I'm guessing the "drivers side sag" is a combination of the gas tank and a fat driver over many years just wearing the springs (both front and rear) slightly more over the last 25 years replace springs and I'm sure itd look fine
just curious about any custom addons or factory modifications people have done to their trucks.
ive done a headlight relay harness. and converted to XJW header. the headlight harness is probably the single best light upgrade you could doIMO.
1993 is the only year where a standard was available from the factory in a ZJ. And I don't think external slave was till 1995. So I'm guessing this is a custom install
Eh maybe its a lingering thought of tow trucks and dump trucks. Manuals always feel more competent then their auto equivalents. But as stated. They generally are designed for hauling. Rather then an option as with pickups/suvs
i guess by shape i meant the radius of the corner. obviously they don't have the neck down sections. but that also why i said theres no direct replacement. other then a sawzall and a parts truck
But those are different? The red jeep lugs mount flush with the rim. Those are the standard ones you see. The jeep version of the outlaw 2s. But that black one the lugs are recessed. Like as if a center cap went over them.
They also make a custom gauge cluster that goes where the clock panel is. And one below the ash tray depending on your center console.
http://pages.ebay.com/motors/link/?nav=item.view&id=231549427979&alt=web
http://pages.ebay.com/motors/link/?nav=item.view&id=231516181595&alt=web
What about getting an adapted flange of another style 4.0. For example. My 91MJ has it vertical facing down. But my 95XJ had it sideways facing back. And my 00TJ is sideways right on the block. All threads are the same. So you should be able to swap around from the junk yard
pretty neat idea. so I'm assuming your also putting a gauge in to monitor temp if your putting a thermostat in, right? if so would it be possible for you to first bypass the cooler to see what initial temps are vs post cooler.
I don't think ive ever seen rims like that.... I kinda like them, their like an outlaw 2 but then not really... wonder what they would look like with center caps
not sure how true or easy it is.... I herd you can swap the internals from new to old style. while keeping your shell. so youd swap the window, regulator and seals. id try a search around here for that. as another option.
