jdog
    2
Everything posted by jdog
  1. Did you bump the ebrake wiring
  2. same seller, one had ended when i looked at it
  3. jdog
    1JTMP63P2JT006261
    Build: 7/22/87 Body: jm61 Selling Dealer: RIDGE AMC JEEP RENAULT INC Philadelphia, PA *X1 DESCRIPTION NOT AVAILABLE -Q8 DESCRIPTION NOT AVAILABLE AGJ Driver Assistance Group APA Monotone Paint BCQ Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DGW 4-Spd. Automatic Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GEC Front Left Side Sliding Window GFD Rear Sliding Window GSC Right Black Mirror HAA Air Conditioning JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LMA Halogen Headlamps MBJ Bumper MCA MCB Applique NAA Federal Emissions NHQ Transmission Heater PB3 QB3 RAB AM/FM Radio SBA Power Steering SCE Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire WJD 15X7.0 Styled Steel Wheels 3LX DESCRIPTION NOT AVAILABLE
  4. You'll have to pull the lines to see the size and length. While you're there change out the filter
  5. That is to fix it at the fuel rail, all the lines underneath are just rubber fuel lines and metal, any parts store should have the rubber lines
  6. Nope, whole different pattern
  7. I believe the first one is for the underhood light. Not sure what the eyelet is for either
  8. Lol I gotta ask Voltage DC, or just get a cheap test light.
  9. Does it have fluid?
  10. That does Suck, at least they didn't drill the tank
  11. Red interior?
  12. Yep. I can see a jeep
  13. If its for the two doors, if you're looking at the four door options the Comanche use the same doors as four doors
  14. Teamcherokee.com had the weather stripping, haven't looked lately, common points are windshield/back window and anything that passes thru the firewall.
  15. Bumo Any updates?
  16. woke up to this in my head, some good advice lol
  17. Ok what do the hoses feel like to the touch, be careful because they can get really hot
  18. Just stacked together bolted to the left steering column stud under the steering colunm
  19. What about media shipping or a round tube
  20. Another issue could be that it's just too cold, what happens if you block part of the radiator?
  21. What is the temperature of the heater hoses with the vehicle fully warmed up, use a ir gun and see, if both are cold you have a air pocket. Which style cooling system are you running?
  22. You gotta remember these things had some slop as they are a steering box and not a rack
  23. How much slop are we talking about?
  24. jdog
    Happy twos-day
    Happy 2/2/22
