ghetdjc320
  1. @Pete M The knuckles if their cheep enough! I’ll take knuckles from any xj/mj 84-89
  2. ghetdjc320
    Mandalorian
    I bet you never guessed I was a fan
  3. I just adjust them with a good angle finder and tape measure. Adjust your lowers first to center the axle then use the uppers to set you castor angle using an angle finder on the inner C’s of your axle. Then center the axle with the track bar at ride height. There is also some preset number charts floating around online but the above method dials it in better. Most alignment shops don’t take the time to actually adjust all the links and track bar since the adjusting points don’t match the “stock” configuration in their manual. A good off-road shop could do it for you though if you prefer.
  4. I use a vacuum tester and check each line. Helps to find the problem right away
  5. I’m referring to the GM connectors on the steering column for ignition ant turn signals. Nice to have those be plug and play .
  6. You could but the YJ painless harness will fit pretty well on most MJs. Even the firewall plug connector will bolt in. It’s plug and play with our steering columns and most major components. Plus it has provisions for efi or carb and tons of alternator options.
  7. Just a thought but painless makes a nice YJ harness for the 87-90 that could be so easily adapted into your MJ. I used it in my YJ along with a Holley efi system.
  8. Apologies if this is in the wrong section. Please move it if needed. Just wanted to reference an installation guide for those who are replacing your switch trim covers with the new replacements. It’s fairly straight forward to install but here is a step by step: 1. Remove dash trim. There are a couple of screws just above the gauge cluster and a few others that will need to be removed. The bezel itself pops off once the screws are removed. 2. Remove the existing switch holder. (You can skip this step if you don’t have an existing switch holder and will be installing a new one) Each switch holder will have one screw and two tabs holding it in. 3. Using a thin metal instrument like a razor blade or utility knife, gently remove the switch trim cover from the switch holder. The cover is held on with adhiesive from the factory. Here is a pic for reference: 4. Optional: clean up the switch housing. Would also recommend cleaning up the blank face of the switch housing for proper installation of the new cover. 5. Test fit your new switch cover. Do not glue it down yet! You want to get an idea how it’s going to align on the housing. The switch cutouts need to be lined up As close as possible with the housing. This will ensure that the symbols are fully illuminated by the backlighting. Here is what that looks like: This alignment is crucial for the for proper oem appearance and illumination. TIP: align the switch trim cover switch cutouts with the plastic switch base. Each panel has been tested to align with the switch cutouts. If they are aligned well then everything else will line up just fine. 6. Glue the switch cover onto the switch holder. I specifically opted not to include the factory trim tabs for alignment. After testing them on different housings it became obvious that the moldings are not always 100% identical. I recommend using a gel type super glue. Place small dots of glue on the switch holder as shown: NOTE: be very careful not to use too much glue so that it doesn’t squeeze out when installed. If any glue gets on the face of the switch cover it may ruin it and be almost impossible to remove without damaging it. NOTE #2: Spray adhesives such as 3M “45” or “Super 77” among others also work well but don’t let you play around with alignment very much. The most critical aspect is making sure not to get any adhesive on the front of the cover. The back of the switch covers is a poly material that is fairly safe using a wide range of adhesives. The gel type super glue gives a few seconds handling time. As soon as you set the cover on, check and align the symbols so they are fully visible while looking through the light cutouts on the back. Each unit is test fitted before shipping out. 7. Once the glue has cured (make sure you follow the glue manufacturers recommendations) you can reinstall your switches and lights. If you also purchased new oem switches at the same time, the wiring from top to bottom is: ground, load, positive. These switches can be used to control just about anything. A note on lighting: these bezels have been made to recreate the factory yellow/green color using the standard original “74” bulbs. If you decide to use a standard white LED the glow will be slightly blue and will not look as good as the original filament type bulbs. I recommend sticking with the original types as this will produce the most oem appearance. We spent many hours and went through literally hundreds of different materials until we found this one that provides the best light difusión and symbol clarity. Using multiple layers, I was able to reproduce a finish that looks like it came from the factory when installed.
