Dana 44 rear axle
ghetdjc320 replied to ComancheMadness's topic in MJ Tech: Modification and Repairs
Yes I’ll stand by that all day. Not saying the 8.8 doesn’t work at all but there are better options out there. The 8.8 Is also heavy and unsprung weight should play a factor in any build. The bottom of a 8.8 is flat and wide vs the single narrow lowest point of a d44. It will make a difference which d44 your are comparing since there are some variations. But xj/mj 44 is lighter and much better clearance than an 8.8. The 8.8 is just chunky. If you going to build a new axle, built a 44 or a 60 if need that. 8.25 is a good choice though for what the OP described and is a cheap junk yard swap. Tire width, rolling weight and driving style play a big role in how long an axle lasts. -
Dana 44 rear axle
If all you want to do is run 33’s i’d just run the d35 if you have the right gearing. A liberty 8.25 as Pete suggests is an easy swap though and probably cheaper than a 44 in most places. An 8.8 in my books is about as worthless as the exploders they come from. I’ve had 4 of them over the years and they are all boat anchors. Think of it this way, a 31” tire on a Dana 35 has about as much clearance under the pumpkin as an 8.8 with 35’s. On 33’s it actually has more! The 8.8 is a chunky axle but does not hold up well to 37’s and low gearing without breaking things. The axle tubes are thinner than a d35/44 and have been known to spin. The c clip axle design is not really the flaw to me. If you break a non c-clip axle there is also carnage left behind and you won’t get far. Full floating axles are the obvious exception. -
Mj console on eBay 240$
ghetdjc320 replied to jdog's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
@Minuit don’t feel too bad. I threw out my oem rear bumper and brackets. Didn’t have a single dent or drop of rust. Even still had the license plate lamps. -
The console insert is a separate piece also so if you could find one you could just install it in a good xj console. -
Rubber Windshield Molding
ghetdjc320 replied to WahooSteeler's topic in MJ Tech: Modification and Repairs
Agreed, that keeps it simple -
When I had my windshield installed i had them install the newer style 97+ gasket instead of that metal trim. Looks really good imho -
Dana 44 rear axle
96-97 rodeo/passport works great too. Same bolt pattern issues as the wagoneer axle though -
Just grab the fitting you need from a ZJ with a V8 (don’t think the V8 makes a difference). It will fit your pre 90 Dana 30 or the 90+ axles. The biggest difference on those pre 90 Dana 30’s is the knuckles. They had a different style caliper mount (which is a great platform for upgrading brakes). Just run to your local auto store or jump on rock auto and order the drag link, tie rod ends and adjusters from 98 Grand Cherokee. I suggest moog or precision products. You’ll have all new steering that is quite a bit beefier than the stock setup. Now that I think about it, your existing setup may be an inverted t style vs the newer y link.
Glamour shots and final resting place of my MJ
ghetdjc320 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
If anyone is interested, please PM me. I don’t mind shipping anywhere for the right buyer. I’ll post in the for sale section shortly -
Aside from the machining of the block and the spray job I did it myself. The paint is pretty awesome and the pictures just don’t do it justice. That paint was like 90% pearl base then they added some deep colors at the end along with some metallic. I haven’t listed it for sale stateside and honestly I’m not sure how??? If anyone has any ideas please let me know. I don’t have any new projects planned at the moment and probably won’t be working on anything for a few years but MJs are my go to still. Would love to pickup an 88 mj chief and restore to oem or pickup another 91-92 ho MJ and build another one. Someday perhaps -
Thank you all so much! This is quite an honor!
Sway bar drop brackets or extended links?
I run the Artec bracketry kit for the d30 and the sway bar links are much higher for crossover steering. Was able to run RE disconnects for a 2” lift on my 5.5” lift. -
Yep, will be there indefinitely. The biggest problem is access to parts there and the constant salt water and super high humidity environment. I’ve never seen vehicles reclaimed by nature so quickly. In a few months my MJ would be unrecognizable and they really don’t have any vehicle storage locations or garages available. Even here on Guam I keep it covered in a high quality custom fit cover and wash and wax it often. Also spray the underside with corrosion inhibitor every few weeks. Keeps everything in good shape. -
Like @fiatslug87 said, it’s $2400 to ship back to Long Beach. If anyone stateside or anywhere else in the world is genuinely interested, shoot me a PM and we can discuss. I had it shipped from Texas to CA for about $500 then it went on the boat for $2800 to get it out here. Takes about 2.5 weeks to ship. Actual sailing time is like 12 days I believe and it transits through Honolulu. -
Thanks! 2020 Aston Martin cinnabar Orange. Tons of pearl in it so it glows in the sun -
1989 Jeep Comanche (CO)
ghetdjc320 replied to RAFA2009's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I can appreciate the body work but...eeks! -
Source files for DIY projects
unless anyone in the club wants it stateside. It’s $2400 to ship back. -
unfortunately no... I have to sell it before we go. I’ll make sure it goes to a good buyer here on island. If i ship to Micronesia it will die there. Lack of parts and lost o salt air with rain. I’ve never seen machinery reclaimed faster by nature than Micronesia. -
if you want to do that then that’s fine by me. I’ll be moving to Micronesia soon and will be unable to do anything with these projects which is why I made them open source. I only ask that no one tries to profit from them. You can easily change the symbols on the switch covers to whatever you need. Just keep the placement the same you you can have the glow through effect from the backlighting -
You also need the vinyl to be applied directly to the overlay. Otherwise it will be too opaque. Paper just doesn’t have the color saturation like vinyl does -
it could but the transparency wouldn’t be right -
@Pete M Did you want to stick this thread so we can keep adding to the file database in the first thread? -
Taillight Harness (Repair)
ghetdjc320 replied to JeepFanatik's topic in MJ Tech: Modification and Repairs
Dorman still makes all the sockets if you need to replace them
