Byrdock
1 Follower
    Angier, NC
1135 profile views
Byrdock's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. You still making these? I could use one fully assembled. Thanks
  2. Byrdock
    1J7FT36L8KL494319
    Also available on flea bay from NJ.
  3. After this and a few more tinkers, I'll be ready for a throttle body. Thanks!
  4. Email heading your way! Thanks!!
  5. I'm all for it too. Need an excuse to work on the MJ!
  6. I had the same problem a few weeks ago. I had replaced the CPS a few hundred miles ago, so I didn't even check that, but had a MAP sensor from another truck and swapped it in and she fired right up. Also, I put the wire harness where the sensor ground is back in the plastic sleeve. So one or the other might be a fix for you. I haven't had time to swap the MAP sensor back to see if that was the problem or the sensor ground that was redone by previous owners.
  7. You can have it for whatever it takes to get it to you.
  8. I might have one. Cover and foam are toast.
  9. I have a gray vinyl and a blue cloth seat if you're interested.
  10. What color and condition are your bucket seats? And what color bench are you looking for? Might be able to help you out.
  11. My May of 89 was in there too. Found out I have delay headlamps, didn't know they did that back then.
  12. Byrdock
    1J7FJ26LOKL603601
    It was easier to swap out the black steel factory rims I had on my rust bucket. Just need to swap out the chrome door handles when I get a chance.
  13. Byrdock
    1J7FJ26LOKL603601
    Hi fellow MJers, Just picked up this nice survivor. 89 base long bed, 4.0 w/ AX-15 and NP231 with dana 30 and 35. Fresh paint, factory original red, and gray interior with gray vinyl bench and tripped 134,000 on the ride back to her new home in Angier, NC!
  14. Glad to see some more Comanches in NC. You'll have fun working on this one!
