ratrapp
Everything posted by ratrapp
as long as they'll bolt on then i'll upgrade the intake at a later time.
i wasn't aware the bolt patterns are different for the manifolds.i just put a new exhaust manifold on and really don't want to fool with tb issue just yet.i can get a 91-95 head for less than a $100 from the local junkyard if i pull it myself.i just wanted to get a head already done and ready to swap on the same day as right now my mj is my only running vehicle as i haven't had time to put my 393 back in my mustang.i may just put up with the head gasket seeping oil.it's definitly the head gasket because i switched to the new style steel valve cover and fel-pro perma seal gasket and my valve cover has never been that dry and no more oil in air box.thanks for help,guys.
umm,that really didn't answer anything.what i'm asking is it really worth changing to a ho head and are all 91-up heads the ho style.
my head gasket is starting to seep oil after 160k miles.i was thinking about changing to a different head while i'm at it.i've heard different stories about ho-heads and even newer heads.would it be worth my while to do this and i really don't want to change my intake just and deal with the tb issues.i'd like to hear from personal experiences.thanks
you don't have to drop the fuel tank on a mj to get the pump out.not on my 88 anyway.
some of the older 258 cj motors had a plastic cover on them.they were crack prone and i don't know if they would interchage with a 4.0 or not.
poor fuel economy..why?
ratrapp replied to 90eliminator's topic in MJ Tech: Modification and Repairs
i would fix the gauges and see what i'm really getting.my mj with 160k 4.0 and a/t gets about 16mpg.it didn't get much better than that when it was new.my gas gauge when i fill it up takes 100-125 miles before it moves but is accurate when it hits empty.you can't trust the gauges in these trucks.mine is a bad sending unit. -
Water Pump 1990 Comanche 4.0
ratrapp replied to SchneiderFishing's topic in MJ Tech: Modification and Repairs
i got the hesco pump as well.expensive but a very nice piece. -
91' 4.0L Valve Cover Gasket
ratrapp replied to jesawyers's topic in MJ Tech: Modification and Repairs
i've used the right stuff sealant with alot of success.it is alittle expensive but it's still cheaper than a $35 valve cover gasket and you can make several gaskets with it for less than $20 a tube depending on where you get it.advance and federated auto parts both carry it. -
HO valve cover on a Renix 4.0 UPDATE
ratrapp replied to mjeff87's topic in MJ Tech: Modification and Repairs
i did this swap as well.it has all but eliminated my blowby in the breather box.the downside is that i'll have to oil my k&n filter now instead of the engine doing it for me.i think i spent about $20 for a cover and used a fitting i had in my tool box and a can of therightstuff sealant.money well spent. -
i bypassed mine as well.after the 3rd valve went out in 10 years i got tired of it.i also used the newer cherokee hoses.i have more heat now than ever and no more control valves to worry about.like everyone says all the valve does is cut water flow off when the a/c is on but my a/c died years ago so it doesn't matter to me anyway.
How many miles have you racked up?
ratrapp replied to Comanche County's topic in MJ Tech: Modification and Repairs
mine has only 160k.i got it from my grandmother who bought it with only 7k miles on it.the drivetrain is all original.it doesn't run as good as it did 21 years ago but i would take it anywhere.i feel sure it'll make it to 200k. -
thanks.actually i would need the 34 or 35 tooth as i have factory 3.55s.i think i'll order both gears to be on the safe side.once again,thanks guys.
my 88mj came with stock 215s and i went to 235s.i would like to change the gear to make the speedo right.does anybody know the # of teeth that came stock?it has a 4.0 /a/t.i figure 1 tooth less would make it right.i'd like to be able to order one without taking mine apart first.
in va. there is a 0 deflection in ball joints for most vehicles.the exceptions are listed in our state rule book.when i check them for balljoints if they have only a few thousands of movement i let it go but do tell the customer that in the near future they'll have to be replaced.we ususally use spicer parts in our shop and it's odd to see ones with play with that little time having gone buy.you could try the old grease them right before you take it and get it inspected trick to try and tighten them up first.
i only use mopar sensors on my truck.when i worked at the jeep/dodge dealership 7 years ago i used my employee discount and replaced every sensor except the knock sensor on my truck.i have seen several different crank sensors fail or not work at all from the aftermarket.i to this day still use mopar plug wires because they're not that expensive and are better than anything in the parts store.
my 88 has the 23.5 gallon tank as well.the smaller tanks used 2 straps to hold it up where the bigger used 3 straps.funny thing is that before i replaced my tank is when the gas light came on it would have 4-5 gallons left.after i replaced the tank it comes on when there is only 1-2 gallons left.
Closed to Open Cooling System Conversion
ratrapp replied to LEAD_NOT_FOLLOW's topic in MJ Tech: DIY Projects and Write-Ups
is the hesco waterpump worth the money?i replaced my w/p with a mopar one about 10 years ago when i worked at the jeep/dodge dealership and it just noticed started to leak when i was replacing my belt and alternator and had thought about upgrading as well.i have also done the closed to open conversion as well except i removed the heater control valve as well.i have never used and hesco pieces and was wondering if it's worth the money.if it is i may get one for the g/f's 95 grand as well. -
heater core replacement ???
i've did mine twice.the first lasted 4 years and i just replaced it again 3 months ago. -
it's common for 2.5 and 4.0 heads to crack there.
My 1988 MJ RestoMod/Tribute (New pics 01.09.12 on p4)
ratrapp replied to phenryiv1's topic in Member Projects: Your Comanches
i am upgrading my cluster to one with a tach and will be taking my gauge cluster out.it has gauges but no tach.let me know if your interested in it.i'll let it go pretty cheap. -
man that truck looks just like mine.same color and pioneer package as well.i also inherited mine from my grandmother 10 years ago as she bought it with only 8k miles on the clock.it's starting to get a little rust above the rear fender flares but it has served me faithfully for 10 years and i wouldn't trade it for the world.good luck with your project. -
Auxiliary Fan Question
ratrapp replied to highlandjeeper's topic in MJ Tech: Modification and Repairs
i'm also interested in this as well.
