Everything posted by DJM/78
I am a big fan of the 4.0 HO , some may disagree , however a good set of low gears in the rear will help with towing . I am rebuilding my dana 44 with 4;56 gears . IMHO , a HO with low gears makes me feel like this in my head ... :banana: . I'll have to have the doctors remove my ears , so my smile can go back further . :D
Restoring factory turbine wheels
DJM/78 replied to sinkrun's topic in MJ Tech: Modification and Repairs
Yeah, you should be able to refinish them . I polish all kinds of metal . Aluminum is actually really easy to polish , just takes forever . Best bet is to strip them with chemicals and see what comes off . It will bleach the metal but you will polish that right back out . Start with 220 sand grit, work your way up to about 800 wet or dry . Then start with 3M rubbing compound, until a mild polish occurs , then mothers the hell out of it , to a bright finnish . Finnish will last a wile before you have to polish again . There are some coating options though . -
By cutting away the B-pillar supports , that ruins the purpose of a uni -body design . If that truck rolls or is hit , it will crumple like a pop can . If someone were to do that and drive it around , they would have to reinforce any areas that are not load bearing , witch was the whole cab . It can be done with an internal roll cage safely . Just not much room in the cab after its done .
Difference in Mini Consoles - Never Noticed This
DJM/78 replied to runner6's topic in MJ Tech: Modification and Repairs
Depending on your heater box clearance . looks like there might be a little trimming at that end . Should bolt right in though . :dunno: -
Yeah ! I've been trying to get a new E-brake assembly for about six months , guess I'm converting to the console brake . :shake:
IMHO , after all the work putting a new or used diff , in place , I would find a ford 8.8 or a dana 44 . Both are good axles and very upgradable . Disc brakes and lots of options on lockers . :cheers:
In the MJ tech forum , click on board index . :yes:
Howdy from Andy in PA (more west than the Orig. Andy in PA)
DJM/78 replied to webbjeepxj's topic in The Pub
Welcome to the club . :wavey: -
Yeah " , I guess that one collected interest ! Next time you loose a family member , you can bury them in my backyard . :yes:
My problem is trying to find a good working E-brake assembly . Factory quit making them about four or five years ago . I can't find a decent working one anywhere . Where as the console E-brake is a dime a dozen and cheap . Dealerships still cary them new as well . As far as the conversion , I don't know about that , but you'll probably have to fab. or modify somethimg anyway . :dunno:
Sorry, no gold and no woodgrain... I want to keep it simple and clean looking, will eventually repaint it white, maybe with a silver lower two tone, who knows. lol.... :rotf: Truck looks good though ! I always catch myself looking at your bike . :thumbsup:
What's up Ken !! I'm mainly a pile of uselessness around here , but I try . :D I was stationed down there in Clarksville , KY . 101'st Airborne div . Nice country up there in , KY-TN. :thumbsup:
Dam'it ! I knew someone beat me to making a pair of underwear out of pink see through bubble wrap . :brows:
The AT . tires are also a much harder rubber compound , with more of a rough ride than the softer compounds . They will last you longer , but for more aggressive traction off road , mud , loose sand , ext. I would go with the BFG , mud terrains . plus a smoother ride . I am using the BFG AT"s now but I want a set of mud terrain's for off road use . However where I live, there is allot of pavement to rock roads, with pot-holes the size of a VW out here and they have held up great . I guess its just personal preference . :thumbsup:
Anybody going through that stuff deserves a metal ! :bowdown: I hate hospitals . My wife goes back in for surgery thursday , after just getting out this morning . :( I hope you get well soon !! :thumbsup:
It took me a wile , but I like the " Wanche Limited " :rotfl2: Whatever . :doh: Are you going to hook it up with some gold trim like some Limited Jeeps ? Gangsta' :thumbsup:
If its is coming from the windshield , than you need a couple of things . 1, Good urethane sealant , pref. from glass shop . 2, Urethane pinch weld primer . 3, A cold knife , yes its a special tool . 4, New plastic clips that the windshield trim holds on to , if you don't break them cutting out the glass . 5, Probably a new windshield . 6, A long knife, another special tool . 7, A good sharp flat chisel or strong scraper . thin as possible . 8, A good caulking gun . stronger the better . That urethane is tough stuff. Its not impossible to save the old windshield , just very hard . The hardest part are the corners and the bottom , at the cowl . It does take some patience . I can help you more if you need it . What is your exp. with windshields . Its not an easy task if you don't know what your doing . You can cut up your headliner real easy if your not careful . Like the hacks who did mine . :rant: I can go step by step if you want . :thumbsup: Let me know .
Project "Eliminator"
DJM/78 replied to 89eliminator's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Looks good , does the weight of the bumper drop the front any ? -
First of all , welcome to the shananagans ! :dunce: I agrea with JeepcoMJ .
I'm sorry , but a matrix sh@t .......... thats gonna leave a stain on my brain I'll have to tell my friends about . I can't do this , my tummy hurts . :clapping:
Maybe someone knows more about it than me . I'm the class :dunce: around here just yet . I got tired of looking for MJ floor brackets . So I did my own thing . Used a set of best top TJ seats and 95" XJ floor brackets and went to town . You can see the bolt pattern a little better in this pic .
I'd give you my 92" bench floor brackets , but I don't think they will work on the older bolt pattern . :dunno:
I'm sssstttiiiillll ballen' :rotfl2: :rotfl2: :clapping: :huh???: :doh: :rotf: :rotf: :bowdown: Publish that sh@t and send it to Barbara Walters , she's got saggy nuts too ! :ack:
Considering you have an older style floor bolt pattern , I would do what mfpdm did . Much easier to fit . Newer style MJ's are allot harder to bolt in . I had to mod. some stuff no matter what . XJ floor brackets are allot easier to find as well .
