Everything posted by mikekaz1
curious Ive always used a Purolator 14670.... on all my jeeps
The brackets themselves are angled to get the straight arms and bushings to line up correctly
Jeep XJ MJ OEM AM FM CD Player Mopar 82300393
mikekaz1 replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
Cool info. I see your featured Haha. I'm guessing the switch was to make it more uniformed and symmetrical. But curious what the 91+ empty light sockets are for... and was their any use to the old style square? -
Curious what was the year split/ difference between the clock pod that had the big square and the one with the bars? -
Sick! -
Krustyballer Fabrications
mikekaz1 replied to shelbyluvv's topic in Vendors- members making products for MJs
I could be wrong, but I think they just hang lower under the bumper compared to the factory bumpers- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
id love to see that for sale! thats what i thought this bumper was going to be!- 199 replies
- hitch
- hitch plates
(and 10 more)
Tagged with:
No real point to this. I just wanted to claim post 22,222
false. getting to use the stock leaf packs results in a smoother ride and better off road performance. the flatter the leaf pack arch, they better. there is a drawback though, and that is a greater chance for axle wrap. when i was still on leaf springs, i had to fab a traction bar because my axle wrap was so bad. eh... still seems like no solid benefit to it other then ground clearance and lift ability, what you explained as an improvement is more of it just gives the ability to keep using factory parts, that themselves have a better ride vs aftermarket. but not that the SOA itself has a benefit in ride or drivability, but just that factory springs are a better ride (usually). and it gives the added disadvantage of axle wrap.
there was a factory mini console available
Ah OK. So there's no true(performance) benefit or gain? It just allows a higher lift ability.
semi off topic... but what is the benefit of spring over anyways? other then ground clearance?
HITCH PLATES!
mikekaz1 replied to krustyballer16's topic in Vendors- members making products for MJs
I'm excited to see this bumper! -
Ah. OK. Good to know thanks guys! Its COOOOOOLD up here. So I'll leave it still (been there months anyways). But I have a cluster bulb that's loose and flickering. So when I fix that I'll pull the bulb for the GEN
http://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Winterforce+UV&sidewall=Blackwall&partnum=675SR6FWFUV&tab=Specs 265/75r16 (31.8x10.5R16) for $388 set of 4. they are AWESOME tires i run them on my WJ year round, fantastic in the snow and dirt. http://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Winterforce+UV&sidewall=Blackwall&partnum=675SR5FWFUV&tab=Specs 265/75R15 (30.8x10.5R15) for $340 set of 4
so i guess in 1996 with the OBD2 the GEN light just meant there was a issue with the charging system. why they used GEN instead of a battery symbol or ALT, who knows.
hmmm guess it must be a replacement cluster then (obviously if 96 was the only year for GEN) my guess now is its just lit GEN thinking its MAINT REQD. other then pulling bulb, is there any way to clear the light? not that pulling is a big deal just curious. makes me wonder how many miles are truely on this truck..... the custer says ~214K
uh... go fish? its tight enough that everything works, but i do have the typical semi-constant belt squeak. my 95% sure my tensioner is stripped as it won't tighten (move) any more but it not maxed out either
...mines shows GEN ill take a pic when I get home. I have full gauges and it stays right at 14V
why even bother going SOA if you don't want it bigger then it already is? seems like wasted cost to me,,,,
1991 mj 4.0ho its on the left with all the other lights, I believe its right ontop of the check engine light
Yup the Napiers. IMO their better then bushwacker
Curious on why my GEN light has been on.... battery is good. And alternator charges just fine. Voltage is at roughly 14.5 like it should. What controls the light?
