problem but when I started getting sparks from the starter wire and compared it to my MJ, I concluded I will need to get the FI starter. Fun times to be had!
  3. I have one of the older ones. My wife has the XJ one.
  4. Like I said, vintage has the last two let. Shoot me a PM if you want to go that route.
  5. No problem. If your temp climbs, then you know you have damaged the water pump, same with power steering and AC if you have those. As long as its just accessories your having to replace, I say youre in the clear.
  6. I say you’re fine. Just keep listening for other odd sounds.
  7. Ok this is weird. They have the lower brace but not the upper two. Nut (Radiator Brace) | Crown Automotive Sales Co
  8. I had found them once as aftermarket....Now I can not seem to find them. There are 2 left as NOS at vintage.
  9. The ones the 2.5L/2.8L radiator rest on/bolt to? Yeah, crown makes them new, they’re called well nuts.
  10. Sounds good. Vacuuming will remove any and all moisture in the system before being charged.
  11. Make it the last thing you install. But yes it’s fine to be exposed to the atmosphere for a bit considering the system is already exposed. As long as you get it charged soon or aren’t in a incredibly humid climate, you’ll be fine to leave it for a while. But if you are, get it installed and charged as soon as possible to avoid any issues.
  12. Yes. It should be. When I did mine I didn’t know this bulletin existed, so I got the new dryer and compressor, everything has been fine so far.
  13. It’s more for the 134 pressure so the system knows the right pressure to cut off at vs 12. But yes it’s necessary. You’ll get it with a new dryer and you’ll need to get a new switch which looks the exact same as the older one. Hell the older one will probably work just fine but that’s your call. There really wasn’t a part number for a 134 switch. The catalog just shows one switch and it’s one part number until 1990.
  14. Well you should replace the dryer if your converting to 134. But if you’re going back to 12, then you shouldn’t have to do anything.
  15. I haven’t seen this MJ around town. Nice to see another one pop up. I’ll get your build sheet tomorrow afternoon.
  16. Like the title says, I am after an OEM or OMIX rear bumper. Crown sucks at making the parts that are key details to our jeeps. Anyone have an XJ rear bumper laying around?
  17. Anyone notice the WJ lower control arms?
  18. Have you recently swapped clusters from lights to gauges? Cleaned your grounds too?
  19. *M5 PREM CLOTH HI-BACK BUCKET SEATS -KG CAMEL/DK. GREEN 00S FAM: TJ TRACKING: 00713J06 MY:2001 122 ZONE 22-CANADA-QUEBEC 1AB CANADA DEALER RETAIL 24V Customer Preferred Package 24V 2TV Customer Preferred Package 2TV 3K6 Automatic Transmission Discount 3UA Customer Preferred Discount 4CP FEDERAL A/C EXCISE TAX 4EA SOLD VEHICLE 594 Vehicle Order Tracking 5I4 Four Wheel Drive (4WD) 5I8 Left Hand Drive Vehicles 5IS TJ-Vehicle Family 674 EQUIP. REQMT. - QUEBEC 6CS LABEL - CANADA SPECIFICATIONS 6X9 Paint Order Code A23 4.0L ENGINE(ERH)/3SPD AUTO TRANS(DGG AAC STEERING GROUP AAS TIRE &&&& WHEEL GROUP - 30" ADC CONVENIENCE GROUP AEM DUAL TOP GROUP W/MATCHING COLORS AFG Fog Lamps and Tow Hooks Group APA MONOTONE PAINT BAU ALTERNATOR - 117 AMP BCE BATTERY - 600 AMP MAINTENANCE FREE BGK BRAKES - 4-WHEEL ANTI-LOCK CAD SEATS - HIGH BACK BUCKET CAG EASY ACCESS PASS TIP &&&& SLIDE SEAT CDB SEATS - RECLINING FRONT CFM SEAT - REAR FOLDING CGW AIR BAGS - NEXT GENERATION** CGZ AIR BAG ON/OFF SWITCH - PASSENGER CK9 COWL SIDE CARPET CKE CARPET - FRONT SEAT AREA CKF CARPET- REAR SEAT/WHEELHOUSE/CARGO CKT CARGO TIE DOWN LOOPS CLC FLOOR MATS - FRONT CLS SPORT BAR W/REAR PADDING CUF CONSOLE - FULL LENGTH FLOOR DGA TRANSMISSION - 3-SPEED AUTOMATIC DGG 3-SPD. AUTOMATIC 32RH TRANSMISSION DHA TORQUE CONVERTER - LOCK-UP DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJJ Axle - Front, Dana 30/186MM DME AXLE RATIO - 3.73 DRJ DANA M35/194MM REAR AXLE DSA TRAC-LOK DIFFERENTIAL REAR AXLE EAA ALL ENGINES ERH ENGINE - 4.0L POWER TECH I-6 GBB WINDSHIELD GLASS - TINTED GCB LIGHT TINT FRONT DOOR WINDOWS GCD GLASS - HRD TOP DEEP TINT SUNSCREEN GCF DOOR - FULL METAL W/ROLL-UP WINDOWS GFA DEFROSTER - REAR WINDOW GRV MIRROR - LEFT MANUAL GSV MIRROR - RIGHT MANUAL GTV SWING-AWAY MIRRORS GVA ALL VEHICLES W/O POWER MIRRORS GXX SENTRY KEY THEFT DETERRENT SYSTEM HAA AIR CONDITIONING ID2 Route D2 - CP, Montreal JAY INSTRUMENT CLUSTER W/TACH JDB SPEEDOMETER - 180 KPH PRIMARY JHA WINDSHIELD WIPERS - VAR INTERMITTENT JHB