Strokermjcomanche
    6
  1. I don't think the one you linked would work without the bracket because it has a bushing at each end , unless they make an adapter .. It's for a ZJ rear - just read the fine print. That explains it then .
  2. This is precisely why I chose the JKS. Frame brackets for every one that I looked at at the time either dropped down, or, and. moved forward. Also, I like the factory bracket, it has a bulged pressed in for strength, the aftermarket bracket look weak. Everyone has their preferences, I wanted the sleeve and also seen that the JKS bar required drilling , which I'm not prepared to do. Something that bolts directly on is fine for what I'm using the truck for .
  3. I don't think the one you linked would work without the bracket because it has a bushing at each end , unless they make an adapter ..
  4. https://www.amazon.com/gp/aw/d/B00OPEUO0I/ref=mp_s_a_1_6?ie=UTF8&qid=1489345365&sr=8-6&pi=AC_SX236_SY340_QL65&keywords=jeep+cherokee+adjustable+track+bar
  5. Thanks for the reply. I saw the extra set of holes, they didn't seem to be threaded though. I will double check when I get back there today. If they aren't, I might just drill them out a bit and use grade 5 bolts and nuts. Sent from my SM-N900W8 using Tapatalk I would tap them to the 10mm 1.5 thread , you'd have to open up the frame to put the nuts on and they would spin if you ever tried to take the crossmember off in the future. Do it the right way ,the tap is cheap....
  6. There are several sets of holes in the frame , probably hidden by dirt / grease . Being that you're going from 2wd to 4wd you'll want to use the rear set of bolts , before you do I'd clean the 10mmx1.5 threads . Use everything from the 98 XJ and you'll be good .
  7. I want one with a sleeve ...
  8. There is one male and one female that are on both the radio harness AND the dash harness , which happen to be the same plug(s) . See for yourself
  9. https://www.crutchfield.com/S-Kga90OtkQwW/p_120701000/Metra-70-1000-Receiver-Wiring-Harness.html
  10. Just exploring my options on a track bar for my truck : 88 swb with OME 2934 coils running about 3.5 inches of lift.... The current adjustable track bar I bought won't work due to the taper not going far enough in the frame bracket for me to thread the castle nut on AND fit the cotterpin in . I've tried the newer frame bracket with the same results ..... I'm open to suggestions to make it work if it's possible . So being that I'm running 3.5 lift I'm looking for one that goes from 3/3.5 inches and up ( not up to 3.5-4.0 inches of lift ) in case I lift it in the future .And I'm looking for one that has a adjustable sleeve so I don't have to unbolt the track bar to adjust it . Other than that I have no requests . So what do you suggest ?
  11. One for NSS and the other is for the AW4
  12. http://m.ebay.com/itm/NEW-NOS-MOPAR-PERFORMANCE-GENUINE-OEM-INTAKE-MANIFOLD-ATTACHING-PKG-P4529680-/361843679815?nav=WATCHING_ACTIVE
  13. Thanks Troy .I currently have a pair at my brothers house in Parker Co , but I need two pair for my project . It would also be great for logistics as the next time he comes to Ohio he can bring them in his car and I can save shipping .
  14. Thanks for the attempt , he must not wanna sell or he already sold and never took down the ad .
  15. https://www.crutchfield.com/p_120701000/Metra-70-1000-Receiver-Wiring-Harness.html
  16. Thanks Rob , explains why it looks clean coming from FL
  17. Krustyballer16 on here sells new hitches specific to our trucks .
  18. I would have thought the fire originated from the passenger side , the lower dash is non existent on the passenger side while the drivers side is melted but still there . Maybe the blower motor or resistor ? Exhaust? It would be nice to know to prevent this from happening to other MJ owners....
  19. I'd like to know what started the fire , it seems like it was a nice truck beforehand. http://daveysjeeps.com/repairables/R487019.html P.S I don't care about how much He's asking...
  20. http://comancheclub.com/topic/49241-full-bench-non-cutout-in-5-speed-mj/page-2 Last post ...
  21. I told him I'd like to buy the running boards and gave my email , phone number etc . I do understand what you're saying , he could respond saying he didn't have them anymore or that he won't ship to me . I looked at the map and it shows he's not very far North of Michigan , thanks for any help .
  22. http://www.kijiji.ca/v-auto-body-parts/city-of-toronto/jeep-cherokee-xj-running-boards/1202862661?enableSearchNavigationFlag=true&uar=true Wish this guy would respond to my messages .....
  23. There are no guarantees on how long the paint/ dye will last , preping and using quality materials ( like S.E.M.) will greatly improves its life though. I guess it all depends how hard you are on the interior ....
