Dirteatr717
Everything posted by Dirteatr717
  1. I was excited to see more after seeing the boatsides and then saw the roof coming off and didn't really like it too much anymore... Good thing you saved the truck but you didn't really save much! Hopefully the toob comes out very badass and makes up for the lack of Comanche that's left haha
  2. Got my ballistic fab order in the mail today yahoo! I have all the brackets I need now. Ordered all new brake stuff front and rear through a buddy and that should be here this week as well.
  3. It's been a rough week time to break in this bad boy! Got it today in the mail, thanks Pete :wavey:
  4. I had to get a metric bolt that was 130mm long and put it in the right way and was able to put the oil filter on fine, yours might've been slightly longer? Also last night my starter committed suicide and Cherokee_chiefs fell out while he was driving down the highway... Weird indeed. So I cleaned my battery posts and put a new duralast starter in my truck this morning and new fuel filter.
  5. Drooled a little :thumbsup: can't wait to see it skydriving
  6. Thanks Minuit ! :wrench: If anybody needs one let me know ill make another
  7. I'm pretty sure it was 5 or 6 sheet metal screws then the 4 bolts for the shifter itself, as for my axles I Think about it everyday haha. don't bother with fullwidths and 35s, thats about the equivalent of stock if not smaller tires an stock axles for ground clearance.Update: Got my brown dog motor mounts in after work today, works been kicking my butt so I havent been motivated to do it! Also my Pass side MM bolt was put in backwards from the factory as the bolthead is facing the firewall and won't come out unless you remove the oil filter adapter and I wasnt about to do that so I cut the bolt off and got 2 new ones at the hardware store. pics of course... The originals were kinda toast :fs2:
  8. why bother getting a new one if your not going to put any fluid in the new one? Save yourself the time and 30 bucks by leaving the broken one in there :D
  9. sliders look good as do the tube fenders :thumbsup: ! Ive had something like that in mind when I get to my cage
  10. of what exactly do you want a picture of? I have an aftermarket crossmember now but may have an old useful picture somewhere..
  11. Youll be able to get to some pretty remote places with 33s and a locker, sounds like a 30/8.8 with discs is what would fit you best :thumbsup:
  12. Just placed my order for the D60 disc brake brackets, coil bucket/lca/shock mounts and added a .99ยข ballistic weld on skull because it wouldn't be badass without one. Also ordered a 4x8 sheet of 1/8" to make frame stiffys and I have a 3.5'x 1' sheet of 1/4 to use for gussets and a smaller front axle truss. Need to install motor mounts, new exhaust manifold and need to buy Rear 35 spline axle shafts (other ones were wrong length) Rear hubs Axle yolks Tires Then I can swap my axles!
  13. Cherokee_chief daily drives his on 37s, as will I. A 44-9" is a good combo but only for 35s isn't worth the money to build them. Have you considered waggy axles? I'm currently building fullwidth D44/D60 axles
  14. I'm in for the rockclimbing at some point while I'm there, I've done 100' walls without any gear so I'm gunna have a blast!
  15. U G L Y YOU AIN'T GOT NO ALIBI YOU UGLY
  16. Pics or it didnt happen :D
  17. Check to make sure it's not the back of the valve cover first, also a 8.25 with a locker and 4.56s for 300 isn't that bad of a price. It'll hold up just fine too
  18. CHeck out mnkyboys build thread, he bobbed his shortbed a decent amount.
  19. pukegoats casings split in half vertically the ax15 split somewhat horizontially and everything ive gotten for my tranny for a ax15 fits so....
  20. I have an Ax-15 and it says it in my sig lol
  21. 2 dr XJ buckets and 5spd center console XJ Or-Fab rear bumper 78 f250 dana44 front axle Late 60s f250 dana60 full float rear axle 2 pieces of wooden dowels to hold up my headliner and sunglasses That's about it, I took out the ORIGINAL Floor mats last week because my foot finally wore through em hahahaha
  22. I *think* I have 4.5" rustys coils and 1.75" poly spacers and pretty healthy 4wd leafs. Sits perfect in my opinion.
  23. Didn't have work today so I washed my truck and cut out the center console enough to slip my CB radio in there. Fits nice and is out of the way. Hopefully selling my Camaro this week so that'll help cover a decent chunk of everything else I'd like to do :driving:
  24. Could be hub bearings, could be worn out control arm bushings. Check anything that moves in the front end! also for the seals if you have The original d30 with the vacuum disconnect the pass side axle seal is next to the vacuum disco, you have to remove the axle shaft to squeeze a new one in there, the driver side is even more fun it's in the housing so when you take the cover off to inspect the Spider gears take a look at the seal :thumbsup:
