cruiser54
    14
  1. I have no recommendation on the 93. Only Renix. Contact info: trevor.skankfootracing@gmail.com https://www.facebook.com/Skankfoot-Racing-100901878066960/
  2. So, maybe the original injectors weren't flowing enough because of age or something, and the ones you installed are flowing too much. Perhaps a nicely refurbished set of stock injectors or the equivalent 4 hole injectors would be a wiser choice.
  3. I had the priveledge of ordering brand new Comanches for myself as demos. Only 3 or so 1986 and earlier. Never saw 3.73 as an option.
  4. So, you have a 99 engine with all the bolt on injection parts already? Distributor, throttle body and manifolds etc?
  5. No wonder there are no responses!! Holy run-on sentences. Hurts my head to read.
  6. Yup, there's only 3.
  7. You likely have a bad socket.
  8. It will be just fine. Be sure to plug the vacuum lines on your truck.
  9. well, get an 87 or 88 harness and get to work.
  10. 87 to 88 least differences.
  11. Have you adjusted the throttle valve cable? There's a youtube video on it. Needs to be done.
  12. No. There are other options. And, a scanner will not detect the things that my Tips cover. nickintime makes engine monitors. His info is on the first page: http://cruiser54.com/
  13. The ground wire was bad on mine. So, have you done the Tips?
  14. You can also remove the rear cover and read the numbers on the ring gear. Probably needs a lube change anyway......
  15. Did you adjust the TPS? Have you completed Tips 1 through 5 on my website? Tip 10?
  16. Needs a good dose of noggin pokin'. Go have a look!! YES. Could be that the hose inside is just rotted or loose.
