6
Everything posted by Ωhm
If fuel tank cap is non-vented then air box would put negative pressure (vacuum) on the fuel tank, no vapor flow.
Has anyone bisected a RENIX charcoal canister? Purpose of question is dual; 1.Is charcoal canister vented between fuel tank, charcoal, and fresh air? 2.Is charcoal canister vented between air box, charcoal, and fresh air? Both using the same vent.
No decision, is a decision. No call back, he'll figure it out.
Different MPG 1989 vs 1990 4.0 OHV
Ωhm replied to 1990Eliminator's topic in MJ Tech: Modification and Repairs
That's OPEN LOOP mileage or is it Pb foot mileage?- 16 replies
‘92 Eliminator - A Journey Begins
Ωhm replied to Sammykonga's topic in Member Projects: Your Comanches
Looks clean. I like it. Welcome -
88XJ Electrical Manual shows Low Washer Fluid is powered up by the Radio Fuse. 88MJ Electrical Manual doesn't show this. Not much information in either manual to help anyone. Minuit photo of dash (Low Washer) show bulb is in a different location than that of the 88MJ Manual. I think (since its there) Engine Harness is equipped, IP Harness is not.
No turn signals or wipers
Ωhm replied to Comanche chief 87's topic in MJ Tech: Modification and Repairs
Do T/S, wipers work with the key in the ACC position? Welcome to the Forum. -
Using a testlight, connect the clip end to Battery Positive (B+). Probe D2_3 with other end. LAMP ON: P or N LAMP OFF: all other positions.
Upper right hand corner of screen. Click on USERNAME. Click on ACCOUNT SETTING. Click on SIGNATURE. Add INFO: YR, ENG, TRANS, etc, etc.
That's interesting. Maybe linkage between Key Cylinder and IGN SW or IGN SW adjustment. Anyone know DIY for IGN SW adjustment is, I can't seem to find it?
Mechanical question (Key Cylinder to IGN SW). With everything connected back up, back to normal, does engine CRANK over when key is in the START position? If yes, then OPEN circuit between C103_E and C267_I1 (YELLOW wire).
Disconnect C103. On the IGN SW side of the harness measure for voltage at C103_E, KEY ON (IGN SW connectors connected). Problem with C103 is C105 looks the same (6_pin). C103 will have YELLOW wire in cavity E.
Yes As long as C267 and C268 are reconnected at the IGN SW.
Using that jumper on the IGN SW connectors bypasses the switch. I think you got a faulty Ignition Switch.
