Upper shackle bushing replacement
ghetdjc320 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
The shackles have a small divot on one side from factory that acts like a crimp to hold in the shell of the bushing. Once you get past that divot point they come out fairly easy -
Here is the leftover carnage. Keep in mind, I’m doing this out on the ground on a hot tropical island in the middle of nowhere lol. No compressor, no press. -
I bought a bushing kit several months ago for the rear leaf springs and it came with new upper shackle bushings. I was able to remove the leaf spring bushings by drilling several holes in the rubber and collapsing the outer shell of the bushing with a punch. Then you just pound it through to the other side. When I first removed the leaf springs, all the bolts had rust-fused to the inner bushing sleeve so they all had to be cut out. In the absence of a press and this being our only vehicle currently, I decided to crawl out under the truck and fix those shackle bushings which were very shot. After cutting out the bolt, I tried removing the outer bushing shell the same way as the springs but it would absolutely not budge. Very long story short, get yourself a stout chisel and chisel along the inside of the shell where the shackle is welded together (Don’t chisel into the shackle bore, just the bushing shell). Once you have that all broken free it will eventually pound out. A solid 1 1/8 socket fits the inner shell well and let’s you pound it out. Just be advised that this process take hours of beefing and pounding. But it can be done. A hack saw will do little good here since the shell is thick and most likely fused to the shackle bore.
Comanche taillights on ebay
ghetdjc320 replied to 88mjsally's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
About 3 days of deep searching will yield a single nos tail light. Or at least, that’s been my experience. You got to search out of the box and sometimes out of the country. Google doesn’t normally help you find obscure postings. Every once in a while you can get a nos one on eBay. You just need to know all of your part numbers that amc and Chrysler used. -
Grab a liberty 8.25 as @Pete M suggests. Especially if you only planning to run 33’s. That being said, I run 33’s on my d35 with revolution shafts, Detroit truetrac and TNT truss. Love the clearance and performance but I also know where the d35 weak points are. There was a custom rig I saw in an article featured a few years back running a built d35 and 37’s and he’d been running it for years. He had phenomenal clearance. The whole build was a super lightweight lcg concept rig. After having built and swapped several axles (d44’s, 8.8’s & 9”), I started to think that maybe he was onto something. The weakness of the d35 ultimately will come down to the ring and pinion. There is an aftermarket solution to pretty much every other shortfall of that axle. Chryo treating a good new revolution, motive or Richmond gear set increases the strength quite a bit. 30 spline chromo shafts are pretty stout. A good girdle cover will help relieve stress from the bearing caps. A nice truss will greatly reduce flex which tends to be the root cause of many failures.
Just to clarify, I wasn’t suggesting that anyone swap in a d35. It was just a side point that they are still producing them.
Bumper and misc
ghetdjc320 replied to Wounded_Fighter's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
He posted in our classifieds section a little while ago -
That’s a good guess. I’ll check that out in the morning (it’s dark here now and I don’t have a shop to work on it at night. Plus I’ve seen the huge centipedes that can land you in the hospital crawling around at night 😆). Headlight switch still works fine and from what I can tell, everything else does also. Haven’t had the parking brake light connected for a good while though.
Auto transmission issues '88 MJ Pioneer
ghetdjc320 replied to Lungshot's topic in MJ Tech: Modification and Repairs
Is it an aw4? -
Rear main seal damage.....
ghetdjc320 replied to Wounded_Fighter's topic in MJ Tech: Modification and Repairs
And make sure to use the tiniest possible amount of jb weld so you don’t create a high spot somewhere that will give you problems down the road. -
I’d still recommend a small dab of jb weld on that piece just to keep it in place. Take your time, clean up all oil in that spot, let the jb weld fully cure and install your seal per fsm. Should be good to go. As others have pointed out, it’s not on the “wet” side of the seal. -
Painting black door handles?
ghetdjc320 replied to 87MJJeep's topic in MJ Tech: Modification and Repairs
This may sound crazy but if you are good with a blow torch you can get them looking like new. You can also quickly ruin them this way so be careful. An actual heat gun works better. You just need to lightly and evenly heat the plastic. Make sure to remove your handle from the door first. Once the plastic looks like new again, hit it with some black plastic restore and it will Jeep it looking great for a long time. Lasts for quite a while and won’t peel or flake like paint -
Hello all, before I dig under the dash to find what this is or where it goes, I’m sure one of you has seen this and know exactly where it goes 😆. I was driving along and this piece fell out from under the drivers side dash somewhere between the parking brake and the regular brake pedal. Looks like an electrical contact for a switch of some sort.
Whatever the number is, ultimately it’s not many and there are fewer each year. I doubt a company would build new molds for it but maybe if they have the original molds??
Thin axle tubes, faulty plug welds (sometimes no plug welds) so the tubes spin, has a Dana 35 shape but is much fatter and gets hung up on rocks/mud, relatively tiny brakes, adds a lot of unsprung weight, it’s narrower which is really pronounced on an mj, ring and pinion are still not up to par with newer d44 components, cost in most places has skyrocketed, doesn’t have a dropout center section or preload adjusters which would help with gear swaps. Stock axle bearings aren’t that great either. If these axles could handle 37’s and 40’s in stock form I think they would be a good option. However, most people only throw on 33’s or 35’s which just isn’t enough to compensate for the cons in my mind. In stock form, they can’t handle 37’s. C clips are not really that big of a problem unless your snapping axle shafts. A super 8.8 handles 37’s but at that point just upgrade.
Interior trim is good to have and a lot is mj specific. Drivers side kick panel, sill trim, b pillar trim, trim piece below back glass, mj specific center console with e brake delete.
We’ve seen the same thing happen with our vendors here of repop parts. Tailgate handles, seat brackets, frame stiffeners, mud flap brackets, emblems and roll cage brackets have all come and gone in small batches. Lots of hype for us in the club but it quickly fizzles.
Have my doubts but would be nice if it did happen. The market just isn’t there for a big supplier. I don’t know how many MJs are still on the road but let’s assume half of the 160K +/-. So 80K. Out of those, how many are restorable or even projects? The MJ was a beater truck for so many just like the XJ. By the time people come to the realization that these trucks are rare, classics and are gaining in value, there will be very few left.
You do know dana 35’s are the base model axles in JLs and JTs now too right? They are a bit upgraded though. The one I still dislike as a swap candidate is the ford 8.8 lol especially for 33’s or even 35’s. These axle threads are never ending
No worries. Found a set on eBay I can use
I did 95% of the work stateside. But as with most projects, I keep working in it while here on island too
Sounds good. I’ll be at the dentist then but just shoot me a PM with your PayPal info and a pic of the knuckles. Thanks
I’d do $80 for the pair shipped in a large flat rate box (with lots of tape lol) if they’re the ones I need. Let me know
Sounds good, let me know what you want for them. Just to be sure, the top picture is the knuckle style I need. It doesn’t have the brake pad “wings” like the second picture.
Comanche Coin on ebay
ghetdjc320 replied to Pete M's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Wouldn't mind one if the price stays reasonable
