ratrapp
Everything posted by ratrapp
is the cam gear chewed up as well as the dist gear?
86 mj using 95-96 booster/aster cylinder
ratrapp replied to ratrapp's topic in MJ Tech: Modification and Repairs
yeah ive got the spacer,master cylinder and prop valve all together.i had already deleted the load leveling valve in the back.i never could get fluid to come through it.it had sat several years in the woods before i got it. -
the 99 booster is slightly different than the 95-96 booster.I'm using the 95-96 booster.when i did this swap on my old 88 all i did was grind a flat on the rod to accept the older style brake light switch.i was asking to see if anything needs to be clearanced for the booster to clear the firewall or anything else. -
Steering box recommendations?
ratrapp replied to Warren99's topic in MJ Tech: Modification and Repairs
i used e redhead box on a customers 96bronco and it was only marginally better than the worn out stocker.used a psc replacement on my old 95 zj with stock tires and no lift and was disappointed as well.they all worked and didnt leak but didnt seem to offer much better steering feel. -
the 95-96 booster is the dual diaphram and is longer and thicker than the original style over all mj boosters.it worked fine in my old 88 but the 86 seems to e the bastard child of mjs. -
ratrapp posted a topic in MJ Tech: Modification and Repairs
i know the 86 has differences that the 87 ups don't have.i did the booster/master cylinder upgrade on my old 88 but i passed my 86 on to my nephew for his first vehicle.ive already bypassed the leaking load leveling valve.ive got the parts just don't know if anybody has actually done the 86 if there are any slight differences that i need to plan for. -
you can tell its been replaced before which actually means nothing.I'm sure a lack of greasing it can have made it go bad if its bad.if you do replace it you'll need to rock the steering wheel to get the bar back in place as the front end will shift some when its removed.
is the cam gear chewing up as well?unfortunatly think about where the metal from the gear has went through the engine,twice now.
thats actually the joint end,the other end has the bushing.
clutch kit preference-quality
ratrapp replied to tarmac2dirt's topic in MJ Tech: Modification and Repairs
i second the luk clutchs.good clutchs if you use them for what there intended to be used for.thats the only clutch i use in my shop for the last 10 years and i havent a had single one die or fail prematurely. -
been having brake light issues.found the culprit.the original spacer,2 plastic bushings and bolt have been replaced with just a bolt.looking for everything minus the switch,thanks
yeah you used a 78 dt which has both side and top terminals where a standard 78 has just side posts.
thanks guys,i 'm going to make the 58 fit but if the poor 2.8 survives long enough to outlast this battery ill go with a 34 or 78.
I'm finally getting ready to put my 86 on the road monday.i had been just putting any random used battery i had laying around to get it started and running.i went and got a new group 58 battery yesterday because thats what according to all the parts stores that its what it takes.the 86 battery tray is different from the 87 -up trays.the 58 fits but it just doesnt seem right as it doesnt lock in the tray like its not the correst size.even my hold down bracket says standard and one size and heavy duty flipped over.curious to see what other 86 owners use for battery size.i can cut up the tray but would rather just get the right battery.
you shouldnt need adjustable ball joints and you wouldnt know which ones you needed unless you went to an alignment shop and they said you needed them as thats the only way camber is adjusted on the jeep axle.
Showing 10-11v gauge battery at 13.9
ratrapp replied to ja_racing's topic in MJ Tech: Modification and Repairs
the 88 i had showed a good volt less than what it actually was.my grandmother bought it when it was a year old with only 10k miles on it and it had always been off some.factory gauges arent always the most accurate. -
the last two customers we had that brought in detroit axle parts were a simple cross drilled rotor and pad combo that sonded like 2 rocks grinding together when stopping.they stopped fine but sounded awfull.another was a lincoln town car that customer wanted all 4 ball joints replaced.they lasted around a year before the lowers were going bad again.i don't know about them being reboxed moogs,but ive installed enough moog parts over the last 25 years that i'm pretty sure they werent moogs.moog also doesnt make as good a product as it did 10 years ago either.
i know the wj arms are solid arms and do allow for more turning clearance turning but you do have to grind the bushings down to make them fit.you seem to be on the struggle bus at times so i would just go with the stock arms and keep it simple.yes,most of the detroit axle stuff is crap.it either doesnt last long or simply doesnt fit.its one of these things that you get what you pay for.
i second not using the detroit axle crap.we've installed some of there crap that customers have brought in and its mostly crap.
Removing rear interior molding
ratrapp replied to Spinnakerblue89's topic in MJ Tech: Modification and Repairs
i know this is a dead thread but i want to thank fiatslug87 for the part number for the clips.i found them at summit racing for 2 bucks apiece which beats the crazy prices that they have on them on ebay.i ordered 10 today just to have a spare one or two. -
yeah i would get a noid light and see if the injectors are pulsing.if they are and you have adequate fuel pressure i bet the injectors have froze up from sitting.its not that uncommon.
if you have fuel pressure at the rail then the injectors have probably froze from sitting all those years.
good fitting carpet or vinyl floor kit
well,i finallly got around to installing the carpet today.needless to say the acc kit fits like crap.it isnt molded in any way shape or form.I'm resorting to slicing and glueing to get this in place to look half way decent.on a side note the division seals on the doors i got from team cherokee fit great. -
thanks,i waiting on them now.the pics look alittle rough but i don't mind if i have to sand and paint them.I'm hoping they get here because i afraid usps may have lost them already which unfortunatly is becoming pretty common anymore.if these don't work out ill hit you up.
