6
While it's nice , it's far from perfect and he's not the original owner ....
Marchal 850GT Fog Lights
Strokermjcomanche replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
Marchal -
Check out the marchal 950 Charlie lights , they are huuuge -
Making XJ buckets work in a MJ
Strokermjcomanche replied to mfpdm's topic in MJ Tech: DIY Projects and Write-Ups
Yep -
They are spot welded too , you should be able to see a little dimple where it was welded -
No CD head unit that isn't junk
Strokermjcomanche replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
Looks like it might fit in the clock delete panel -
How's this one ? https://www.amazon.com/Kenwood-KDC-BT858U-Dash-Receiver-Bluetooth/dp/B00I5ZOQ52 -
I just tried and it worked fine for me , I'll try and link it to some other site . -
I wasn't sure on your taste , just seen this one and it doesn't look too tacky https://www.google.com/search?q=crutchfield+cherokee+radio&start=20&client=safari&sa=N&hl=en-us&biw=375&bih=559&tbs=vw:l,ss:44&tbm=shop&prmd=sivn&srpd=16180876127732546235&prds=epd:11527911987599839405,paur:ClkAsKraX8ooopqYBxOr9sKCIap21Pfek0w5adZ2YY-ppqyidKGpg1hGFkSa6fkjSXKbQL3yD25-uaCANboJwklyyCeVjSw_gSdkL5DInSZTpa2bbsAl4cSSexIZAFPVH73HPszz0zn3KH510WCH9xXLBuAFcw,cdl:1,cid:17166990204541735345&ved=0ahUKEwiow9zE-IHXAhUl94MKHdJ6AXU4FBCBNgipBA -
Pretty sure he's not making them anymore...
The MJ was sold 15 minutes away from my house in ohio ( I knew the seller ) , I can assure the odometer was not rolled back ( it had 17k when I looked at it ) . There has been changed since I seen it in person : turbines instead of white wagon wheels . Marchal lights Embroidered floor mats And iirc splash guards all the way around I have pictures on my old phone and a post on here( photobucket drama ) that I can post up here if I can get my phone to cooperate...
Keep in mind the holidays are approaching, lowlifes will be out in full force trying to steal stuff from hardworking people so they can pawn them for drug money..... could have been worse Dzimm , looks like you got all the financial aspects worked out , which is second most important to your loved ones .
no start Truck just died
Strokermjcomanche replied to Smileybubby's topic in MJ Tech: Modification and Repairs
So you aren't getting a signal to trigger the injectors to fire ? I know you said you changed the CPS , what voltage are you getting at the CPS plug when cranking ? -
How did you verify spark and fuel ? -
Just testing to see if I could upload a pic by scaling it down , which I got to work . I used my iPhone and send an oversized pic to my email at a smaller size and was able to post it on here . It worked but will be a lengthy process.... I seen a set of four for sale on eBay for $150, I could send you a link if you're interested.
No offense taken , but a muffler( which is stock and in good shape ) or a soundproofing ( which I've already done ) won't effect RPMs . The axles were just installed (from 3:07 to 4:10 ) and I have no intention to change them now , I would have went with 3:55s if I knew that this was going to be higher than my liking , it really is easier for me to change a trans ( my buddies trans shop ) than it is to regear / swap axles .
While I agree with you Eagle some things have changed in the past 30 years . When these trucks first came out the speed limits were lower ( 55-65 around me ) now we have a lot of 70mph highways around here and when I'm going 70 I'm getting passed like I'm standing still. I don't plan on doing 80mph , but 75 mph is probably a realistic number ( and is a possibility that some highways will be raised to that ) so the RPMs will be even higher , and I would like to hear a little bit better too .
Yep , the one by the Ecm (6 pin iirc )
My innova scanner 3160 has the adapter and will read my 95 XJ RPM along with other readings
Good idea John , I will have to ask him and see what he says . I'm sure it would be a cheaper route to go ...
Yes it agrees with my dash tach , I can read up to 4 things at a time with the R.E.M. . I keep the engine RPM , fuel trim , O2 readings , and TPS on most of the time ...
Lol. I know . My black truck is considerably more quiet with the same drivetrain, lizard skin and all , minus the manual trans . My thought process is that the higher engine RPMs is the culprit, which is why I'd like to pursue the 6spd to drop some RPMs .