WIPER/WASHER - REAR WINDOW JJA LIGHTER - CIGAR JJB HORNS - ELECTRIC JKA GLOVE BOX - LOCKING K5X EXTERIOR COMPONENT COLOR KBT PEARLSTONE/TAN/F. GREEN/RED - DECAL KVP LT. QUARTZ - BADGE - TJ KWP LT. QUARTZ - BADGE - JEEP, LOWER COW KYP LT. QUARTZ - BADGE - 4.0L LBB LAMPS - COURTESY LDA LAMP - UNDERHOOD LMA HEADLAMPS - HALOGEN LMK HEADLAMPS - DAYTIME RUNNING LNJ FOG LAMPS LPS LAMP - CENTER HI-MOUNT STOP MB5 BUMPER - REAR BLACK MBA BLACK FRONT BUMPER MCH BUMPER EXTENSIONS MFP HEADLAMP BEZELS - CHROME MFR FRONT FRAME OVERLAY - BLACK MFT GRILLE - BODY COLOR MRJ STEPS - BODYSIDE MWB SPORT BAR W/SIDE PADDING NAS EMISSIONS - U.S. 50 STATE NBK EVAP CONTROL SYSTEM NBV EMISSIONS - LOW (LEV) NF1 FUEL TANK - 19 GALLON W/TETHERED CAP NHK ENGINE BLOCK HEATER NHM SPEED CONTROL PX8 BLACK CLEAR COAT QX8 BLACK CLEAR COAT RAA ALL RADIO EQUIPPED VEHICLES RBR RADIO - AM/FM COMPACT DISC RCS SPEAKERS - FIVE, INCLUDING SUBWOOFER RDD ANTENNA - FIXED SBA POWER STEERING SCG STEERING WHEEL - LEATHER WRAPPED SDU HIGH PRESSURE GAS CHARGED SHOCKS SHA STABILIZER BAR - FRONT SHC REAR STABILIZER BAR SUA STEERING COLUMN - TILT TBB SPARE TIRE - FULL SIZE TBR TIRE CARRIER - OUTSIDE TUS 30X9.50R15LTB WRANGLER OWL A/T TIRES TZA GOODYEAR BRAND TIRES VJT DARK TAN SOFT TOP VKT DARK TAN HARD TOP WJX WHEELS - 15 X 8.0 ALUMINUM WKB WHEEL - MATCHING SPARE WLZ WHEELS - ALL ALUMINUM XCY UPGRADED OBD-II CONNECTORS XEE SKID PLATE SHIELD - FUEL TANK XEF SKID PLATE SHIELD - TRANSFER CASE XEW 2 FRONT &&&& 1 REAR TOW HOOKS XJF FUEL FILLER CAP - TETHERED XLR Language - French/Canadian XPF PROTECTIVE COATING AND REMOVER YAC BUILD TO CANADA MARKET SPECIFICATION YGA WITHOUT BILLABLE FUEL Z5B GVW RATING - 4450# ZAV SPRING - LEFT REAR ZBG SPRING - LEFT FRONT ZNV SPRING - RIGHT REAR ZPG SPRING - RIGHT FRONT Build date 4/26/01 Body code JP77 Sold by PAT ABINEY CHRYSLER DODGE JEEP, DOWAGIAC MI Yup is Canadian. It should have some TJ decals on it some where as GM had a Wrangler up there prior to AMC introducing the wrangler in the states.
  20. I would say that cluster has been swapped, its a Sportruck which is almost damn near if not base. It wouldve had an idiot light cluster. The biggest thing that gives the cluster swap away is the black bezel with the black gauges. That gauge cluster comes with a grey bezel to offset the black. So someone rolled the odo back to match the old cluster. It probably is right though.
  21. *E1 CLOTH BENCH SEAT -SA Charcoal 165 Zone 65-New Orleans 1AA U.S. Dealer Retail 5AM 5KN ALN APA MONOTONE PAINT BAY 105 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPETS - FLOOR AND CARGO AREA CSR PASSENGER ASSIST HANDLES DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DGS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHA LOCK-UP TORQUE CONVERTER DHT SHIFT-ON-THE-FLY,P/TIME T/CASE DMD 3.55 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEH FIXED DOOR VENT GLASS GFD REAR SLIDING WINDOW GNA REAR VIEW DAY/NIGHT MIRROR GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HAA AIR CONDITIONING JAA INSTRUMENT PANEL JAZ DO NOT USE - SEE JP, KA CLASSES JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH PRIMARY SPEEDOMETER JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER JKB K2X STRIPE/BADGE/MOLDING/COLOR K3D STRIPE/BADGE/MOLDING/COLOR KKE LAF SEAT BELT ALERT-DRIVER SEAT ONLY LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ MDA Front License Plate Bracket MFG Headlamp Bezels MHA Black Windshield Moldings MMC MMG Belt Moldings MMK NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PS3 DOVER GREY MET CL CT PRIMARY PAINT - HS3 QS3 DOVER GREY MET C C SECONDARY PAINT - HS3 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE TBC Compact Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJM 15X7.0 Chrome Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Build date 6/11/89 Body code TM61 Sold by GLYNN SMITH JEEP, OPELIKA AL
  22. Welcome!
  23. *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS LNJ DUAL ROAD LAMPS MBJ Bumper - Front, Black MCA FRONT BUMPER GUARDS MCB MD8 Delete Front License Plate Bracket MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 11/24/85 Body code JM62
  24. *ZZ -ZZ AJY Popular Equipment Package CGX Head Restraints-Outboard Seating, RR DDJ 5SPD MANUAL TRANS A881 (JA-41) EPD ENGINE - 2.5L I4 TBI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAE EMISS CONTROL TESTING LABEL NFA TANK - 23 GAL FUEL P99 NON - RELEASED PAINT (SPECIAL) RAC RADIO - AM/MTR SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE Build date 11/15/85 Body code TM62
