2
Everything posted by jdog
Build Date: 10/9/87 Body: jp62 Selling Dealer: SKYLAND CHRYSLER JEEP DODGE RAM Asheville, NC *W7 Cloth Seats -SA Charcoal ADA Light Group ADB Protection Group ADL Skid Plate Group AGL APA Monotone Paint BCQ Maintenance Free Battery CAC Low Back Bucket Seats CGW CKA Carpet CUF Full Length Floor Console DDQ 5-Speed Manual Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GFD Rear Sliding Window GSC Right Black Mirror HAA Air Conditioning JFH Tachometer JGB JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LDA Underhood Lamp LMA Halogen Headlamps LNJ Front Fog Lamps LPE Cargo Lamp MBF Bright Rear Bumper MCA MCB MDA Front License Plate Bracket MFD Bright Grille NAA Federal Emissions NFA 23 Gallon Fuel Tank NHM Speed Control NHQ Transmission Heater PQ9 DESCRIPTION NOT AVAILABLE QQ9 DESCRIPTION NOT AVAILABLE RAF AM/FM Cassette Radio SBA Power Steering SCE Wrapped Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire WJM 15X7.0 Chrome Wheels XEA Tow Hooks 3LX DESCRIPTION NOT AVAILABLE
Build Date: 8/20/88 Body: tl61 Selling Dealer: Von Byerly Jeep - Eagle Salisbury, NC *F2 DESCRIPTION NOT AVAILABLE -SA Charcoal BAYP 105 Amp Alternator BCYP 95 Amp Battery CBAP Straight Back Bench Seat DGB All 4-Speed Automatic Transmissions DHTP EAAC All Engines EAFC ERB 4.0L I6 MPI Engine GRVP Left Manual Mirror HAA Air Conditioning MBJ Black Bumper MDA Front License Plate Bracket PE4 Colorado Red RAAC All Radio Equipped Vehicles RCAP Audio SBAA Power Steering TAAC All Tires TBB Full Size Spare Tire TNCA P195/65R15 Tires YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z59P Left Front Spring Group Ix Z78P Right Front Spring Group VIII 5ALA APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror GUAS Open JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KDAS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS NBKS EVAP Control System NDAS Catalytic Converter NF2S 18 Gallon Fuel Tank QE4S Colorado Red RACS Open SCBS Perforated Steering Whl SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 167S Zone 67-Charlotte
Fuel issue in new to me manche
jdog replied to Jeepjunker's topic in MJ Tech: Modification and Repairs
Or dirty injectors -
The other port is just a plug on the throttle body. No problem
The one in the back of the throttle body should go to the map sensor on the firewall
That's why I was thinking either ground issue or socket issue, did/does this thing have wiring for a trailer?
Then I would look at the grounds or a bad turn signal switch
Could be the sockets in the rear, or mis wired sockets
@Jesse J Haven't heard from you in a while
Sorry for using your thread, trying to sell the car and on the other site I can't pm pictures directly gotta host them elsewhere
yes they should be mirror images of themselves, make sure the short pad is always on the front, long on the rear. but I do think someone swapped your backing plates, comanches park brake cables come in from the front
falcons?
88 mj radio and other interior wireing
jdog replied to Damonk90's topic in MJ Tech: Modification and Repairs
Ah OK @Minuit Would know, other wise only other suggestion I have is there's a electrical manual here on the site, hopefully @Pete M Would comment as he has the link in his signature I believe. I would just say run it to the ground location same as the dash but that's just what I would do -
Welcome, all questions welcomed. Iirc it grounds to the back of the radio unit, the wire should be separate then the rest,. Interior lights, how's the fuse? Do you have power at the lights? Are you using the factory lights, if so are they in the on position? -
Do you happen to have the Vin? If you do you can search the registry and see if it pops up
For 89 year yes, but he could swap everything over from a 93-94 cherokee and get a single key for all
amc used two keys like gm, they didn't go to a single key till after chrysler took over. are you looking to replace all with the double keys or single key for all?
I got one, you pay shipping and it's yours
