By the way, here are the gear ratios for the AW4: 2.8 1.53 1.0 .75 AX15 3.83 2.33 1.44 1.0 .79 The unique thing to remember with an automatic is the torque converter, which in effect produces a sort of lower version of each gear. Top end highway speeds are very similar with both options. In practice, they both have a very similar effective first gear as well when the torque converter is factored in. Both are great tranny’s for our Jeep’s imho.
4.88’s are great. 4.56 with an ax15 with stroker on 35’s was also nice but I could definitely have used 4.88’s though and that’s with plenty of long highway drives,
Just as an option, I used a rubber floor plug and some urethane sealant. Works great. Put a small “drip loop” in the antenna cable before it enters the cab also.
I haven’t gone a drop over 210 pulling my jet ski through the mountain passes in Guam with my AC on… the mishimoto radiator or novak is where it’s at. I’ve tried others, oem, csf, spectra. Nothing cools like the mishimoto has. Plus a threaded magnetic drain plug, 19psi cap, perfect welds, and (2) decent size cores with a higher fins per inch count than most. Oh, and lifetime warranty. Cold Case if you want to save a bit more coin. Novak if you only ever want to but once.
the old Griffin jeepspeed radiator was probably the best production unit available but isn’t around anymore. Very pricey though
I’ve been through all these options before. Here is the combo that just works: oem water pump, oem tstat, oem hoses with the spring in the lower hose, oem tstat housing, oem 10 blade mech fan, oem shroud, Napa 2.5l fan clutch, oem late XJ e fan, mishimoto or novak radiator. There are certain situations where other options are better but for a stock or near stock rig nothing will cool it better than the above recipe. FYI mishimoto is on Amazon
1991 Eliminator Resto-Mod
ghetdjc320 replied to ghetdjc320's topic in Member Projects: Your Comanches
Addco rear bar is complete and on the way! My ocean freight finally arrives this week. Going to be cutting out the floors soon. Not looking forward to it but I’m going after any and all rust even if it’s just surface rust. -
Need some ball joint help
ghetdjc320 replied to jeepmjga's topic in MJ Tech: Modification and Repairs
Awesome! Glad you got it fixed -
Check your axle tube, it may be bent just enough
- 12 replies
- differential
- differential seal
(and 3 more)
Tagged with:
The side cam gears may not be fully seated. Lunchbox lockers can be a bit finicky until the axle shafts are installed.
- 12 replies
- differential
- differential seal
(and 3 more)
Tagged with:
I’d recheck the Spartan locker install. Make sure the cross pin is fully set and that your springs and cam gears are all lined up. Try shining a light down the axle tube and see if you can clearer see all the splines on the side gears through the tube. Regarding the axle seal, does it have a metal cone on one side to guide in and center the axle shaft? The trick with adding those oem seals to the cad housing is just getting it completely square. The seals-it seal fits much better in the bore and holds a much better seal.
- 12 replies
- differential
- differential seal
(and 3 more)
Tagged with:
Brake upgrades - start with this
ghetdjc320 replied to ghetdjc320's topic in MJ Tech: DIY Projects and Write-Ups
Curious as to the WJ hubs. It was my understanding that they could not be used in a XJ/YJ/TJ/MJ housing due to not properly centering the u joint axis in a turn. How are they working out for you? if they didn’t chew up u joints they would make fore a simple wheel bolt pattern change. I also run JL wheels but with adapters -
They fit just fine if your inner C was not damaged by a botched install from a previous owner/shop. I love Moog parts but on these axles you want the Dana/Spicer 706944X. They have consistently outlasted the moog/precision joints 2:1 with big tires and/or lots of wheeling -
First off, what locker did you install? Also, what seal did you use? In CAD housings, seals-it seals work fantastic since, as you mentioned, the housing isn’t really machined for a good seal there on the cad axles.
- 12 replies
- differential
- differential seal
(and 3 more)
Tagged with:
I believe a lot of these previous owners lacked the proper tool to install the ball joints correctly. It’s a pricey tool but worth it. -
Sounds like maybe someone botched the ball joint install at some point in time on this axle and messed up the holes -
706944X is what I’ve always used. And that was after pressing out some Moog knurled ones. What exactly doesn’t fit? -
Most will suggest that you swap with one for a short bed. Both are in demand.
‘88 to ‘98 D30 brakes
ghetdjc320 replied to howeitsdone's topic in MJ Tech: Modification and Repairs
Manual window regulator fix
ghetdjc320 replied to 70barracuda's topic in MJ Tech: Modification and Repairs
Interesting question, following. I replaced mine with a good used one with zero problem. -
I did . Those huntsmans are fast though and they actually will turnaround and run after you if they can’t escape quick enough. -
Someone stole my temp probe along with my multimeter so I can’t say for sure. It I would guess mid 50’s with 85* ambient air. -
Those huntsman spiders are all over the place here. Makes reaching your hand down in to a dark hole quite a thrill -
