dasbulliwagen
    3
  1. I have a VW Jetta engine Ive had stored for probably 10 plus years now. I did nothing to it before pulling it. I just go to it every once in a while and roll it over by putting my foot on the flywheel. It has yet to lock up, but anything you can do to lube the cylinders would be good. Like a previous poster said, pour some oil through the carb while running and then more in the spark plug holes after would be great, then roll it over bey hand to make sure it is well dispersed. It will smoke like a mother when you finnally do install it though!
  2. Same amount of torque at the engine, but the amount of torque available at the wheels would be more with the 4:10 due to the gearing difference... it actually should be more torque at the wheels in all gears just given the engine will have to turn more times to make up the same distance... does that make sense?
  3. I got bit by one of those cops while vacationing in West Virginia. And while writing me the ticket, he then goes into a lecture about how I'm gonna get more tickets buy guys just like him, in other small towns, because (not in so many words) I am a menace to society.... sitting there in my car with my wife and her family, spending our hard earned dollars in his town....never again! I live in a town of maybe 15-20000, and Id bet we don't have many more than 7 cops. Stupid!
  4. I know that those GM tilt mechanisms are rebuildable, but we don't know if that really is your problem, could have a bent wheel or a bent steering shaft, or all of the above. You might try finding one from a junkyard Cherokee with similar options in similar year range after making sure it doesnt have the same problems your has. I'm sure someone on here could help more about the tilt mech rebuild if thats all you need. Good Luck!
  5. State moto: Missouri loves company! :rotf:
  6. We had this problem on the air cooled VWs I worked on before, the caliper/wheel cylinder would be fine, but the rubber brake line going to them would be swollen inside and not release pressure, and I agree on the slide pins, and the also look at the caliper mount at the top and bottom where the caliper rests on it, sometimes you can get wear spots there too that could cause problems, Take a grinder and grind them smooth if you see any indentation there.
  7. If you swapped also, you could have busted the crank sensor where it goes into the bellhousing while installing the motor. Pull the sensor out and see if its broken....and replace it while its out anyways if it isnt broken. If I remember correctly, the new ones come with a peice if cardboard on the end of them to set proper air gap to the flywheel, when the engine turns over, the cardboard is ground off by the flywheel and proper air gap is established. Good luck!
  8. I just fixed a durango with the 4.7 in it with the same problem, it was the crank sensor. It would crank for a long time, sometimes act like it was out of time, and then when it did fire up, the idle would go up and down, eventually stalling out. Just my 2 cents, and I know not a 4.0, but its all relative.
  9. At the bottom of that track there is a bolt, 10mm. The door panel will have to come off. You may also have to remove the window to get it out... or maybe not, I just know its a pain putting it back together though. Good luck
  10. I don't know anything about your car specifically, but in most the window motors all ground through the driver door switch assy. You can go to alldata.com and buy a 1 year subscription for the service info on your particular model for like $20. That would give you all the wiring diagrams and troublshooting info you need. In a lot of the Jeep Grand Cherokees, there is a wire in the door harness at the hinges that likes to break and will cause this same problem. I think Autozone also sells these subscriptions to alldata, but If I were you I would call and ask them first. I think the autozone website has a link to buy a subsciption too. Good Luck!
  11. I thought you made that word up.... until I searched it. Yup youre right a Jeepney.... wonder how it got to norfolk?
  12. My GF's 12 year old daughter told me the other day that she wants her first car to be a stick, wants nothing to do with automatics. :banana: My daughter will be 1 year old next month, but when it comes time, she won't have much choice. And yes, a stick does make you a more alert driver, kinda like riding a motorcycle... if youre not alert on one of them, you arent going to last very long.
  13. Reminds me of the Toyota FJ55, which is about that long, but I couldnt find any pics of a truck version like this one, and the front end is wrong too. The front end looks like the early Willys pickup version, but the rest of it is too big. Who knows. Is there anyone who can go look at this thing and tell us exactly what it is?
  14. Everything I have is stick, and I intend to keep it that way. Do you know how hard it is to find a new car anymore with a stick??? Its horrible! When I bought my 05 Hyundai Tucson, it was like pulling teeth trying to find one with a stick, and then the salesman only want to sell you the V6 with the automatic. And kids nowadays don't even want to learn to drive one at all. I don't understand it. Sticks get you better gas milage, better reliability overall, and are more fun! And I heard something recently, maybe it was on here, that many auto manufacturers are doing away with sticks altogether because their computers can control emmisions better with an electronically controlled automatic. If it has an auto, I won't buy it, and I will seek out those that still do... except for GM products that is. :yes:
  15. I don't know about them being more expensive than Toys, but my current Jeep addiction is definitely cheaper than my VW addiction. I guess it doesnt hurt me either being a Jeep dealer tech running into cheap or free parts quite often. Jeeps are definitely cheaper than a lot of things we could be into, and it also depends on what you want to do with em, and if you don't mind playing with used parts.
  16. I could use it as a DD, but more often it is just easier to jump in one of the Hyundai's and just go, but sometimes it will get driven on a daily basis, depends on how I feel at the time. I just bought a baby seat for it so I can drive it more often too. And now that I think I have my 68 Beetle sold, I may want to drive it more often as it will be my only "fun car" to drive.
  17. Urethane is the glue you refered to for the front window. It is what is used to install windows like that that don't have the rubber gasket. It is a thick rubbery black tar looking stuff that is really nasty if you get any on you.
  18. I'm in the process of making a fitted fan shround for the WJ electric fan I am installing in my 2.5 MJ. I'm using 2 seprate 2.8 V6 fan shrouds cut down and epoxied to the fan unit itself so it can mount to the original radiator mounting holes. I hope the 2 part epoxy holds up OK. I bought an adjustable temp fan controller, and plan on doing all this when I replace my leaky water pump. I'm curious to see how much of a difference it will make with no crank driven fan in there.
  19. If he only paid $50 each for them, hes robbing that dealer blind, scrap price paid to regular people is at least double that if not triple. But I have to have respect for someone like that with their own business making a good profit.... at least someone is. Not that it is any good that he will want to screw the next guy, but business is business and you are there to make a profit. Now the Katrina cars is another story.... all of those should have went right to scrap, no ifs, ands, or buts. Reselling one of those cars is ripping someone off. That guy should be publically whipped for something like that.
  20. :agree:
  21. Not selling the whole vehicle may also be the yards rules, many yards won't sell complete vehicles for whatever reasons, especially newer ones. Just saw on one of the spike shows where they are putting a dodge drivetrain under a 70's Ford body... they said that thee yard doesnt sell whole vehicles, but made an exception for them. Maybe a liability issue?
  22. I have yet to get to the point of swapping in an 8.8. But go to therangerstation.com, and you should be able to find that info.
  23. You may know stuff about the yota axle already, but I think it would best to stay away from it in an MJ, Too many other good options available.
  24. There are a bunch of members on here from the Charlotte area. Go to the wheeling section and to SE area and youll see whos around.
  25. car-part.com will bring up any number of 8.8's with 4:10 and limited slip for $300 and up, or pick-n-pull for half that.
