ratrapp
Everything posted by ratrapp
found a set on ebay
definitly new bushings.as others said a grease job can sometimes temporarily tighten up a bad joint.the harbor freight grease guns arent bad for the price.
looking to see if anybody has a set of fiero v6 valve covers for my 2.8,only found 1 set on ebay and they want $300 bucks for them.would like to dress the 2.8 upalittle and eliminate some of the underhood clutter from the factory covers.
honestly,I'm computer/phone illiterate.i don't have the first clue on how to do it.you can see the difference in the pieces when laid side by side.
i can tell by the rust on the track bar joint thats bad.
well some what good news.the passenger side is now leak free using crown weatherstripping for the 97 up cherokee.the driver side i did have to still adjust the door up and inward some but its now leak free as well.my one gripe is when you install it i wish it had been just an inch longer because when you get it installed you have about an inch gap at the bottom in the middle of the door but ill cut a small piece out of the other weatherstripping i got from team cherokee and fill the gap in.does it cost more?yes but it does seal up the doors better.i don't care if it has wind noise but the water leaks had to be fixed and it did the job.now to replace a few pieces of weatherstripping around the glass and be done with it.
you need two.I'm going to try and put one side on tomorrow after work and do my water test before i even take the other side out of the bag.
i already straightened the pinch seam up quite alot.it got better but the weatherstripping from teamcherokee is just not cutting it.my new ones are supposedly on the truck today for delivery and if they are I'm putting them on tomorrow.
I'm hoping theyll be here this week so i can install them saturday and do another water hose test and see how they do.this all depends on fedex's great sevice.in my area ups is very reliable but fedex not so much.
i just ordered a set of crowns from quadratec for the 97 up cherokee.hopefully theyll seal up the doors.every step i take forward seems like i take two back.
what is a good quality door weatherstripping for the comanches?i made the mistake of buying new gaskets from team cherokee and i went from no door leaks to now water pours in both doors.i threw the old weatherstripping away before i realized it leaks.i looked at the steele/rubber brand but to me they look the same as the team cherokee ones.i replaced the weatherstripping because it had a few tear places around the bottoms of the doors but they didnt leak.the replacements don't look no where near as wide as the old ones.i thought they would flatten out but after three months i realize theyre not going too.i have thought about going to my pick n save and find used ones if good new ones arent available.
86 mj brake booster differences
ratrapp replied to ratrapp's topic in MJ Tech: Modification and Repairs
yeah ive had to replace the booster on a few vehicles over the years for doing this.its definitely the booster. -
if you look up a booster for an 86 it shows 5474040 and it says 86-87 but if you look up an 88 it shows 5474071 and says fits 86-90 .i know 86 is like the bastard year for these jeeps.these were the only new ones that it showed.ive replaced every single piece of the brake system on this truck and they were working good and now the booster diaghram ruptured.push the pedal and it goes to the floor and the nice swooshing nice. -
in my never ending quest to get the 86 road worthy the last piece of the brake system has failed(booster).rock auto showed 1 new booster that said fits 86-87 but if you look at a slightly newer mj it shows a different number but it says fits 86 thru 90 i think.i don't know if theyre interchangable and i really don't feel like doing the 96 xj booster upgrade at this time.
good fitting carpet or vinyl floor kit
it was more than just a trimming.i just ordered a black carpet kit from rockauto.hopefully itll fit better than the vinyl mat -
i may give acc a try.the vinyl floor mat they sent me is almost universal.it was way too long plus it came with a grommet to go in the floor for vehicles with floor mounted dimmers.I'm pretty sure the mj never came with a floor mounted dimmer. -
I'm finally finishing the interior up in my 86 to pass onto my nephew for his first vehicle.i originally purchased a vinyl flooring kit for it from rockauto a while back.the truck had come factory with the vinyl mat as its a low optioned truck.the mat they sent was supposed to be molded but it is just a completely flat mat.ive had it too long to send back and have heard horror stories about acc carpets.I'm leaning towards just putting regular carpet in it if i could find something i know fits.any suggestions on a good vendor?
ordered them now,thanks
thanks,ill be making an order for the brackets this week.i think thats a more common speaker size anyway.
looking for the factory 4x6 speaker brackets that mount behind the seat in the side pillars shipped to va,thanks
looking for 2 doors that have the sport style mirrors and manual regulators for my 86 mj.even if you only have 1 side I'm interested.must be close to va for me to pick up.i don't care if they have the movable vent windows or not.
trouble bleeding the front brakes
ratrapp replied to Pete M's topic in MJ Tech: Modification and Repairs
dumb question but are your bleeder valves pointed up?if the bleeder screw is pointed down you'll never get it to bleed. -
found one on ebay,hopefully it works
