Project “Tomahawk”
ghetdjc320 replied to ghetdjc320's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Yeah, the axle tubes and pumpkin are pretty clean but the knuckles are rough. I have a set of pre-90 knuckles going on this along with my big brake setup. Taking the housing down to blast today. -
Project “Tomahawk”
Stripped down the HP30 today. Plenty of rusted bolts to get loose. also got in some frame reinforcement parts. along with door hinge and striker reinforcement plates. -
Project “Tomahawk”
The largest possible brakes that can be fit under a Turbine wheel. Much larger than anything ese on the market. 12.10” rotors and dual piston calipers: -
rear floor pan replacement question
ghetdjc320 replied to ratrapp's topic in MJ Tech: Modification and Repairs
I saw this picture in a post recently and saved it since it appears the poster replaced the back pans with something from Key Parts. Likely XJ floor pans cut down but the OP would be the one to ask: -
How fast is is fluctuating? Is the gauge fluttering? Often times I would see the gauge drop down when accelerating after a a short time idling.
Bump. Still in need of a good tailgate
Waggy F44, Isuzu R44
ghetdjc320 replied to WVpioneer_88's topic in MJ Tech: Modification and Repairs
Depends on the year of the axle for the pinion yoke size -
The tailgate on my mj is borderline unusable. It’s been almost destroyed by the PO. Needing nice clean and straight tailgate for my build. It will go to a good home for sure. Let me know what you have. Thanks
Project “Tomahawk”
Quick Draw bellhousing conversion kit in along with clutch kit. This is a super nice setup for an ax15 to LS conversion. This uses the Jeep external slave cylinder, throw out bearing and fork with the GM LS truck style clutch and flywheel. @Limeyjeeper -
Project “Tomahawk”
3.25 here. 5.59 on Guam so I’m loving anything under $5
Project “Tomahawk”
I’ll pull the stock buckets here next week and set the brackets on for reference. Working on getting the shop built at the moment -
High Altitude CPS—Renix 2.5 Question now
ghetdjc320 replied to 89 MJ's topic in MJ Tech: Modification and Repairs
Thanks -
Project “Tomahawk”
Will adjust if needed. Have to see how the trailcats sit on them. What seats were you running on these? If anything I may slightly lower the rear of the seat. I really don’t like the lack of knee support on the stock seats though. -
89 Comanche Dana 30 Hub Bearing
ghetdjc320 replied to NC Toy Boy's topic in MJ Tech: Modification and Repairs
Unit bearings from 90-99.5 should all have the same offset and lug stud length. Later models had a different offset and rotor but can also be swapped together. They also have longer wheel studs. Pre 90 is a mixed bag but the unit bearing 3 bolt pattern is the same through all the years. Knuckles can be swapped back and forth as well with the accompanying mods -
@cruiser54 do you happen to recall the degrees of advance that cps is good for? I was thinking 3 or 6 but don’t remember -
Aftermarket repair parts. Whats new?
ghetdjc320 replied to camjeep3's topic in MJ Tech: Modification and Repairs
I bought a set of replacement fenders from C2C. They have an econo and an oem line. The oem line run about $150/ea but they are a good fender. Fitment is really nice as is the thickness of the material used. I bet that they are made in the same factory as Key Parts (Taiwan). -
Control Arm Drop Kit Question
ghetdjc320 replied to Warren99's topic in MJ Tech: Modification and Repairs
Your drag link angles are quite steep it seems from the pics. The Comanche control arm brackets are not identical to XJ brackets. There is extra reinforcement to them that is not there on the XJ. Rock road suspension makes a set that works. I think there are one or two others as well. The cheapest alternative I could think of here is to lower you lift back down to whatever your control arms are designed for. I believe those tubular fixed lowers are for possibly a 4” lift max. Mid lifting an MJ that handles like stock is quite a task -
Rear slider window seals and felt
ghetdjc320 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
Yes I got mine. It’s a very different fit from the original but looks very good in the end. The CR Laurence screws in from the inside of the cab in a few areas. You have to really have a good clean window opening for it to sit flush in. The frame is aluminum and can bend a bit to fit nice and flush. The instruction only call for using butyl tape to seal it. That’s what I did at first but I had small leaks. I took it all back out and reinstalled it with urethane and didn’t have any leaks after even with the pressure washer. The CR Laurence unit looks a little bigger and has a larger opening than the 3 pane oem unit. It also eliminates the rubber trim around the oem unit. These guys seem to have it in stock: https://www.dkhardware.com/duo-vent-four-panel-slider-with-solar-glass-for-1986-1992-jeep-comanche-edv700s-product-43373.html -
Project “Tomahawk”
Corbeau brackets came in today. I had never seen a picture of the Comanche specific brackets but here they are: -
Project “Tomahawk”
Not sure, will pick it up over the weekend. It’s an 06 KJ -
Project “Tomahawk”
Still sorting out axle availability. My local junk yard doesn’t give me the time of day so I had to widen my search. Managed to find two yards in MO and going to make the run tomorrow. 3.55 8.25 liberty rear with disks and a XJ non disconnect HP30 with 3.55’s. Picking them up tomorrow -
Project “Tomahawk”
Engine has arrived. Along with some more goodies. GM LS swap oil pan kit for front axle clearance. also got a new manual tilt column, all black steering wheel, and a new boostwerks hidden winch/steering brace setup thanks to @Red Mistress! Dropped off an original MJ hitch, swb gas tank skid, transfer case skid, step bumper, bumper brackets and oem front skid to get blasted. Disassembly coming up soon. Getting some shop area prepped for the initial tear apart. First order from Novak arrived with headers, motor mounts, and all sorts of small swap parts. Painless stand alone LS harness also came in. Have a pair of Corbeau trailcats being made also with lumbar adjusters and heaters with the HD material option. Most big parts will be coming around mid May. The yard that I was getting my 8.25 from dropped the ball and ended up never pulling the axle. After being transferred several times and having to re-explain the situation I just gave up on them. Rear is now going to stay a Dana 35. I’ve built many a Dana 35 that can endure some serious abuse all while being very light weight. This one will get 3.73 gears, 1541 shafts (possibly 30 spline with arb). There are several trick to keeping the Dana 35 alive and happy. Axle tube flex is one, along with a good cryo treatment on the R&P. This axle will be running 31” BFG’s but 35’s are quite attainable and writhing the axles range. Axle clearance and unsprung weight are very good compared with to marginally larger tires on heavier axles