  9. Are you going after a “Jeep Speed” style build?
  10. Same here. I’m not sure if the OP understood my post. I was just mentioning the internal differences but have never seen a failure from the mod itself. You may notice a bid of driveline vibes if the driveshaft wasn’t balanced
  11. The old 231’s (94 I believe was the changeover year), had needle bearings on the main shaft that the Chan sprocket would ride on. They were later deleted. So basically, the 231 was updated when the driveshaft started spinning all the time. That being said, you should have no problems if your tcase is in good shape. If you run an sye, most will update the internals to the later style with no cage/needle bearing.
  12. This project has now officially moved to production! XJ and YJ versions also in the works.
  13. I tried and the staples held fine but the card stock in mine was giving out.
  14. Yes they do and I’m also going to offer replacement plugs so you can add new plugs for your acccessories without hacking up anything. I’m starting with the fog/cargo and tranny/sport bar combos first this week. Doing one more prototype model to make some very fine adjustments with text and backlight color filtering. Here is what will be offered to start with: 1. Bezel cover (fog/cargo and tranny/sport bar eta this week) 2. Original switches 3. New light sockets for the symbol illumination (plug and play with the stock switch housings) 4. New switch connectors (pending) 5. Refurbished switch housings on an as needed basis Regarding the bezels: once I get this first batch finished I’ll move on to different and custom versions. If you want a one-off I can do that but if it’s just going to be one or two switch panels it will obviously be more costly. Regarding the replacement switches: they are NOS! Regarding the new light sockets: These twist and lock right into the old switch housings and use the same 74 bulbs as the originals. I’ve tested LED’s and they also work fine but obviously will give a different color. Regarding the switch housings: I’ve been sourcing used switch housings to refurbish and can send you a complete, ready to install panel if you prefer it that way. This can include switches, bezel, lighting and wiring as needed ready to swap right in. Will post last prototype this week and link the threads together. Will notify everyone and create a thread in the vendor section for orders. Let me know if you have any questions
  15. That’s a tough call. I’ve seen the WJ clear 15” steelies but didn’t look like their was much room left. Would also depend on whether or not wheel spacers were used.
  16. More appetizers This was my second to last prototype. Will post in vendor section soon. Depending on how many orders I receive, lead time may go up a bit. The glow through portion will be matched to stock 100%. I can provide just the bezel or also the bezel and new original switches and the bulb socket for illumination of your new “factory” options @Red Mistress. Also, please let me know y’all’s interest in hvac covers as well as the headlight and cigarette lighter bezels. They can all be made original or custom depending on interest. Also just want to thank everyone for their support and patience. I’ve been meaning to get some products available for our MJs for some time now. Thanks CC!
  17. Some tweaking left to do but wanted to send out an appetizer. The text needs to be slightly adjusted as do the pin points that locate the bezel. These are painstakingly time consuming lol. They have multiple layers but the end product is looking very good.
  18. yeah that’s not a problem but will have about a 1 week lead time and cost more unless there are multiple people that want the same version. There are plenty of options for sure. I also will be carrying the oem switches for a completely original look. The switches are new OEM and can be used for pretty much anything
  19. I’ve been getting this project moving recently and am nearing completion. Hope to have some product pics out soon. The hvac controls bezel and the headlight switch are also in the works. More projects in the works also.
  20. I’ve been contemplating new front coils also. I run metalcloak control arms but Currie products have always been top notch.
  21. This is why some of us keep saying 4” or less given the info you’ve provided.
  22. If your budget is 4K then the cost of an sye or steering mods should be a non issue. Bob the bed and run a 4” lift. If you keep the long bed then the sye will likely never be needed though there are other good reasons to get one.
  23. I’ve got about 5k in mine. But I don’t have a single dent or blemish. I have since bought many body work tools and will be doing most future body work myself
