GrizzzzBear
Everything posted by GrizzzzBear
  1. I went to a Local Spring Shop. Easier to get and deal with. Prices were reasonable. Got Exactly what I wanted, with no issues. My Springs were Metric Ton with additional 4" lift.
  2. Hey Gang, My Comanche caught fire today. 89 Longbed, with a cap. Would anyone be interested in saving it from the Scrappers Torch??
  3. https://www.ebay.com/itm/291995724355?hash=item43fc4d2a43:g:HI4AAOSw44BYLzJT&amdata=enc%3AAQAIAAAA8CikVVcv6v8LXIT3k3rhiEyNH%2B2wwOQUpUbQa%2FNYOVh%2BJDIOjZpnqRyNV%2Fsm3ac9XyaAs86dWCe98JPUzpc1gRzDoH%2Bj1HBnGDJGEjqiDntO62NvwzFQP934dAKtuN5pVFZAsfm4%2BL07idDhWsTZ7iQOpHgZB79eEkg9Fq0C8n1JqKI5D3CvYeNwQr9tMZWsFDOdRHXH5tlbi%2Fax8KawEM0L8FOge7uXL5Us77jylPSLSQZbq45Y5uJFjxXm59JZ%2FAX2X1driOzP4zKffaGrcXoBTWWK3p%2BFZtOnbAM9Rc3EaCfiziDe9Hb1%2F2iz8%2F3AoQ%3D%3D|tkp%3ABFBM-vaw75Ni
  4. I'm a fan of the last pic, the Warrior Products one. Would like to have one with a Winch, But I really like the looks.
  5. The thing with the Trim Rings, Jeep Rings are Stainless and line up with the Wheel lines. Chevy's are Different, as are most Generics. Too Many Online Sellers say they will "Fit", but they will never say they are an Exact Copy. Learned the hard way. Went through 4 sets, before heading to a Parts Yard I could walk through. Good Luck.
  6. Just Remember, California has all of the Oddball Restrictions and Parts. After seeing the California Debacle myself, I Refuse to get any Vehicle from there.
  7. Sounds more like an Issue of the Head is putting out too much, the Speakers can't handle all of it, Head unit gets Overloaded and does a Shutdown to Reset. I had the same Issue with a Home Stereo. Had a friend (he did sound systems professionally) who checked and told me about the Issue.
  8. I had used the Tape, to hold the Wires & Lights in place, while the Silicone Cured/Dried. Had to move the lights, they came off pretty easy. No troubles to reuse them or wiring.
  9. Westin has a good bumper. The Choice is to get theirs, a Used MJ Factory one, or Custom Fab.
  10. I ran the wire for lights, simil;ar to what others say to. The lights I have are a Trailer Side Marker light. Put out tons of light. Secured with tape and Silicone.
  11. The Black Center Caps, were used on a multitude of Models & Years. Check around, they are not too difficult to find. Just a quick look, I found singles, about $25. Sets of 4 or 5 started about $125. I have the Chrome version on my MJ. With the Stainless Rings, Not an easy find anymore.
  12. I've ordered several different colors, for various cars/trucks from Automotive Touch Up. Every one has been Spot-on for the color. Very Pleased with them!!!! https://www.automotivetouchup.com/
  13. On the MJ Bucket Seat Bracket, there are more Supports, to keep the Bucket Seat from "Rocking" from side to side. Check with krustyballer16, I Believe he was making Replacement Bucket Seat Brackets. TAKE NOTE: The Bench Seat Brackets, WILL NOT work Properly for Bucket Seats. ALSO: The XJ Brackets ARE DIFFERENT than MJ Bucket Seat Brackets. The Floor Contour IS DIFFERENT between them.
  14. Neat Set up. Made me want to check out ARB Compressors. Under the Seat, gave me an Idea. Maybe get a Small ARB, stuff it in the Console, under the Armrest.
  15. Thank You. I really appreciate the pic.
  16. Before you install the new buckets, Did you have Buckets or a Bench in it?? Bench Brackets are not the same as Bucket Brackets.
  17. Getting to the point of being ready to add an Air Compressor to my rig. Not sure just where to mount it. Have a nice sized Tool Box, behind Pass. Seat. Have to keep the Hi-Lift Jack inside. Have a bag with Straps, Jumpers, and some other essentials, behind Drivers Seat. Have the Air Tank going in on Pass side, outside of Frame, with a Skid Plate. Curious about where any others have mounted a Compressor.
  18. Did you have Buckets already??
  19. I have the same Issue. What Box & Where is it??
  20. What size was the Engine?? Need a 4.0 Air Filter Box.
  21. Really sad news, that Sheisters are taking advantage of Us Jeep Owners. Hopefully you get some progress after they see a drop in business, for jeep parts.
  22. May the Good Lord see fit to give Jerry, Peace & Happy Trails, in a Comanche.
