Everything posted by Tj1
Looking for Parking Brake Release Cable Bracket screws
Tj1 replied to Broke's topic in MJ Tech: Modification and Repairs
I removed my E brake stuff and installed my prop valve in the release cable handles spot. if i remember right i reused the old screws..... Ill poke my head under there this weekend for you and let you know -
JCR picked a comanche a few months ago.... Hopefully they open up a new world of armor and protection for our MJs
One thing I've learned from my manche is that I've had to improvise at almost every fix, from the rusty floors to random bad wiring and anything in between!
That's the hose set for an XJ. Pretty much the same, eh? Close enough for new hoses with bends with cutting like 2" off the one end. I didn't have the hose clamp tight enough oringally and my first fill up was messy... luckily it was in the drive way with a can.
I used crown auto p/n: 52000623. The IDs were the same, bends are close and I trimmed it to size
ruff stuff, barnes 4x4, 4wd.com, quadratec just to name a few places, a bunch of places will have new 10" long ubolts
Tapatalk was the easiest for me because all my pics are on my phone
Rough country is cheap and a step up from stock or WJ arms. They have them fixed or adjustable.
Flared bed sides and front fenders
Tj1 replied to EnlistedManche's topic in MJ Tech: Modification and Repairs
I haven't replaced the inners yet, to much surface rust to get the welds to bite. Patched the outters with 18 ga. and primed it Not sure if I'm going to add flares yet, but I have a set of rear tj flares ready -
Question on parts for doing SOA
Tj1 replied to pitbull4x4's topic in MJ Tech: Modification and Repairs
X2 for the leaf centering pins. Got my ubolts and antiwrap pearches from ruffstuff. Shock mounts from iron rock offroad. Brake line extensions from rockauto (H38620 & H38363). Control arms from rough country. Bilstein shocks and RE coils. Didnt have to mess with a drop pitman arm -
Yes its MT leafs Stock mjs are 3+1 MTs are 3+2 or 4+1
I cut a corner out of an eye bolt and have no issues so far
I need help with pinion angles
Cherokees and Wranglers with SYE typically shoot for 1-3 degrees under 0, maybe more to help with small amounts of spring wrap. Maybe someone can confirm this. -
C2C is what I used, they needed trimming and custom adjustments though..... each side is $45
Could you get a generic size from the local parts store and run x amount needed?
Small update - a couple weeks after moving out of the unit I took her out on a bunch of state land to camp. We didn't quite make it to camp before the the radiator bllleeewwww. The wonderful closed system wouldn't hack it anymore so I dropped some cash to get every thing ready for open system. New radiator, water pump, thermostat, generic over flow tank, and gaskets. Couple days after that we went to the local orv sand dunes to play for the weekend. The fun didn't last long due to some wiring issues. No taillights and headlights coming on when the brake is pressed. I recently got be wires ran and finally have working taillights. About the same time as installing a new harness for the rear, I bought and installed the autopal housings with the putco relay harness. Next on the to do list is cowel hood mod and finish my half door mod....
I'm interested in the wing windows when you go to fixed.....
I rarely use my harbor freight pump but it comes in handy for how cheap it is. http://www.harborfreight.com/all-purpose-drill-water-pump-34302.html
'89 4.0 Renix Valve Train Noise When Starting?
Tj1 replied to Archaeor's topic in MJ Tech: Modification and Repairs
mine does the same thing, but I blame the oil running down back to the pan while sitting. -
This is what I interpreted from the drawings. Am I correct?
Sooo I've tracked the issue back to the tail lights. From the connector behind the bumper to the bulbs the PO had spliced in multiple areas and used duct tape to wrap them up. Some wires weren't even connected. I believe he tried to wire in a trailer harness at some point. I want to go through and run fresh wires. Can anyone dumb down a wire schematic for me? I looked in the hanes book and the cherokee set up looked more like what I seen on my truck vs. the schematic for an mj. I got a fogged brain trying to do wires.
Ive got a leer on mine, would the frame or hinges have part #s stamped in them? I could at least get a few measurements for you if you went homemade route.
