Pete M
Administrators
    114
Everything posted by Pete M
  1. A/C is officially fixed. and a huge thanks to the engineers for putting a schrader valve on that pressure switch. I was fearing the worst and a whole refill process.
  2. all depends on what you want to do with it. I don't fit well trying to sleep in a shortbed with the gate up. I love my trailer and take it all over the place. can't imagine life without one.
  3. very common. that metal is just too soft for the task at hand. weld on a washer. I'm confident it'll cure your woes, but at the very least it's free to try.
  4. can you share a picture of this specific issue area? maybe it's not what's in my head.
  5. the factory steel that's there isn't up to snuff. hardened steel should cure it.
  6. wait, why can't we just weld on a washer? it just seems like we're overthinking this.
  7. which axles are we talking about? not all ratios are available for all axles.
  8. Pete M
    Epic MJ Roadtrip
    you can just swap in a later radiator with the cap and be on your way. no need to mess with the rest of the system right now. upgrade it later on at your leisure.
  9. the entire body is different. the entire firewall is different. everything that mounts to the body/firewall will bedifferent. I'm not saying it's impossible, but I wanted to make sure the OP knows it's not a shared-platform like the Cherokee.
  10. can I get my official mall crawler card now? found some plastic tail guards at a 'yard and painted them up. also replaced the cracked tail housings because they were cheap.
  11. Pete M
    1J7FJ26S6NL136874
    'tis a gorgeous survivor! I would start hitting the classic car shows asap.
  12. Pete M
    Epic MJ Roadtrip
    have fun!
  13. good thing there are 5!
  14. olive greens and Jeeps just go together
  15. bed looks saveable
  16. more or less everything is in a different place and there would be a lot of custom fab work to mount everything. an XJ Cherokee would work much better.
  17. the difference is not just in length, but also angle.
  18. '07 model year would still be KJ. I'd wager that started with the '08 KKs. now ya got me thinking about if I can swap the second gen Liberty brakes onto my first gen
  19. I'm not 100% on the specs of the 08+ KK Libertys. 17s was a later year of KJ. though it's not he best looking rim in the world IMO. I went with the TJ Rubicons for my Liberty
  20. Liberty KJ rims are all 16 (or 17) and the same bolt pattern and backspacing as MJ rims.
  21. I liked the suburban and the forester truck scenes in Dante's Peak
  22. not such luck. it's a writeoff and will need to be rebuilt. too much of a shock to the concrete. hopefully the ramps are deemed ok.
  23. 'tis a gorgeous example of the breed.
