ratrapp
Everything posted by ratrapp
  1. i can guarntee if its this bad from the bottom its worse in the inside.
  2. ive done this to my 86.i hate to say but I'm on my second carb after just a year.the one thing i did learn was it is picky about fuel pressure.ive got mine set at 3 lbs by webers instructions.i bought a cheap mr gasket gauge and regulator but in hind sight ive shouldve got alittle better set up for the gauge and regulator.it took a good while before i got the pressure to stay consistent and match the gauge.also if you have an automatic then you may have to modify the kickdown cable and to fit the carb .ive passed the truck on to my nephew and wish there was a better alternative but i havent found a simple alternative.
  3. i think a member on here makes them.i bought a set several years ago and they fit fine.
  4. well the first step is you have to pull the lower dash panel off to access it or at least i did.the other hard part is pushing the release button to get the knob out.there is very litttle room to pull the switch down to unplug it.
  5. thanks,i just messaged him.
  6. did some maintenance on my nephews 86 today such as replacing the harmonic balancer that came apart and when i went to replace the headlight switch i found the connector had melted which really wasnt a surprise.ive looked my normal avenues but i havent found a replacement for the connector.does anybody know of a good source for one?thanks
  7. very nice work,itll be worth it when your done.
  8. i used some sound deadener off of amazon called siless that was pretty inexpensive.it really takes alot of road noise out of the cab.i even put it in the roof under the headliner.
  9. thats not a bad price to balance a rotating assembly if done right.when building any kind of stroker or even using aftermarket parts it needs to be balanced.checking weights of rods/pistons doesnt tell you much.i have had enough stroker engines in my life that i don't skip that step after the first time it happened to me.
  10. i used some brand of sound deadner off of amazon .i think it was called siless or something like that.it was very inexpensive and did a great job of deadening sound noise.i even put it in the roof while the headliner was out.
  11. definitley resurface the flywheel and the 2 little bearings in the kit are pilot bearings.you just have to see which one you have.they can be a pain to get out sometimes.
  12. ratrapp
    House windows
    i think for the price of pellas theyre not a bad buy.of course theyre nicer windows out there but i have a 75 year old 1100 square ft house and its not worth spending crazy money on expensive windows.
  13. did you have the rotating assembly balanced?i bought a stroker kit once that said it was balanced and ready to go.it was not and it had to come back out again and taken to a machine shop to be balanced properly.
  14. ratrapp
    House windows
    when i was about 30 and hadnt purchased my home but about 5 yearsbefore.i got an installer that i seen on tv and that was a mistake.they replaced 7 windows in my house and had a quote lifetime warranty.they were double hung and gas filled for supposedly to help with heat savings.the cost seemed alittle high to me but i knew nothing about installing windows so it seemed okay.after a few years several of the windows had started discoloring from the gas leaking between the panes.well guess what,the place that the company gets windows from went out of business so i had no warranty on them.the installers did a fine job on the windows but the windows were overpriced junk.i learned my self how to replace windows and have one at a time done them.i went to lowes and got some pella replacement windows for around 200 bucks apiece.that was over 20 years ago.ive learned to do many home repairs without calling some one every time something goes wrong.
  15. ive never used anything skp brand so i can't comment on there quality.i have used dorman(not the greatest but better than nothing sometimes)and moog,delphi and even federated line srt and they all seem to fit.i do order a lot off of rock auto but sometimes its better to just bite the bullet and buy local so returning them isnt as big of a deal.
  16. looking good.i wish when i done mine they had made the mj pans.i used xj pans and trimmed and cut and got them in.
  17. do they actually measure 1/2 inch wider than your originals?ive had some that i trimmed a little off each side to make them work but not 1/2inch worth.
  18. that has crossed my mind several times.i need to find where the casting numbers are at and see what year it is.on a side note i finally did the 95 cherokee booster/master cylinder prop valve upgrade today.the original booster was leaking vacuum and the crown replacement didnt work at all.truck hasnt had brakes this good since it was put on the road last year.
  19. no,after the trans mount replaced there are several inchs of clearance between the exhaust and crossmeber.i just wish i knew if the vibration started before or after someone had the trans out before me.i can tell the trans has been out by the cut cooler lines and missing nuts on the kickdown cable bracket.
  20. you can feel some vibration when reving it up.it seems worse when its cold and you first start it up.ive had a race car engine that was not balanced properly and it feels very similar to this.the truck sat for years in a field and i wonder sometimes if this is why it was parked.it runs okay for 2.8 ,i just want to fix this vibration before it causes some other damage.
  21. i don't think its in the suspension.its 2wd and i put new sway bar links and bushings on it.i also replaced all 4 shocks with good kyb gas adjust units.the steering wheel never shakes,its just you feel it in the trans tunnel.the rest of the front suspension is in good shape and even aligned it at my old shop.i thought about just replacing the harmonic balancer to see if it does anything but my visual inspection it seems the rubber isnt in too bad of shape.i had took the rear end cover off and checked it out.there was no metal shavings anywhere and the rear sounds smooth and quiet while driving.the vehicle is stock height so ive kind of ruled out pinion angle but who knows.
  22. i found that out but unfortunatly i don't think thats my problem.jeep has had a vibration since i bought and has slowly gotten worse over the last 6 months.its not in the tire /wheel and just had the driveshaft balanced and it checks out fine.found a broken motor mount but even after replacing both mounts and trans mount it made very little difference.i can tell the trans has been replaced before and was hoping that maybe someone had replaced the flexplate with the wrong one but i can see the counterweight on the flexplate and all the converter bolts are tight.you can feel the vibration directly over top of the trans tunnel.it starts around 45 and progressively gets worse to 65 and then kind of smooths out some.hoping its not in the trans itself.
  23. does anybody know if a flexplate from a same year 2.8 s10 or camaro is the same as the 2.8 comanche?i think they should be externally balanced but i didnt know if they shared the same torque converter pattern.
  24. i just a bunch of these back in june from summit for 1.95 a piece.i see theyre currently unavailable now.
  25. thanks,my local advance auto has 2 in stock,I'm going to grab one today.i ran into the same exact problem you did.
